We’re more and more thinking that there should be a RMW-RMW bridge for ROS 2.
Our specific use-case is simple - a microcontroller with MicroROS (thus FastDDS) and the rest would be better with Zenoh RMW. But we can’t use Zenoh in the rest of the system because DDS and Zenoh don’t talk to each other.
I know (or guess) that between DDS-based RMWs, there is the possibility to interoperate on the DDS level (through it’s incomplete for some combinations AFAIU).
But if you need to connect a non-DDS RMW, there’s currently no option.
I haven’t dived into RMW details too much yet, but I guess in principle, creating such bridge at the RMW level should be possible, right?
Has anyone tried that? Is it achievable to create something that is “RMW-agnostic”, meaning one generic bridge for any pair (or n-tuple) of RMWs to connect?
Of course, such solution would hinder performance (all messages would have to be brokered by the bridge), but in our case, we only have a uC feeding one IMU stream, odometry, some state and diagnostics, and receieving only cmd_vel and a few other commands. So performance should not be a problem at least in these simpler cases.
It seems like it should be possible to create an rmw-rmw bridge. I would expect a single process could initialize two RMW in separate rmw_context_t instances, and then bridge stuff across them.
Although they don’t exactly meet your requirements,
I know of two products with similar concepts.
rmw_zenoh_pico
This product has been left unbuildable for a long time, but I hear it will be done soon.
The next update will include the following:
M5Stack core + Arduino support
PlatformIO support
Zenoh-Pico 1.4.0 support
However, while rmw_zenoh_pico has similar capabilities to microros, it is not exactly the same.
If you have made modifications to the microros client, the transition will be difficult.
custom from fork zenoh_plugin_ros2dds
This product was created by the same developer as rmw_zenoh_pico for the purpose of operating in conjunction with it.
Change the format of the zenoh_plugin_ros2dds’s unique liveliness/topic key to the rmw_zenoh format, and recognize the rmw_zenoh node as a remote zenoh_plugin_ros2dds to communicate.
I’ve heard that basic testing of this program has been completed and they are planning to release it as open source.
But, Like rmw_zenoh_pico, the projects on this site have a very long internal release process, so I don’t know when it will be released.
However, this product is modified from a fork of zenoh_plugin_ros2dds, so the dds side is fixed to cyclonedds. If your program only has sub/pub, it may work, but server/client communication may not be possible.
In the early stages of this product, there were plans to replace DDS, but this was deprioritized as developers began other plans.
Thank you for your explanations. You confirmed what I was worried about I have a very similar problem with somebody that built a bridge from CycloneDDS based ROS to their own private DDS middleware. Now I would like to move to Zenoh as RMW but that would break this integration.
Are you aware of any progress form the makers of rmw_zenoh_pico on their fork of the Zenoh_plugin? Maybe @Yamazaki_Katsumi ?
If I would attempt to try this myself, I assume a bridge on topics should be doable. However I guess Services and Actions are more challenging because Zenoh is implementing the differently. Also features like Security would probably be excluded.
