OpenSplice move to Eclipse Cyclone DDS in ROS 2
Based on community demand and user feedback we’d like to focus our ROS efforts on the Eclipse IoT Eclipse Cyclone DDS project. What do you think? OpenSplice users can switch to rmw_cyclonedds which is easier, 3x faster, 1/3 CPU and uses less memory than OpenSplice. Eclipse Cyclone DDS will be familiar and easy for OpenSplice users. We contributed both and Eclipse Cyclone DDS is the new generation. Please reach our if there’s anything you use in OpenSplice not already in Eclipse Cyclone DDS and we’ll work hard to make sure it is in Foxy. We are here to support you via GitHub issues. You can also DM @eboasson @rotu @joespeed. Here is more on Eclipse Cyclone DDS.
How to switch from OpenSplice to CycloneDDS in ROS 2:
Install CycloneDDS:
apt install ros-eloquent-rmw-cyclonedds-cpp
                (or dashing)
Run ROS with CycloneDDS: Set env variable and run as usual
RMW_IMPLEMENTATION=rmw_cyclonedds_cpp
Confirm RMW: In Eloquent, to confirm which RMW you’re using
ros2 doctor --report
note: OpenSplice has not been removed from the current ROS 2 distros.
That’s quite a mouthful.
@joespeed
thanks for the information, cyclonedds works fine with good stability and footprint !
I moved forward with the removal of OpenSplice for Foxy:
Thanks for being open and straightforward with this @joespeed, makes total sense. Given our discussion about this it might be worth clarifying for others: this isn’t a change on existing ROS distros. OpenSplice will continue to be supported there. The change in focus (and subsequent RMW impl removal) applies to Foxy and beyond.
OpenSplice removal from rmw_implementation: Remove OpenSplice dependency by jacobperron · Pull Request #79 · ros2/rmw_implementation · GitHub
A few more dependencies to OpenSplice removed: Remove OpenSplice dependencies by jacobperron · Pull Request #56 · ros2/rosidl_typesupport · GitHub
Thanks @Jacob! :100: More info for those looking at Eclipse Cyclone DDS RMW bit.ly/eclipsecyclone a project of Eclipse IoT and OpenADx autonomous driving WG and testbed
Nightly package archives from https://ci.ros2.org will no longer include rmw_opensplice_cpp: remove OpenSplice from packaging jobs by dirk-thomas · Pull Request #401 · ros2/ci · GitHub
From consuming the nightly archives to generate the ros2:nightly docker images. It appeared that the archives stopped shipping rmw_opensplice_cpp about a month ago when it was removed from the ros2.repos file.
That makes my post non-news then.
Is Cyclone available on Windows 10 as well?
Yes! Windows, Linux, macOS M1 & x86, FreeRTOS, Solaris 2.6 (because Erik & Morgan are sentimental) and 1/2 dozen OS.
https://github.com/eclipse-cyclonedds/cyclonedds#getting-started
$ cd build
$ cmake -G "<generator-name>" -DCMAKE_INSTALL_PREFIX=<install-location> ..
$ cmake --build
