Just a query, but the performance.log is a link to another text file in gazebo:
/home/user/.gazebo/server-11345/default.log
So technically I’m not sure the tutorial documents are correct when you copy over this file. The gazebo logs are fine though
Hi @cdrwolfe, the symbolic link from the performance.log file to the target that you mentioned is the expected behaviour. We have clarified in the submission instructions that the -L / --dereference option should be used when copying the logs to ensure that the link is followed – thank you for the question.
