ROS PMC Business
- Proposal: Michael Carroll proposes to mentor Michael Carlstrom as a ROS PMC Committer (Article 7.8.iv)
- @mjcarroll makes the motion
- @ahcorde seconds
- Pass by consensus
Regular Business
Buildfarm update
- PTAL Buildfarm Issues Triage Sheet
- ROS Greenness:
- Humble jobs haven’t run in a while (investigation)
Issues
- test_allocator_memory_strategy failing in Rolling Connext CI (Michael will take a look)
Priorities
- rmw_connextdds support message making ROS2 CLI tests fail (Michael assigned)
- sros2.test.sros2.commands.security.verbs.test_generate_policy_no_nodes.test_generate_policy_no_nodes failing consistently in Kilted CI (Michael assigned)
- The RecordIntegrationTestFixture.can_record_again_after_stop test is tend to be flaky (Michael Orlov assigned)
- ros2service.ros2service.test.test_cli.test_cli failing consistently in Kilted (Scott assigned)
- ros2cli daemon get publishers and subscribers by topic test failing in connextdds (Pending review of skip history and depth check for rmw_connextdds. by fujitatomoya · Pull Request #1064 · ros2/ros2cli · GitHub)
Waffle note-taker
- Nov 6 + Nov 13 - @sloretz
Rosdistro assignments
Rosdistro is a weekly assignment to monitor incoming issues and pull requests in GitHub - ros/rosdistro: This repo maintains a lists of repositories for each ROS distribution. Two people per week are assigned to be the rosdistro maintainers.
Release Management
- Audrow (Humble)
- No updates.
- Yadu (Rolling)
- No updates.
- Marco (Jazzy)
- No updates.
- Scott (Kilted)
- Announce today, freeze Wednesday, sync Thursday
Agenda
- [@emersonknapp] Proposal to create a ROSGraph Working Group. Find the charter at: ROSGraph Working Group - Google Docs
- [Waffle Triage] Should we switch from ament_python to ament_cmake (+ament_cmake_python) in tutorials?
- GitHub · Where software is built
- @mjcarroll I see three alternatives
- Add ament_cmake as a parallel track to the tutorials
- Remove ament_python entirely from the tutorials
- Bring ament_python to parity with ament_cmake
- [scott] we should prioritize creating a document showing what capabilities each type of build has:
- Cmake vs ament_cmake vs python
- Bringing python to parity is a good long term goal in the context of “pip install ros”
- [emerson] as a datapoint: our (internal) style guide is biased exclusively to ament_cmake
- [shane] should there be a REP if this is tool-facing?
- @cottsay (I think) more package developer facing
- [@cottsay] colcon dependency isolation during builds
- 0.20.0 and newer
- COLCON_FEATURE_FLAGS=restore_build_isolation
