Hello everyone,
We have just synced many updated and new packages to Jade.
Thanks for everyone’s help. The list of new packages and contributors follow.
Your ROS Release Team
Updates to Jade
Added Packages [147]:
- ros-jade-actionlib-lisp: 0.2.8-0
- ros-jade-auv-msgs: 0.0.1-0
- ros-jade-axcli: 0.1.0-0
- ros-jade-catkin-pip: 0.1.11-0
- ros-jade-cl-tf: 0.2.8-0
- ros-jade-cl-tf2: 0.2.8-0
- ros-jade-cl-transforms: 0.2.8-0
- ros-jade-cl-transforms-stamped: 0.2.8-0
- ros-jade-cl-urdf: 0.2.8-0
- ros-jade-cl-utils: 0.2.8-0
- ros-jade-explore-lite: 1.0.0-0
- ros-jade-force-torque-sensor-calib: 1.1.0-0
- ros-jade-force-torque-tools: 1.1.0-0
- ros-jade-fzi-icl-can: 1.0.9-0
- ros-jade-fzi-icl-core: 1.0.4-0
- ros-jade-gazebo-ros-control: 2.6.0-0
- ros-jade-gl-dependency: 1.0.0-0
- ros-jade-grid-map-cv: 1.4.0-0
- ros-jade-grid-map-ros: 1.4.0-0
- ros-jade-grid-map-rviz-plugin: 1.4.0-0
- ros-jade-hakuto: 0.1.8-0
- ros-jade-hrpsys: 315.9.0-0
- ros-jade-hrpsys-ros-bridge: 1.3.2-0
- ros-jade-hrpsys-tools: 1.3.2-0
- ros-jade-image-publisher: 1.12.19-0
- ros-jade-imagesift: 0.3.21-0
- ros-jade-imu-complementary-filter: 1.1.0-0
- ros-jade-imu-filter-madgwick: 1.1.0-0
- ros-jade-imu-tools: 1.1.0-0
- ros-jade-industrial-core: 0.5.0-0
- ros-jade-industrial-deprecated: 0.5.0-0
- ros-jade-industrial-msgs: 0.5.0-0
- ros-jade-industrial-robot-client: 0.5.0-0
- ros-jade-industrial-robot-simulator: 0.5.0-0
- ros-jade-industrial-trajectory-filters: 0.5.0-0
- ros-jade-industrial-utils: 0.5.0-0
- ros-jade-jsk-pcl-ros: 0.3.21-0
- ros-jade-jsk-perception: 0.3.21-0
- ros-jade-jsk-pr2eus: 0.3.4-0
- ros-jade-jsk-recognition: 0.3.21-0
- ros-jade-katana: 1.0.5-0
- ros-jade-katana-arm-gazebo: 1.0.5-0
- ros-jade-katana-description: 1.0.5-0
- ros-jade-katana-driver: 1.0.5-0
- ros-jade-katana-gazebo-plugins: 1.0.5-0
- ros-jade-katana-moveit-ikfast-plugin: 1.0.5-0
- ros-jade-katana-msgs: 1.0.5-0
- ros-jade-katana-teleop: 1.0.5-0
- ros-jade-katana-tutorials: 1.0.5-0
- ros-jade-kdl-parser-py: 1.11.11-0
- ros-jade-kni: 1.0.5-0
- ros-jade-laser-scan-publisher-tutorial: 0.2.3-0
- ros-jade-moveit: 0.8.3-0
- ros-jade-moveit-commander: 0.8.3-0
- ros-jade-moveit-controller-manager-example: 0.8.3-0
- ros-jade-moveit-ikfast: 3.2.0-0
- ros-jade-moveit-ros: 0.8.3-0
- ros-jade-moveit-ros-benchmarks: 0.8.3-0
- ros-jade-moveit-ros-benchmarks-gui: 0.8.3-0
- ros-jade-moveit-ros-control-interface: 0.8.3-0
- ros-jade-moveit-ros-planning-interface: 0.8.3-0
- ros-jade-moveit-ros-visualization: 0.8.3-0
- ros-jade-moveit-ros-warehouse: 0.8.3-0
- ros-jade-moveit-setup-assistant: 0.8.3-0
- ros-jade-mrpt-ekf-slam-2d: 0.1.1-0
- ros-jade-mrpt-ekf-slam-3d: 0.1.1-0
- ros-jade-mrpt-icp-slam-2d: 0.1.1-0
- ros-jade-multirobot-map-merge: 1.0.0-0
- ros-jade-nao-moveit-config: 0.0.9-0
- ros-jade-nav-pcontroller: 0.1.2-0
- ros-jade-navigation-layers: 0.3.1-0
- ros-jade-navigation-stage: 0.2.3-0
- ros-jade-navigation-tutorials: 0.2.3-0
- ros-jade-octomap-rviz-plugins: 0.1.0-0
- ros-jade-odometry-publisher-tutorial: 0.2.3-0
- ros-jade-open-karto: 1.1.3-1
- ros-jade-openrtm-ros-bridge: 1.3.2-0
- ros-jade-openrtm-tools: 1.3.2-0
- ros-jade-p2os-urdf: 2.0.5-0
- ros-jade-parrot-arsdk: 3.9.1-3
- ros-jade-pepper-moveit-config: 0.0.5-0
- ros-jade-point-cloud-publisher-tutorial: 0.2.3-0
- ros-jade-pr2-arm-kinematics: 1.0.8-0
- ros-jade-pr2-kinematics: 1.0.8-0
- ros-jade-pr2eus: 0.3.4-0
- ros-jade-pr2eus-moveit: 0.3.4-0
- ros-jade-pr2eus-tutorials: 0.3.4-0
- ros-jade-pugixml: 1.7.1-0
- ros-jade-pyros-config: 0.1.2-0
- ros-jade-pyros-test: 0.0.4-0
- ros-jade-pyros-utils: 0.1.2-0
- ros-jade-pyzmp: 0.0.14-0
- ros-jade-qwt-dependency: 1.0.1-0
- ros-jade-range-sensor-layer: 0.3.1-0
- ros-jade-razor-imu-9dof: 1.1.1-0
- ros-jade-robot-setup-tf-tutorial: 0.2.3-0
- ros-jade-romeo-moveit-config: 0.2.7-0
- ros-jade-roomba-stage: 0.2.3-0
- ros-jade-ros-numpy: 0.0.2-0
- ros-jade-roslisp-common: 0.2.8-0
- ros-jade-roslisp-utilities: 0.2.8-0
- ros-jade-rosnode-rtc: 1.3.2-0
- ros-jade-rosserial-mbed: 0.7.3-0
- ros-jade-rosserial-tivac: 0.7.3-0
- ros-jade-rplidar-ros: 1.5.5-0
- ros-jade-rqt-launchtree: 0.1.4-0
- ros-jade-rqt-multiplot: 0.0.5-1
- ros-jade-rqt-stream-manipulator-3d: 0.1.6-0
- ros-jade-rtmbuild: 1.3.2-0
- ros-jade-rtmros-common: 1.3.2-0
- ros-jade-rviz-imu-plugin: 1.1.0-0
- ros-jade-schunk-canopen-driver: 1.0.6-0
- ros-jade-simple-grasping: 0.2.2-0
- ros-jade-simple-message: 0.5.0-0
- ros-jade-simple-navigation-goals-tutorial: 0.2.3-0
- ros-jade-slam-karto: 0.7.3-0
- ros-jade-social-navigation-layers: 0.3.1-0
- ros-jade-sparse-bundle-adjustment: 0.3.2-0
- ros-jade-stdr-gui: 0.3.1-0
- ros-jade-stdr-launchers: 0.3.1-0
- ros-jade-stdr-msgs: 0.3.1-0
- ros-jade-stdr-parser: 0.3.1-0
- ros-jade-stdr-resources: 0.3.1-0
- ros-jade-stdr-robot: 0.3.1-0
- ros-jade-stdr-samples: 0.3.1-0
- ros-jade-stdr-server: 0.3.1-0
- ros-jade-stdr-simulator: 0.3.1-0
- ros-jade-stream-manipulator-3d: 0.1.6-0
- ros-jade-swri-nodelet: 0.1.5-0
- ros-jade-swri-route-util: 0.1.5-0
- ros-jade-teb-local-planner-tutorials: 0.0.2-0
- ros-jade-tetris-description: 0.1.8-0
- ros-jade-tetris-gazebo: 0.1.8-0
- ros-jade-tetris-launch: 0.1.8-0
- ros-jade-trac-ik: 1.4.3-0
- ros-jade-trac-ik-examples: 1.4.3-0
- ros-jade-trac-ik-kinematics-plugin: 1.4.3-0
- ros-jade-trac-ik-lib: 1.4.3-0
- ros-jade-uavc-v4lctl: 1.0.3-1
- ros-jade-variant: 0.1.3-0
- ros-jade-variant-msgs: 0.1.3-0
- ros-jade-variant-topic-test: 0.1.3-0
- ros-jade-variant-topic-tools: 0.1.3-0
- ros-jade-warehouse-ros: 0.9.0-0
- ros-jade-wireless-msgs: 0.0.7-0
- ros-jade-wireless-watcher: 0.0.7-0
- ros-jade-xsens-driver: 2.0.1-0
Updated Packages [449]:
- ros-jade-actionlib: 1.11.4-0 → 1.11.6-0
- ros-jade-actionlib-msgs: 1.12.3-0 → 1.12.4-0
- ros-jade-assimp-devel: 2.0.13-0 → 2.0.14-0
- ros-jade-audio-capture: 0.2.10-0 → 0.2.12-0
- ros-jade-audio-common: 0.2.10-0 → 0.2.12-0
- ros-jade-audio-common-msgs: 0.2.10-0 → 0.2.12-0
- ros-jade-audio-play: 0.2.10-0 → 0.2.12-0
- ros-jade-bayesian-belief-networks: 2.0.13-0 → 2.0.14-0
- ros-jade-bond: 1.7.16-0 → 1.7.17-0
- ros-jade-bond-core: 1.7.16-0 → 1.7.17-0
- ros-jade-bondcpp: 1.7.16-0 → 1.7.17-0
- ros-jade-bondpy: 1.7.16-0 → 1.7.17-0
- ros-jade-calibration: 0.10.13-0 → 0.10.14-0
- ros-jade-calibration-estimation: 0.10.13-0 → 0.10.14-0
- ros-jade-calibration-launch: 0.10.13-0 → 0.10.14-0
- ros-jade-calibration-msgs: 0.10.13-0 → 0.10.14-0
- ros-jade-calibration-setup-helper: 0.10.13-0 → 0.10.14-0
- ros-jade-camera-calibration: 1.12.15-0 → 1.12.19-0
- ros-jade-catkin: 0.6.16-0 → 0.6.18-0
- ros-jade-checkerboard-detector: 0.3.15-1 → 0.3.21-0
- ros-jade-class-loader: 0.3.2-0 → 0.3.4-0
- ros-jade-collada-parser: 1.11.8-0 → 1.11.11-0
- ros-jade-collada-urdf: 1.11.8-0 → 1.11.11-0
- ros-jade-collada-urdf-jsk-patch: 2.0.13-0 → 2.0.14-0
- ros-jade-common-msgs: 1.12.3-0 → 1.12.4-0
- ros-jade-cpp-common: 0.5.6-0 → 0.5.7-0
- ros-jade-cv-backports: 0.1.3-0 → 0.1.4-0
- ros-jade-cv-bridge: 1.11.11-0 → 1.11.13-0
- ros-jade-default-cfg-fkie: 0.4.4-0 → 0.5.4-0
- ros-jade-depth-image-proc: 1.12.15-0 → 1.12.19-0
- ros-jade-diagnostic-aggregator: 1.8.7-0 → 1.8.10-0
- ros-jade-diagnostic-analysis: 1.8.7-0 → 1.8.10-0
- ros-jade-diagnostic-common-diagnostics: 1.8.7-0 → 1.8.10-0
- ros-jade-diagnostic-msgs: 1.12.3-0 → 1.12.4-0
- ros-jade-diagnostic-updater: 1.8.7-0 → 1.8.10-0
- ros-jade-diagnostics: 1.8.7-0 → 1.8.10-0
- ros-jade-downward: 2.0.13-0 → 2.0.14-0
- ros-jade-dynamic-reconfigure: 1.5.39-2 → 1.5.44-0
- ros-jade-dynamic-tf-publisher: 2.0.9-1 → 2.0.17-0
- ros-jade-dynpick-driver: 0.0.8-0 → 0.0.11-0
- ros-jade-ecto: 0.6.11-0 → 0.6.12-0
- ros-jade-ecto-opencv: 0.6.1-0 → 0.6.2-0
- ros-jade-eigen-conversions: 1.11.7-0 → 1.11.8-0
- ros-jade-eus-assimp: 0.2.3-0 → 0.2.4-0
- ros-jade-euscollada: 0.2.3-0 → 0.2.4-0
- ros-jade-euslisp: 9.16.0-0 → 9.20.0-0
- ros-jade-eusurdf: 0.2.3-0 → 0.2.4-0
- ros-jade-fcl: 0.3.2-1 → 0.3.3-0
- ros-jade-ff: 2.0.13-0 → 2.0.14-0
- ros-jade-ffha: 2.0.13-0 → 2.0.14-0
- ros-jade-gazebo-msgs: 2.5.1-0 → 2.6.0-0
- ros-jade-gazebo-plugins: 2.5.1-0 → 2.6.0-0
- ros-jade-gazebo-ros: 2.5.1-0 → 2.6.0-0
- ros-jade-gazebo-ros-pkgs: 2.5.1-0 → 2.6.0-0
- ros-jade-gencpp: 0.5.3-0 → 0.5.5-0
- ros-jade-geneus: 2.2.4-0 → 2.2.5-0
- ros-jade-genmsg: 0.5.6-0 → 0.5.7-0
- ros-jade-genpy: 0.5.7-0 → 0.5.10-0
- ros-jade-geometric-shapes: 0.4.3-0 → 0.4.4-0
- ros-jade-geometry: 1.11.7-0 → 1.11.8-0
- ros-jade-geometry-experimental: 0.5.12-0 → 0.5.13-0
- ros-jade-geometry-msgs: 1.12.3-0 → 1.12.4-0
- ros-jade-graspdb: 1.1.7-0 → 1.1.9-0
- ros-jade-grid-map: 1.1.3-0 → 1.4.0-0
- ros-jade-grid-map-core: 1.1.3-0 → 1.4.0-0
- ros-jade-grid-map-demos: 1.1.3-0 → 1.4.0-0
- ros-jade-grid-map-filters: 1.1.3-0 → 1.4.0-0
- ros-jade-grid-map-loader: 1.1.3-0 → 1.4.0-0
- ros-jade-grid-map-msgs: 1.1.3-0 → 1.4.0-0
- ros-jade-grid-map-visualization: 1.1.3-0 → 1.4.0-0
- ros-jade-hector-components-description: 0.4.1-0 → 0.4.2-0
- ros-jade-hector-compressed-map-transport: 0.3.4-0 → 0.3.5-0
- ros-jade-hector-gazebo: 0.4.0-0 → 0.4.1-0
- ros-jade-hector-gazebo-plugins: 0.4.0-0 → 0.4.1-0
- ros-jade-hector-gazebo-thermal-camera: 0.4.0-0 → 0.4.1-0
- ros-jade-hector-gazebo-worlds: 0.4.0-0 → 0.4.1-0
- ros-jade-hector-geotiff: 0.3.4-0 → 0.3.5-0
- ros-jade-hector-geotiff-plugins: 0.3.4-0 → 0.3.5-0
- ros-jade-hector-imu-attitude-to-tf: 0.3.4-0 → 0.3.5-0
- ros-jade-hector-imu-tools: 0.3.4-0 → 0.3.5-0
- ros-jade-hector-map-server: 0.3.4-0 → 0.3.5-0
- ros-jade-hector-map-tools: 0.3.4-0 → 0.3.5-0
- ros-jade-hector-mapping: 0.3.4-0 → 0.3.5-0
- ros-jade-hector-marker-drawing: 0.3.4-0 → 0.3.5-0
- ros-jade-hector-models: 0.4.1-0 → 0.4.2-0
- ros-jade-hector-nav-msgs: 0.3.4-0 → 0.3.5-0
- ros-jade-hector-sensors-description: 0.4.1-0 → 0.4.2-0
- ros-jade-hector-sensors-gazebo: 0.4.0-0 → 0.4.1-0
- ros-jade-hector-slam: 0.3.4-0 → 0.3.5-0
- ros-jade-hector-slam-launch: 0.3.4-0 → 0.3.5-0
- ros-jade-hector-trajectory-server: 0.3.4-0 → 0.3.5-0
- ros-jade-hector-xacro-tools: 0.4.1-0 → 0.4.2-0
- ros-jade-household-objects-database-msgs: 0.1.1-0 → 0.1.2-0
- ros-jade-image-cb-detector: 0.10.13-0 → 0.10.14-0
- ros-jade-image-geometry: 1.11.11-0 → 1.11.13-0
- ros-jade-image-pipeline: 1.12.15-0 → 1.12.19-0
- ros-jade-image-proc: 1.12.15-0 → 1.12.19-0
- ros-jade-image-rotate: 1.12.15-0 → 1.12.19-0
- ros-jade-image-view: 1.12.15-0 → 1.12.19-0
- ros-jade-image-view2: 2.0.9-1 → 2.0.17-0
- ros-jade-interval-intersection: 0.10.13-0 → 0.10.14-0
- ros-jade-joint-state-publisher: 1.11.8-0 → 1.11.11-0
- ros-jade-joint-states-settler: 0.10.13-0 → 0.10.14-0
- ros-jade-joy-teleop: 0.2.1-0 → 0.2.3-0
- ros-jade-jsk-3rdparty: 2.0.13-0 → 2.0.14-0
- ros-jade-jsk-common: 2.0.9-1 → 2.0.17-0
- ros-jade-jsk-common-msgs: 2.0.1-0 → 3.0.0-0
- ros-jade-jsk-data: 2.0.9-1 → 2.0.17-0
- ros-jade-jsk-footstep-msgs: 2.0.1-0 → 3.0.0-0
- ros-jade-jsk-gui-msgs: 2.0.1-0 → 3.0.0-0
- ros-jade-jsk-hark-msgs: 2.0.1-0 → 3.0.0-0
- ros-jade-jsk-model-tools: 0.2.3-0 → 0.2.4-0
- ros-jade-jsk-network-tools: 2.0.9-1 → 2.0.17-0
- ros-jade-jsk-pcl-ros-utils: 0.3.15-1 → 0.3.21-0
- ros-jade-jsk-recognition-msgs: 0.3.15-1 → 0.3.21-0
- ros-jade-jsk-recognition-utils: 0.3.15-1 → 0.3.21-0
- ros-jade-jsk-roseus: 1.4.1-0 → 1.5.3-0
- ros-jade-jsk-tilt-laser: 2.0.9-1 → 2.0.17-0
- ros-jade-jsk-tools: 2.0.9-1 → 2.0.17-0
- ros-jade-jsk-topic-tools: 2.0.9-1 → 2.0.17-0
- ros-jade-jskeus: 1.0.11-0 → 1.0.13-1
- ros-jade-julius: 2.0.13-0 → 2.0.14-0
- ros-jade-kdl-conversions: 1.11.7-0 → 1.11.8-0
- ros-jade-kdl-parser: 1.11.8-0 → 1.11.11-0
- ros-jade-key-teleop: 0.2.1-0 → 0.2.3-0
- ros-jade-laser-cb-detector: 0.10.13-0 → 0.10.14-0
- ros-jade-laser-filters: 1.8.0-1 → 1.8.1-0
- ros-jade-leap-motion: 0.0.9-0 → 0.0.10-0
- ros-jade-libcmt: 2.0.13-0 → 2.0.14-0
- ros-jade-libg2o: 2015.5.19-1 → 2015.5.19-2
- ros-jade-libmavconn: 0.16.6-0 → 0.17.4-0
- ros-jade-libsiftfast: 2.0.13-0 → 2.0.14-0
- ros-jade-lms1xx: 0.1.4-0 → 0.1.5-0
- ros-jade-log4cpp: 2.8.1-0 → 2.8.3-0
- ros-jade-lyap-control: 0.0.12-0 → 0.0.13-0
- ros-jade-mapviz: 0.1.2-0 → 0.1.3-0
- ros-jade-mapviz-plugins: 0.1.2-0 → 0.1.3-0
- ros-jade-marti-can-msgs: 0.0.1-0 → 0.0.4-0
- ros-jade-marti-common-msgs: 0.0.1-0 → 0.0.4-0
- ros-jade-marti-data-structures: 0.1.2-0 → 0.1.5-0
- ros-jade-marti-nav-msgs: 0.0.1-0 → 0.0.4-0
- ros-jade-marti-perception-msgs: 0.0.1-0 → 0.0.4-0
- ros-jade-marti-sensor-msgs: 0.0.1-0 → 0.0.4-0
- ros-jade-marti-visualization-msgs: 0.0.1-0 → 0.0.4-0
- ros-jade-master-discovery-fkie: 0.4.4-0 → 0.5.4-0
- ros-jade-master-sync-fkie: 0.4.4-0 → 0.5.4-0
- ros-jade-mavlink: 2016.2.5-0 → 2016.5.20-0
- ros-jade-mavros: 0.16.6-0 → 0.17.4-0
- ros-jade-mavros-extras: 0.16.6-0 → 0.17.4-0
- ros-jade-mavros-msgs: 0.16.6-0 → 0.17.4-0
- ros-jade-message-filters: 1.11.16-0 → 1.11.20-0
- ros-jade-mini-maxwell: 2.0.13-0 → 2.0.14-0
- ros-jade-mk: 1.12.5-0 → 1.12.7-0
- ros-jade-monocam-settler: 0.10.13-0 → 0.10.14-0
- ros-jade-mouse-teleop: 0.2.1-0 → 0.2.3-0
- ros-jade-moveit-core: 0.6.15-0 → 0.8.3-0
- ros-jade-moveit-fake-controller-manager: 0.5.6-0 → 0.8.3-0
- ros-jade-moveit-msgs: 0.6.1-0 → 0.8.3-0
- ros-jade-moveit-planners: 0.6.7-0 → 0.8.3-0
- ros-jade-moveit-planners-ompl: 0.6.7-0 → 0.8.3-0
- ros-jade-moveit-plugins: 0.5.6-0 → 0.8.3-0
- ros-jade-moveit-ros-manipulation: 0.6.5-0 → 0.8.3-0
- ros-jade-moveit-ros-move-group: 0.6.5-0 → 0.8.3-0
- ros-jade-moveit-ros-perception: 0.6.5-0 → 0.8.3-0
- ros-jade-moveit-ros-planning: 0.6.5-0 → 0.8.3-0
- ros-jade-moveit-ros-robot-interaction: 0.6.5-0 → 0.8.3-0
- ros-jade-moveit-sim-controller: 0.0.4-0 → 0.0.5-0
- ros-jade-moveit-simple-controller-manager: 0.5.6-0 → 0.8.3-0
- ros-jade-moveit-visual-tools: 3.0.2-0 → 3.1.0-0
- ros-jade-mrpt-bridge: 0.1.5-0 → 0.1.11-0
- ros-jade-mrpt-local-obstacles: 0.1.5-0 → 0.1.11-0
- ros-jade-mrpt-localization: 0.1.5-0 → 0.1.11-0
- ros-jade-mrpt-map: 0.1.5-0 → 0.1.11-0
- ros-jade-mrpt-msgs: 0.1.5-0 → 0.1.11-0
- ros-jade-mrpt-navigation: 0.1.5-0 → 0.1.11-0
- ros-jade-mrpt-rawlog: 0.1.5-0 → 0.1.11-0
- ros-jade-mrpt-reactivenav2d: 0.1.5-0 → 0.1.11-0
- ros-jade-mrpt-tutorials: 0.1.5-0 → 0.1.11-0
- ros-jade-multi-map-server: 2.0.9-1 → 2.0.17-0
- ros-jade-multimaster-fkie: 0.4.4-0 → 0.5.4-0
- ros-jade-multimaster-msgs-fkie: 0.4.4-0 → 0.5.4-0
- ros-jade-multires-image: 0.1.2-0 → 0.1.3-0
- ros-jade-multisense: 3.4.6-0 → 3.4.7-0
- ros-jade-multisense-bringup: 3.4.6-0 → 3.4.7-0
- ros-jade-multisense-cal-check: 3.4.6-0 → 3.4.7-0
- ros-jade-multisense-description: 3.4.6-0 → 3.4.7-0
- ros-jade-multisense-lib: 3.4.6-0 → 3.4.7-0
- ros-jade-multisense-ros: 3.4.6-0 → 3.4.7-0
- ros-jade-nav-msgs: 1.12.3-0 → 1.12.4-0
- ros-jade-nav2d: 0.1.4-0 → 0.3.0-0
- ros-jade-nav2d-exploration: 0.1.4-0 → 0.3.0-0
- ros-jade-nav2d-karto: 0.1.4-0 → 0.3.0-0
- ros-jade-nav2d-localizer: 0.1.4-0 → 0.3.0-0
- ros-jade-nav2d-msgs: 0.1.4-0 → 0.3.0-0
- ros-jade-nav2d-navigator: 0.1.4-0 → 0.3.0-0
- ros-jade-nav2d-operator: 0.1.4-0 → 0.3.0-0
- ros-jade-nav2d-remote: 0.1.4-0 → 0.3.0-0
- ros-jade-nav2d-tutorials: 0.1.4-0 → 0.3.0-0
- ros-jade-nerian-sp1: 1.2.1-0 → 1.3.3-0
- ros-jade-nlopt: 2.0.13-0 → 2.0.14-0
- ros-jade-node-manager-fkie: 0.4.4-0 → 0.5.4-0
- ros-jade-nodelet: 1.9.3-0 → 1.9.5-0
- ros-jade-nodelet-core: 1.9.3-0 → 1.9.5-0
- ros-jade-nodelet-topic-tools: 1.9.3-0 → 1.9.5-0
- ros-jade-ntpd-driver: 1.2.0-0 → 1.2.0-1
- ros-jade-object-recognition-capture: 0.3.0-0 → 0.3.1-0
- ros-jade-object-recognition-reconstruction: 0.3.5-0 → 0.3.6-0
- ros-jade-object-recognition-ros-visualization: 0.3.7-0 → 0.3.9-0
- ros-jade-ocl: 2.8.1-0 → 2.8.3-0
- ros-jade-octomap-mapping: 0.5.3-0 → 0.6.0-0
- ros-jade-octomap-msgs: 0.3.2-0 → 0.3.3-0
- ros-jade-octomap-server: 0.5.3-0 → 0.6.0-0
- ros-jade-ompl: 1.0.0003094-2 → 1.0.3094-0
- ros-jade-opencv-apps: 1.11.11-0 → 1.11.13-0
- ros-jade-openni-camera: 1.9.4-0 → 1.9.5-0
- ros-jade-openni-launch: 1.9.7-0 → 1.9.8-0
- ros-jade-openni2-camera: 0.2.5-0 → 0.2.7-0
- ros-jade-openrtm-aist: 1.1.0-1 → 1.1.0-2
- ros-jade-opt-camera: 2.0.13-0 → 2.0.14-0
- ros-jade-orocos-kdl: 1.3.0-0 → 1.3.1-0
- ros-jade-orocos-kinematics-dynamics: 1.3.0-0 → 1.3.1-0
- ros-jade-p2os-doc: 2.0.3-0 → 2.0.5-0
- ros-jade-p2os-driver: 2.0.3-0 → 2.0.5-0
- ros-jade-p2os-launch: 2.0.3-0 → 2.0.5-0
- ros-jade-p2os-msgs: 2.0.3-0 → 2.0.5-0
- ros-jade-p2os-teleop: 2.0.3-0 → 2.0.5-0
- ros-jade-pepper-meshes: 0.2.2-0 → 0.2.3-0
- ros-jade-pgm-learner: 2.0.13-0 → 2.0.14-0
- ros-jade-pid: 0.0.13-0 → 0.0.17-0
- ros-jade-pluginlib: 1.10.1-0 → 1.10.3-0
- ros-jade-posedetection-msgs: 2.0.1-0 → 3.0.0-0
- ros-jade-python-orocos-kdl: 1.3.0-0 → 1.3.1-0
- ros-jade-python-qt-binding: 0.2.17-0 → 0.2.19-0
- ros-jade-qt-dotgraph: 0.2.29-0 → 0.2.30-0
- ros-jade-qt-gui: 0.2.29-0 → 0.2.30-0
- ros-jade-qt-gui-app: 0.2.29-0 → 0.2.30-0
- ros-jade-qt-gui-core: 0.2.29-0 → 0.2.30-0
- ros-jade-qt-gui-cpp: 0.2.29-0 → 0.2.30-0
- ros-jade-qt-gui-py-common: 0.2.29-0 → 0.2.30-0
- ros-jade-rail-collada-models: 0.0.4-0 → 0.0.5-0
- ros-jade-rail-grasp-collection: 1.1.7-0 → 1.1.9-0
- ros-jade-rail-manipulation-msgs: 0.0.7-0 → 0.0.8-0
- ros-jade-rail-pick-and-place: 1.1.7-0 → 1.1.9-0
- ros-jade-rail-pick-and-place-msgs: 1.1.7-0 → 1.1.9-0
- ros-jade-rail-pick-and-place-tools: 1.1.7-0 → 1.1.9-0
- ros-jade-rail-recognition: 1.1.7-0 → 1.1.9-0
- ros-jade-rail-segmentation: 0.1.8-0 → 0.1.9-0
- ros-jade-resized-image-transport: 0.3.15-1 → 0.3.21-0
- ros-jade-rgbd-launch: 2.2.0-0 → 2.2.1-0
- ros-jade-robot-localization: 2.2.2-0 → 2.3.0-0
- ros-jade-robot-model: 1.11.8-0 → 1.11.11-0
- ros-jade-robot-state-publisher: 1.12.0-0 → 1.12.2-0
- ros-jade-romeo-bringup: 0.1.3-0 → 0.1.3-1
- ros-jade-romeo-description: 0.1.3-0 → 0.1.3-1
- ros-jade-romeo-robot: 0.1.3-0 → 0.1.3-1
- ros-jade-romeo-sensors-py: 0.1.3-0 → 0.1.3-1
- ros-jade-ros: 1.12.5-0 → 1.12.7-0
- ros-jade-ros-comm: 1.11.16-0 → 1.11.20-0
- ros-jade-ros-control-boilerplate: 0.3.0-0 → 0.3.1-0
- ros-jade-ros-emacs-utils: 0.4.9-0 → 0.4.10-0
- ros-jade-ros-tutorials: 0.6.1-0 → 0.6.2-0
- ros-jade-rosapi: 0.7.13-0 → 0.7.15-0
- ros-jade-rosbag: 1.11.16-0 → 1.11.20-0
- ros-jade-rosbag-storage: 1.11.16-0 → 1.11.20-0
- ros-jade-rosbash: 1.12.5-0 → 1.12.7-0
- ros-jade-rosboost-cfg: 1.12.5-0 → 1.12.7-0
- ros-jade-rosbridge-library: 0.7.13-0 → 0.7.15-0
- ros-jade-rosbridge-server: 0.7.13-0 → 0.7.15-0
- ros-jade-rosbridge-suite: 0.7.13-0 → 0.7.15-0
- ros-jade-rosbuild: 1.12.5-0 → 1.12.7-0
- ros-jade-rosclean: 1.12.5-0 → 1.12.7-0
- ros-jade-rosconsole: 1.11.16-0 → 1.11.20-0
- ros-jade-rosconsole-bridge: 0.4.2-0 → 0.4.4-0
- ros-jade-roscpp: 1.11.16-0 → 1.11.20-0
- ros-jade-roscpp-core: 0.5.6-0 → 0.5.7-0
- ros-jade-roscpp-serialization: 0.5.6-0 → 0.5.7-0
- ros-jade-roscpp-traits: 0.5.6-0 → 0.5.7-0
- ros-jade-roscpp-tutorials: 0.6.1-0 → 0.6.2-0
- ros-jade-roscreate: 1.12.5-0 → 1.12.7-0
- ros-jade-rosdoc-lite: 0.2.5-0 → 0.2.6-0
- ros-jade-rosemacs: 0.4.9-0 → 0.4.10-0
- ros-jade-roseus: 1.4.1-0 → 1.5.3-0
- ros-jade-roseus-mongo: 1.4.1-0 → 1.5.3-0
- ros-jade-roseus-smach: 1.4.1-0 → 1.5.3-0
- ros-jade-rosgraph: 1.11.16-0 → 1.11.20-0
- ros-jade-rosgraph-msgs: 1.11.1-0 → 1.11.2-0
- ros-jade-roslang: 1.12.5-0 → 1.12.7-0
- ros-jade-roslaunch: 1.11.16-0 → 1.11.20-0
- ros-jade-roslib: 1.12.5-0 → 1.12.7-0
- ros-jade-roslisp: 1.9.19-0 → 1.9.20-0
- ros-jade-roslisp-repl: 0.4.9-0 → 0.4.10-0
- ros-jade-roslz4: 1.11.16-0 → 1.11.20-0
- ros-jade-rosmake: 1.12.5-0 → 1.12.7-0
- ros-jade-rosmaster: 1.11.16-0 → 1.11.20-0
- ros-jade-rosmsg: 1.11.16-0 → 1.11.20-0
- ros-jade-rosnode: 1.11.16-0 → 1.11.20-0
- ros-jade-rosout: 1.11.16-0 → 1.11.20-0
- ros-jade-rospack: 2.2.5-0 → 2.3.0-0
- ros-jade-rosparam: 1.11.16-0 → 1.11.20-0
- ros-jade-rospatlite: 2.0.13-0 → 2.0.14-0
- ros-jade-rospilot: 1.1.1-0 → 1.2.0-0
- ros-jade-rosping: 2.0.13-0 → 2.0.14-0
- ros-jade-rospy: 1.11.16-0 → 1.11.20-0
- ros-jade-rospy-tutorials: 0.6.1-0 → 0.6.2-0
- ros-jade-rosserial: 0.7.1-0 → 0.7.3-0
- ros-jade-rosserial-arduino: 0.7.1-0 → 0.7.3-0
- ros-jade-rosserial-client: 0.7.1-0 → 0.7.3-0
- ros-jade-rosserial-embeddedlinux: 0.7.1-0 → 0.7.3-0
- ros-jade-rosserial-msgs: 0.7.1-0 → 0.7.3-0
- ros-jade-rosserial-python: 0.7.1-0 → 0.7.3-0
- ros-jade-rosserial-server: 0.7.1-0 → 0.7.3-0
- ros-jade-rosserial-windows: 0.7.1-0 → 0.7.3-0
- ros-jade-rosserial-xbee: 0.7.1-0 → 0.7.3-0
- ros-jade-rosservice: 1.11.16-0 → 1.11.20-0
- ros-jade-rostest: 1.11.16-0 → 1.11.20-0
- ros-jade-rostime: 0.5.6-0 → 0.5.7-0
- ros-jade-rostopic: 1.11.16-0 → 1.11.20-0
- ros-jade-rostwitter: 2.0.13-0 → 2.0.14-0
- ros-jade-rosunit: 1.12.5-0 → 1.12.7-0
- ros-jade-roswtf: 1.11.16-0 → 1.11.20-0
- ros-jade-roswww: 0.1.8-0 → 0.1.9-0
- ros-jade-rqt-action: 0.3.12-0 → 0.3.13-0
- ros-jade-rqt-bag: 0.3.12-0 → 0.3.13-0
- ros-jade-rqt-bag-plugins: 0.3.12-0 → 0.3.13-0
- ros-jade-rqt-common-plugins: 0.3.12-0 → 0.3.13-0
- ros-jade-rqt-console: 0.3.12-0 → 0.3.13-0
- ros-jade-rqt-dep: 0.3.12-0 → 0.3.13-0
- ros-jade-rqt-ez-publisher: 0.3.0-0 → 0.3.2-0
- ros-jade-rqt-graph: 0.3.12-0 → 0.3.13-0
- ros-jade-rqt-image-view: 0.3.12-0 → 0.3.13-0
- ros-jade-rqt-launch: 0.3.12-0 → 0.3.13-0
- ros-jade-rqt-logger-level: 0.3.12-0 → 0.3.13-0
- ros-jade-rqt-moveit: 0.4.2-0 → 0.4.3-0
- ros-jade-rqt-msg: 0.3.12-0 → 0.3.13-0
- ros-jade-rqt-nav-view: 0.4.2-0 → 0.4.3-0
- ros-jade-rqt-plot: 0.3.12-0 → 0.3.13-0
- ros-jade-rqt-pose-view: 0.4.2-0 → 0.4.3-0
- ros-jade-rqt-publisher: 0.3.12-0 → 0.3.13-0
- ros-jade-rqt-py-common: 0.3.12-0 → 0.3.13-0
- ros-jade-rqt-py-console: 0.3.12-0 → 0.3.13-0
- ros-jade-rqt-reconfigure: 0.3.12-0 → 0.3.13-0
- ros-jade-rqt-robot-dashboard: 0.4.2-0 → 0.4.3-0
- ros-jade-rqt-robot-monitor: 0.4.2-0 → 0.4.3-0
- ros-jade-rqt-robot-plugins: 0.4.2-0 → 0.4.3-0
- ros-jade-rqt-robot-steering: 0.4.2-0 → 0.4.3-0
- ros-jade-rqt-runtime-monitor: 0.4.2-0 → 0.4.3-0
- ros-jade-rqt-rviz: 0.4.2-0 → 0.4.3-0
- ros-jade-rqt-service-caller: 0.3.12-0 → 0.3.13-0
- ros-jade-rqt-shell: 0.3.12-0 → 0.3.13-0
- ros-jade-rqt-srv: 0.3.12-0 → 0.3.13-0
- ros-jade-rqt-tf-tree: 0.4.2-0 → 0.4.3-0
- ros-jade-rqt-top: 0.3.12-0 → 0.3.13-0
- ros-jade-rqt-topic: 0.3.12-0 → 0.3.13-0
- ros-jade-rqt-web: 0.3.12-0 → 0.3.13-0
- ros-jade-rtabmap: 0.10.10-0 → 0.11.8-0
- ros-jade-rtabmap-ros: 0.10.10-0 → 0.11.8-0
- ros-jade-rtt: 2.8.1-0 → 2.8.3-0
- ros-jade-rtt-actionlib: 2.8.2-0 → 2.8.3-0
- ros-jade-rtt-actionlib-msgs: 2.8.2-0 → 2.8.3-0
- ros-jade-rtt-common-msgs: 2.8.2-0 → 2.8.3-0
- ros-jade-rtt-diagnostic-msgs: 2.8.2-0 → 2.8.3-0
- ros-jade-rtt-dynamic-reconfigure: 2.8.2-0 → 2.8.3-0
- ros-jade-rtt-geometry-msgs: 2.8.2-0 → 2.8.3-0
- ros-jade-rtt-kdl-conversions: 2.8.2-0 → 2.8.3-0
- ros-jade-rtt-nav-msgs: 2.8.2-0 → 2.8.3-0
- ros-jade-rtt-ros: 2.8.2-0 → 2.8.3-0
- ros-jade-rtt-ros-comm: 2.8.2-0 → 2.8.3-0
- ros-jade-rtt-ros-integration: 2.8.2-0 → 2.8.3-0
- ros-jade-rtt-ros-msgs: 2.8.2-0 → 2.8.3-0
- ros-jade-rtt-rosclock: 2.8.2-0 → 2.8.3-0
- ros-jade-rtt-roscomm: 2.8.2-0 → 2.8.3-0
- ros-jade-rtt-rosdeployment: 2.8.2-0 → 2.8.3-0
- ros-jade-rtt-rosgraph-msgs: 2.8.2-0 → 2.8.3-0
- ros-jade-rtt-rosnode: 2.8.2-0 → 2.8.3-0
- ros-jade-rtt-rospack: 2.8.2-0 → 2.8.3-0
- ros-jade-rtt-rosparam: 2.8.2-0 → 2.8.3-0
- ros-jade-rtt-sensor-msgs: 2.8.2-0 → 2.8.3-0
- ros-jade-rtt-shape-msgs: 2.8.2-0 → 2.8.3-0
- ros-jade-rtt-std-msgs: 2.8.2-0 → 2.8.3-0
- ros-jade-rtt-std-srvs: 2.8.2-0 → 2.8.3-0
- ros-jade-rtt-stereo-msgs: 2.8.2-0 → 2.8.3-0
- ros-jade-rtt-tf: 2.8.2-0 → 2.8.3-0
- ros-jade-rtt-trajectory-msgs: 2.8.2-0 → 2.8.3-0
- ros-jade-rtt-visualization-msgs: 2.8.2-0 → 2.8.3-0
- ros-jade-rviz: 1.11.10-0 → 1.11.14-0
- ros-jade-rviz-visual-tools: 2.0.2-0 → 2.2.0-0
- ros-jade-self-test: 1.8.7-0 → 1.8.10-0
- ros-jade-sensor-msgs: 1.12.3-0 → 1.12.4-0
- ros-jade-settlerlib: 0.10.13-0 → 0.10.14-0
- ros-jade-shape-msgs: 1.12.3-0 → 1.12.4-0
- ros-jade-sick-tim: 0.0.6-0 → 0.0.8-0
- ros-jade-slime-ros: 0.4.9-0 → 0.4.10-0
- ros-jade-slime-wrapper: 0.4.9-0 → 0.4.10-0
- ros-jade-smclib: 1.7.16-0 → 1.7.17-0
- ros-jade-sophus: 0.9.0-0 → 0.9.0-1
- ros-jade-sound-play: 0.2.10-0 → 0.2.12-0
- ros-jade-speech-recognition-msgs: 2.0.1-0 → 3.0.0-0
- ros-jade-srdfdom: 0.2.7-0 → 0.3.1-0
- ros-jade-std-msgs: 0.5.9-0 → 0.5.10-0
- ros-jade-std-srvs: 1.11.1-0 → 1.11.2-0
- ros-jade-stereo-image-proc: 1.12.15-0 → 1.12.19-0
- ros-jade-stereo-msgs: 1.12.3-0 → 1.12.4-0
- ros-jade-swri-console-util: 0.1.2-0 → 0.1.5-0
- ros-jade-swri-geometry-util: 0.1.2-0 → 0.1.5-0
- ros-jade-swri-image-util: 0.1.2-0 → 0.1.5-0
- ros-jade-swri-math-util: 0.1.2-0 → 0.1.5-0
- ros-jade-swri-opencv-util: 0.1.2-0 → 0.1.5-0
- ros-jade-swri-prefix-tools: 0.1.2-0 → 0.1.5-0
- ros-jade-swri-roscpp: 0.1.2-0 → 0.1.5-0
- ros-jade-swri-serial-util: 0.1.2-0 → 0.1.5-0
- ros-jade-swri-string-util: 0.1.2-0 → 0.1.5-0
- ros-jade-swri-system-util: 0.1.2-0 → 0.1.5-0
- ros-jade-swri-transform-util: 0.1.2-0 → 0.1.5-0
- ros-jade-swri-yaml-util: 0.1.2-0 → 0.1.5-0
- ros-jade-teb-local-planner: 0.2.3-0 → 0.5.1-0
- ros-jade-teleop-tools: 0.2.1-0 → 0.2.3-0
- ros-jade-teleop-tools-msgs: 0.2.1-0 → 0.2.3-0
- ros-jade-teleop-twist-keyboard: 0.5.0-0 → 0.6.0-0
- ros-jade-test-diagnostic-aggregator: 1.8.7-0 → 1.8.10-0
- ros-jade-test-mavros: 0.16.6-0 → 0.17.4-0
- ros-jade-tf: 1.11.7-0 → 1.11.8-0
- ros-jade-tf-conversions: 1.11.7-0 → 1.11.8-0
- ros-jade-tf-keyboard-cal: 0.0.5-0 → 0.1.0-0
- ros-jade-tf2: 0.5.12-0 → 0.5.13-0
- ros-jade-tf2-bullet: 0.5.12-0 → 0.5.13-0
- ros-jade-tf2-eigen: 0.5.12-0 → 0.5.13-0
- ros-jade-tf2-geometry-msgs: 0.5.12-0 → 0.5.13-0
- ros-jade-tf2-kdl: 0.5.12-0 → 0.5.13-0
- ros-jade-tf2-msgs: 0.5.12-0 → 0.5.13-0
- ros-jade-tf2-py: 0.5.12-0 → 0.5.13-0
- ros-jade-tf2-ros: 0.5.12-0 → 0.5.13-0
- ros-jade-tf2-sensor-msgs: 0.5.12-0 → 0.5.13-0
- ros-jade-tf2-tools: 0.5.12-0 → 0.5.13-0
- ros-jade-tile-map: 0.1.2-0 → 0.1.3-0
- ros-jade-topic-tools: 1.11.16-0 → 1.11.20-0
- ros-jade-trajectory-msgs: 1.12.3-0 → 1.12.4-0
- ros-jade-turtlesim: 0.6.1-0 → 0.6.2-0
- ros-jade-ueye: 0.0.8-0 → 0.0.10-0
- ros-jade-ueye-cam: 1.0.12-0 → 1.0.14-0
- ros-jade-urdf: 1.11.8-0 → 1.11.11-0
- ros-jade-urdf-parser-plugin: 1.11.8-0 → 1.11.11-0
- ros-jade-urdfdom-py: 0.3.0-1 → 0.3.1-0
- ros-jade-virtual-force-publisher: 2.0.9-1 → 2.0.17-0
- ros-jade-vision-opencv: 1.11.11-0 → 1.11.13-0
- ros-jade-visp: 3.0.0-3 → 3.0.0-4
- ros-jade-visualization-msgs: 1.12.3-0 → 1.12.4-0
- ros-jade-voice-text: 2.0.13-0 → 2.0.14-0
- ros-jade-xacro: 1.10.6-0 → 1.10.7-0
- ros-jade-xmlrpcpp: 1.11.16-0 → 1.11.20-0
Removed Packages [4]:
- ros-jade-romeo-dcm-bringup
- ros-jade-romeo-dcm-control
- ros-jade-romeo-dcm-driver
- ros-jade-romeo-dcm-msgs
Thanks to all ROS maintainers who make packages available to the ROS community.
The above list of packages was made possible by the work of the following maintainers:
- Aaron Blasdel
- AlexV
- Alexander Tiderko
- Andy Zelenak
- Anqi Xu
- Armin Hornung
- Austin Hendrix
- Ben Charrow
- Bence Magyar
- Brice Rebsamen
- Carnegie Robotics
- Chris Zalidis
- Christoph Rösmann
- Christopher Berner
- Dan Lazewatsky
- Daniel Stonier
- Dave Coleman
- David Gossow
- David Kent
- David V. Lu!!
- Devon Ash
- Dirk Thomas
- Dorian Scholz
- Edmond DuPont
- Elliot Johnson
- Enrique Fernandez
- Eric Wieser
- Fabien Spindler
- Florian Lier
- Francis Colas
- Francisco Vina
- G.A. vd. Hoorn
- Gary Servin
- Gayane Kazhoyan
- Georg Bartels
- Georg Heppner
- Henning Deeken
- Hunter Allen
- Ioan Sucan
- Isaac I.Y. Saito
- Isaac Isao Saito
- Isaac Saito
- Jack O’Quin
- Jackie Kay
- Jan Winkler
- Jiri Horner
- Johannes Meyer
- Jon Binney
- Jose Luis
- Jose Luis Blanco Claraco
- Jose Luis Rivero
- Jose Luis Sanchez-Lopez
- Jose-Luis Blanco-Claraco
- Kareem Shehata
- KazutoMurase
- Kei Okada
- Kevin Hallenbeck
- Koji Terada
- Konstantin Schauwecker
- Kris Kozak
- Kristof Robot
- Lorenz Moesenlechner
- Maintained by Carnegie Robotics LLC
- Mani Monajjemi
- Marc Alban
- Markus Bader
- Martin Günther
- Matei Ciocarlie
- Mathias Lüdtke
- Mathieu Labbe
- Matias Valdenegro
- Michael Ferguson
- Mikael Arguedas
- Mike Purvis
- Morgan Quigley
- Natalia Lyubova
- Noda Shintaro
- Orocos Developers
- Patrick Beeson
- Patrick Feuser
- Paul Bouchier
- Paul Mathieu
- Philipp Krüsi
- Philipp Schillinger
- Piyush Khandelwal
- Péter Fankhauser
- Ralf Kaestner
- Roberto G. Valenti
- Ruben Smits
- Russell Toris
- Ryohei Ueda
- Sachin Chitta
- Scott K Logan
- Sebastian Kasperski
- Shaun Edwards
- Shohei Fujii
- Slamtec ROS Maintainer
- Stefan Kohlbrecher
- TORK
- Tabjones
- Takashi Ogura
- Takuya Nakaoka
- Tom Moore
- Tully Foote
- Vincent Rabaud
- Vitor Matos
- Vladimir Ermakov
- William Woodall
- Yohei Kakiuchi
- YoheiKakiuchi
- Youhei Kakiuchi
- Yuki Furuta
- Yuto Inagaki
- heppner
- k-okada
- mikael arguedas
- tabjones
You made it to the bottom, have a
