[Release] AI Flight Integrity Observer: Measuring PX4 Offboard degradation under controlled AI inference lag
Hi guys,
I’d like to share AI Flight Integrity Observer (AFIO), an open-source ROS 2 / PX4 runtime assurance observer for Offboard autonomy.
AFIO is designed to make one failure surface visible:
When a companion computer is running VIO, visual tracking, neural planning, or heavy perception workloads, is PX4 still receiving fresh, temporally consistent, physically realizable Offboard intent?
It does not modify PX4, replace failsafe logic, publish recovery commands, or intercept control. It is observe-only.
Why this exists
A. Degraded communication / RF / telemetry link volatility
In degraded communication environments, the Offboard stream may not simply disappear. It may become bursty, stale, or highly jittered while still producing syntactically valid messages.
A flight controller may still receive /fmu/in/trajectory_setpoint, but the control intent may no longer be temporally healthy.
AFIO exposes this through standard ROS diagnostics:
setpointAgeMs
setpointJitterMs
staleStreams
causalAlignment
dominantCause
These signals can be consumed by external autonomy managers, dashboards, or fail-safe state machines.
B. Edge-AI / vision stack overload
VIO, object detection, tracking, neural planning, mapping, and semantic navigation can create bursty companion-compute load.
When inference latency spikes, the Offboard setpoint publisher can become delayed or irregular even while PX4 itself remains healthy.
AFIO detects this as:
SETPOINT_JITTER
SETPOINT_STALE
STALE_STREAM
POSITION_RESPONSE_MISMATCH
COMMAND_RESPONSE_MISMATCH
How AFIO works
AFIO sits as a passive observer on the ROS 2 / PX4 boundary.
It subscribes to:
/fmu/in/offboard_control_mode
/fmu/out/vehicle_odometry
It publishes:
/diagnostics
  ai_flight_integrity/flight_execution_integrity
CSV labels
  setpointAgeMs
  setpointJitterMs
  flightResidual
  totalResidual
  dominantCause
  diagnosticLevelName
The core is a NARH-inspired boundary residual observer. NARH here means Non-Associative Residual Hypothesis. AFIO does not claim to inspect PX4’s internal solver order. Instead, it applies the residual-auditing idea at the Offboard boundary: intent stream, feedback stream, stream freshness, and Offboard semantic mode are evaluated together.
Controlled AI-lag injection test
Real UAV hardware stacks vary widely: ELRS / 4G / 5G / WiFi links, Jetson Nano / NX / Orin, RK3588, NPU boards, DDS settings, PX4 versions, and different Offboard planners.
A single real-drone benchmark is useful, but not broadly generalizable by itself. So AFIO includes a decoupled ai_latency_injector_node for controlled-variable testing.
The observer does not read the injector state. It has no access to ai_lag_ms. It only sees the PX4-facing boundary topics.
In a Gazebo / PX4 SITL circular tracking mission:
Injected AI lag Outcome Dominant cause setpointJitterMs p95 flightResidual p95
0 ms 100% OK 100% NONE 50.9 ms 0.214
30 ms 100% OK 100% NONE 57.2 ms 0.237
80 ms 100% OK 100% NONE 64.4 ms 0.264
150 ms 100% WARN 96.9% SETPOINT_JITTER 119.0 ms 0.483
300 ms WARN + ERROR SETPOINT_JITTER / STALE_STREAM 277.2 ms 1.107
Interpretation:
0–80 ms:
  The system remains aligned. AFIO stays quiet.
150 ms:
  The Offboard boundary enters a measurable degraded state.
  AFIO emits SETPOINT_JITTER before a hard failure.
300 ms:
  The Offboard stream crosses a freshness boundary.
  AFIO reports STALE_STREAM / RESYNCING through standard ROS diagnostics.
What I’d like feedback on
For PX4 / ROS users running VIO, visual tracking, neural planners, or heavy perception on companion computers:
  1. How do you currently detect temporary DDS jitter, companion-compute overload, or Jetson/RK/NPU thermal throttling during Offboard autonomy?
  2. Would a standard /diagnostics + CSV label format be useful for regression testing and post-flight review?
Links:
GitHub: GitHub - ZC502/ai_flight_integrity_observer: A zero-intrusive ROS 2 / PX4 runtime assurance observer for Offboard autonomy under degraded AI compute and communication conditions. · GitHub
  • License: Apache-2.0
  • Compatibility: ROS 2 Humble / Jazzy + PX4 v1.14 / v1.15
