New Packages for Jade 2017-05-01
We’ve got 18 new packages as well as over 100 updated packages.
Thank you to all the maintainers and contributors who helped make these releases happen!
P.S. Jade will be going EOL after the upcoming Lunar release. We’ll give good notice before doing the last sync, but those of you still using jade might want to consider starting to migrate to Kinetic.
Package Updates for jade
Added Packages [18]:
  • ros-jade-eus-qp: 0.1.13-0
  • ros-jade-eus-qpoases: 0.1.13-0
  • ros-jade-fzi-icl-comm: 0.0.2-0
  • ros-jade-jsk-control: 0.1.13-0
  • ros-jade-pyros-common: 0.4.2-0
  • ros-jade-rosdiagnostic: 1.9.0-0
  • ros-jade-rotors-comm: 3.0.0-0
  • ros-jade-rotors-control: 3.0.0-0
  • ros-jade-rotors-description: 3.0.0-0
  • ros-jade-rotors-evaluation: 3.0.0-0
  • ros-jade-rotors-gazebo: 3.0.0-0
  • ros-jade-rotors-gazebo-plugins: 3.0.0-0
  • ros-jade-rotors-hil-interface: 3.0.0-0
  • ros-jade-rotors-joy-interface: 3.0.0-0
  • ros-jade-rotors-simulator: 3.0.0-0
  • ros-jade-rqt-rotors: 3.0.0-0
  • ros-jade-schunk-svh-driver: 0.2.0-0
  • ros-jade-webkit-dependency: 1.0.0-0
Updated Packages [138]:
  • ros-jade-actionlib: 1.11.7-0 → 1.11.9-0
  • ros-jade-angles: 1.9.10-0 → 1.9.11-0
  • ros-jade-bond: 1.7.18-0 → 1.7.19-0
  • ros-jade-bond-core: 1.7.18-0 → 1.7.19-0
  • ros-jade-bondcpp: 1.7.18-0 → 1.7.19-0
  • ros-jade-bondpy: 1.7.18-0 → 1.7.19-0
  • ros-jade-camera-calibration: 1.12.19-0 → 1.12.20-0
  • ros-jade-can-msgs: 0.7.2-0 → 0.7.4-0
  • ros-jade-canopen-402: 0.7.2-0 → 0.7.4-0
  • ros-jade-canopen-chain-node: 0.7.2-0 → 0.7.4-0
  • ros-jade-canopen-master: 0.7.2-0 → 0.7.4-0
  • ros-jade-canopen-motor-node: 0.7.2-0 → 0.7.4-0
  • ros-jade-contact-states-observer: 0.1.11-1 → 0.1.13-0
  • ros-jade-depth-image-proc: 1.12.19-0 → 1.12.20-0
  • ros-jade-diagnostic-aggregator: 1.8.10-0 → 1.9.0-0
  • ros-jade-diagnostic-analysis: 1.8.10-0 → 1.9.0-0
  • ros-jade-diagnostic-common-diagnostics: 1.8.10-0 → 1.9.0-0
  • ros-jade-diagnostic-updater: 1.8.10-0 → 1.9.0-0
  • ros-jade-diagnostics: 1.8.10-0 → 1.9.0-0
  • ros-jade-dynamic-reconfigure: 1.5.46-0 → 1.5.48-0
  • ros-jade-eus-nlopt: 0.1.11-1 → 0.1.13-0
  • ros-jade-fzi-icl-core: 1.0.4-0 → 1.0.4-1
  • ros-jade-geodesy: 0.4.0-0 → 0.5.2-0
  • ros-jade-geographic-info: 0.4.0-0 → 0.5.2-0
  • ros-jade-geographic-msgs: 0.4.0-0 → 0.5.2-0
  • ros-jade-geometric-shapes: 0.4.4-0 → 0.4.5-0
  • ros-jade-image-pipeline: 1.12.19-0 → 1.12.20-0
  • ros-jade-image-proc: 1.12.19-0 → 1.12.20-0
  • ros-jade-image-publisher: 1.12.19-0 → 1.12.20-0
  • ros-jade-image-rotate: 1.12.19-0 → 1.12.20-0
  • ros-jade-image-view: 1.12.19-0 → 1.12.20-0
  • ros-jade-joy-mouse: 0.1.11-1 → 0.1.13-0
  • ros-jade-jsk-calibration: 0.1.11-1 → 0.1.13-0
  • ros-jade-jsk-footstep-controller: 0.1.11-1 → 0.1.13-0
  • ros-jade-jsk-footstep-planner: 0.1.11-1 → 0.1.13-0
  • ros-jade-jsk-ik-server: 0.1.11-1 → 0.1.13-0
  • ros-jade-jsk-teleop-joy: 0.1.11-1 → 0.1.13-0
  • ros-jade-marti-data-structures: 0.1.6-0 → 0.1.7-0
  • ros-jade-mav-comm: 3.0.0-0 → 3.2.0-1
  • ros-jade-mav-msgs: 3.0.0-0 → 3.2.0-1
  • ros-jade-moveit: 0.8.6-0 → 0.8.7-0
  • ros-jade-moveit-commander: 0.8.6-0 → 0.8.7-0
  • ros-jade-moveit-controller-manager-example: 0.8.6-0 → 0.8.7-0
  • ros-jade-moveit-core: 0.8.6-0 → 0.8.7-0
  • ros-jade-moveit-fake-controller-manager: 0.8.6-0 → 0.8.7-0
  • ros-jade-moveit-kinematics: 0.8.6-0 → 0.8.7-0
  • ros-jade-moveit-planners: 0.8.6-0 → 0.8.7-0
  • ros-jade-moveit-planners-ompl: 0.8.6-0 → 0.8.7-0
  • ros-jade-moveit-plugins: 0.8.6-0 → 0.8.7-0
  • ros-jade-moveit-resources: 0.6.1-0 → 0.6.2-0
  • ros-jade-moveit-ros: 0.8.6-0 → 0.8.7-0
  • ros-jade-moveit-ros-benchmarks: 0.8.6-0 → 0.8.7-0
  • ros-jade-moveit-ros-benchmarks-gui: 0.8.6-0 → 0.8.7-0
  • ros-jade-moveit-ros-control-interface: 0.8.6-0 → 0.8.7-0
  • ros-jade-moveit-ros-manipulation: 0.8.6-0 → 0.8.7-0
  • ros-jade-moveit-ros-move-group: 0.8.6-0 → 0.8.7-0
  • ros-jade-moveit-ros-perception: 0.8.6-0 → 0.8.7-0
  • ros-jade-moveit-ros-planning: 0.8.6-0 → 0.8.7-0
  • ros-jade-moveit-ros-planning-interface: 0.8.6-0 → 0.8.7-0
  • ros-jade-moveit-ros-robot-interaction: 0.8.6-0 → 0.8.7-0
  • ros-jade-moveit-ros-visualization: 0.8.6-0 → 0.8.7-0
  • ros-jade-moveit-ros-warehouse: 0.8.6-0 → 0.8.7-0
  • ros-jade-moveit-runtime: 0.8.6-0 → 0.8.7-0
  • ros-jade-moveit-setup-assistant: 0.8.6-0 → 0.8.7-0
  • ros-jade-moveit-simple-controller-manager: 0.8.6-0 → 0.8.7-0
  • ros-jade-nodelet: 1.9.8-0 → 1.9.10-0
  • ros-jade-nodelet-core: 1.9.8-0 → 1.9.10-0
  • ros-jade-nodelet-topic-tools: 1.9.8-0 → 1.9.10-0
  • ros-jade-plotjuggler: 0.17.0-0 → 1.0.3-0
  • ros-jade-pluginlib: 1.10.4-0 → 1.10.5-0
  • ros-jade-ros-canopen: 0.7.2-0 → 0.7.4-0
  • ros-jade-rospeex: 2.15.4-0 → 3.0.1-0
  • ros-jade-rospeex-audiomonitor: 2.15.4-0 → 3.0.1-0
  • ros-jade-rospeex-core: 2.15.4-0 → 3.0.1-0
  • ros-jade-rospeex-if: 2.15.4-0 → 3.0.1-0
  • ros-jade-rospeex-launch: 2.15.4-0 → 3.0.1-0
  • ros-jade-rospeex-msgs: 2.15.4-0 → 3.0.1-0
  • ros-jade-rospeex-samples: 2.15.4-0 → 3.0.1-0
  • ros-jade-rospeex-webaudiomonitor: 2.15.4-0 → 3.0.1-0
  • ros-jade-roswww: 0.1.9-0 → 0.1.10-0
  • ros-jade-rqt: 0.2.14-0 → 0.4.8-0
  • ros-jade-rqt-action: 0.4.7-0 → 0.4.8-0
  • ros-jade-rqt-bag: 0.4.7-0 → 0.4.8-0
  • ros-jade-rqt-bag-plugins: 0.4.7-0 → 0.4.8-0
  • ros-jade-rqt-common-plugins: 0.4.7-0 → 0.4.8-0
  • ros-jade-rqt-console: 0.4.7-0 → 0.4.8-0
  • ros-jade-rqt-dep: 0.4.7-0 → 0.4.8-0
  • ros-jade-rqt-graph: 0.4.7-0 → 0.4.8-0
  • ros-jade-rqt-gui: 0.2.14-0 → 0.4.8-0
  • ros-jade-rqt-gui-cpp: 0.2.14-0 → 0.4.8-0
  • ros-jade-rqt-gui-py: 0.2.14-0 → 0.4.8-0
  • ros-jade-rqt-image-view: 0.4.7-0 → 0.4.8-0
  • ros-jade-rqt-launch: 0.4.7-0 → 0.4.8-0
  • ros-jade-rqt-logger-level: 0.4.7-0 → 0.4.8-0
  • ros-jade-rqt-moveit: 0.5.6-0 → 0.5.7-0
  • ros-jade-rqt-msg: 0.4.7-0 → 0.4.8-0
  • ros-jade-rqt-nav-view: 0.5.6-0 → 0.5.7-0
  • ros-jade-rqt-plot: 0.4.7-0 → 0.4.8-0
  • ros-jade-rqt-pose-view: 0.5.6-0 → 0.5.7-0
  • ros-jade-rqt-publisher: 0.4.7-0 → 0.4.8-0
  • ros-jade-rqt-py-common: 0.4.7-0 → 0.4.8-0
  • ros-jade-rqt-py-console: 0.4.7-0 → 0.4.8-0
  • ros-jade-rqt-reconfigure: 0.4.7-0 → 0.4.8-0
  • ros-jade-rqt-robot-dashboard: 0.5.6-0 → 0.5.7-0
  • ros-jade-rqt-robot-monitor: 0.5.6-0 → 0.5.7-0
  • ros-jade-rqt-robot-plugins: 0.5.6-0 → 0.5.7-0
  • ros-jade-rqt-robot-steering: 0.5.6-0 → 0.5.7-0
  • ros-jade-rqt-runtime-monitor: 0.5.6-0 → 0.5.7-0
  • ros-jade-rqt-rviz: 0.5.6-0 → 0.5.7-0
  • ros-jade-rqt-service-caller: 0.4.7-0 → 0.4.8-0
  • ros-jade-rqt-shell: 0.4.7-0 → 0.4.8-0
  • ros-jade-rqt-srv: 0.4.7-0 → 0.4.8-0
  • ros-jade-rqt-tf-tree: 0.5.6-0 → 0.5.7-0
  • ros-jade-rqt-top: 0.4.7-0 → 0.4.8-0
  • ros-jade-rqt-topic: 0.4.7-0 → 0.4.8-0
  • ros-jade-rqt-web: 0.4.7-0 → 0.4.8-0
  • ros-jade-self-test: 1.8.10-0 → 1.9.0-0
  • ros-jade-smclib: 1.7.18-0 → 1.7.19-0
  • ros-jade-socketcan-bridge: 0.7.2-0 → 0.7.4-0
  • ros-jade-socketcan-interface: 0.7.2-0 → 0.7.4-0
  • ros-jade-stereo-image-proc: 1.12.19-0 → 1.12.20-0
  • ros-jade-swri-console-util: 0.1.6-0 → 0.1.7-0
  • ros-jade-swri-geometry-util: 0.1.6-0 → 0.1.7-0
  • ros-jade-swri-image-util: 0.1.6-0 → 0.1.7-0
  • ros-jade-swri-math-util: 0.1.6-0 → 0.1.7-0
  • ros-jade-swri-nodelet: 0.1.6-0 → 0.1.7-0
  • ros-jade-swri-opencv-util: 0.1.6-0 → 0.1.7-0
  • ros-jade-swri-prefix-tools: 0.1.6-0 → 0.1.7-0
  • ros-jade-swri-roscpp: 0.1.6-0 → 0.1.7-0
  • ros-jade-swri-route-util: 0.1.6-0 → 0.1.7-0
  • ros-jade-swri-serial-util: 0.1.6-0 → 0.1.7-0
  • ros-jade-swri-string-util: 0.1.6-0 → 0.1.7-0
  • ros-jade-swri-system-util: 0.1.6-0 → 0.1.7-0
  • ros-jade-swri-transform-util: 0.1.6-0 → 0.1.7-0
  • ros-jade-swri-yaml-util: 0.1.6-0 → 0.1.7-0
  • ros-jade-test-diagnostic-aggregator: 1.8.10-0 → 1.9.0-0
  • ros-jade-urdf-tutorial: 0.2.4-0 → 0.2.5-0
  • ros-jade-xsens-driver: 2.0.1-0 → 2.1.0-0
Removed Packages [0]:
  • Aaron Blasdel
  • AlexV
  • Austin Hendrix
  • Brice Rebsamen
  • Dan Lazewatsky
  • Dave Coleman
  • David V. Lu!!
  • Davide Faconti
  • Dirk Thomas
  • Dorian Scholz
  • Elliot Johnson
  • Fadri Furrer
  • Francis Colas
  • Georg Heppner
  • Guillaume Autran
  • Ioan Sucan
  • Isaac I. Y. Saito
  • Isaac I.Y. Saito
  • Isaac Saito
  • Jack O’Quin
  • Komei Sugiura
  • Kris Kozak
  • Louise Poubel
  • Marc Alban
  • Mathias Lüdtke
  • Michael Ferguson
  • Mikael Arguedas
  • Noda Shintaro
  • Pavel Vechersky
  • Ryohei Ueda
  • Sachin Chitta
  • Scott K Logan
  • Shunichi Nozawa
  • Vincent Rabaud
  • furuta
  • nozawa
