New Packages for Jade 2017-02-27
We have a large batch of new and updated packages for Jade. We have over 30 new packages released and 275 updated packages included in this sync.
Thank you to everyone who has contributed to these releases through Pull request, individual contributions, opening issues etc! The full details of all the updated packages as well as the list of maintainers who made releases is below.
Package Updates for jade
Added Packages [31]:
  • ros-jade-contact-states-observer: 0.1.11-1
  • ros-jade-eus-nlopt: 0.1.11-1
  • ros-jade-fetch-gazebo: 0.8.0-0
  • ros-jade-fetch-gazebo-demo: 0.8.0-0
  • ros-jade-geometry2: 0.5.15-0
  • ros-jade-idolink-node: 0.1.2-0
  • ros-jade-imu-pipeline: 0.2.2-0
  • ros-jade-imu-processors: 0.2.2-0
  • ros-jade-imu-transformer: 0.2.2-0
  • ros-jade-joy-mouse: 0.1.11-1
  • ros-jade-jsk-calibration: 0.1.11-1
  • ros-jade-jsk-footstep-controller: 0.1.11-1
  • ros-jade-jsk-footstep-planner: 0.1.11-1
  • ros-jade-jsk-ik-server: 0.1.11-1
  • ros-jade-jsk-planning: 0.1.8-2
  • ros-jade-jsk-teleop-joy: 0.1.11-1
  • ros-jade-libphidget21: 0.7.0-0
  • ros-jade-moveit-kinematics: 0.8.5-0
  • ros-jade-moveit-runtime: 0.8.5-0
  • ros-jade-nao-control: 0.0.6-0
  • ros-jade-nao-dcm-bringup: 0.0.4-0
  • ros-jade-pddl-msgs: 0.1.8-2
  • ros-jade-pddl-planner: 0.1.8-2
  • ros-jade-pddl-planner-viewer: 0.1.8-2
  • ros-jade-phidgets-api: 0.7.0-0
  • ros-jade-phidgets-drivers: 0.7.0-0
  • ros-jade-phidgets-imu: 0.7.0-0
  • ros-jade-plotjuggler: 0.11.0-0
  • ros-jade-range-msgs: 1.1.2-0
  • ros-jade-task-compiler: 0.1.8-2
  • ros-jade-um7: 0.0.4-0
Updated Packages [275]:
  • ros-jade-ar-track-alvar: 0.5.4-0 → 0.5.6-0
  • ros-jade-assimp-devel: 2.0.17-0 → 2.0.19-0
  • ros-jade-backports-ssl-match-hostname: 3.5.0-0 → 3.5.0-1
  • ros-jade-bayesian-belief-networks: 2.0.17-0 → 2.0.19-0
  • ros-jade-camera-calibration-parsers: 1.11.11-0 → 1.11.12-0
  • ros-jade-camera-info-manager: 1.11.11-0 → 1.11.12-0
  • ros-jade-catkin-pip: 0.1.16-0 → 0.1.17-0
  • ros-jade-checkerboard-detector: 0.3.29-0 → 1.1.0-0
  • ros-jade-cmake-modules: 0.4.0-0 → 0.4.1-0
  • ros-jade-collada-parser: 1.11.11-0 → 1.11.12-0
  • ros-jade-collada-urdf: 1.11.11-0 → 1.11.12-0
  • ros-jade-collada-urdf-jsk-patch: 2.0.17-0 → 2.0.19-0
  • ros-jade-cv-bridge: 1.11.14-0 → 1.11.15-0
  • ros-jade-default-cfg-fkie: 0.6.2-0 → 0.7.2-0
  • ros-jade-downward: 2.0.17-0 → 2.0.19-0
  • ros-jade-dynamic-tf-publisher: 2.1.2-1 → 2.2.2-0
  • ros-jade-dynamixel-controllers: 0.4.0-0 → 0.4.1-0
  • ros-jade-dynamixel-driver: 0.4.0-0 → 0.4.1-0
  • ros-jade-dynamixel-motor: 0.4.0-0 → 0.4.1-0
  • ros-jade-dynamixel-msgs: 0.4.0-0 → 0.4.1-0
  • ros-jade-dynamixel-tutorials: 0.4.0-0 → 0.4.1-0
  • ros-jade-dynpick-driver: 0.1.0-0 → 0.1.1-0
  • ros-jade-euslisp: 9.21.0-0 → 9.22.0-0
  • ros-jade-ff: 2.0.17-0 → 2.0.19-0
  • ros-jade-ffha: 2.0.17-0 → 2.0.19-0
  • ros-jade-gazebo-msgs: 2.6.1-0 → 2.6.2-0
  • ros-jade-gazebo-plugins: 2.6.1-0 → 2.6.2-0
  • ros-jade-gazebo-ros: 2.6.1-0 → 2.6.2-0
  • ros-jade-gazebo-ros-control: 2.6.1-0 → 2.6.2-0
  • ros-jade-gazebo-ros-pkgs: 2.6.1-0 → 2.6.2-0
  • ros-jade-geometry-experimental: 0.5.13-0 → 0.5.15-0
  • ros-jade-grid-map: 1.4.1-0 → 1.4.2-0
  • ros-jade-grid-map-core: 1.4.1-0 → 1.4.2-0
  • ros-jade-grid-map-cv: 1.4.1-0 → 1.4.2-0
  • ros-jade-grid-map-demos: 1.4.1-0 → 1.4.2-0
  • ros-jade-grid-map-filters: 1.4.1-0 → 1.4.2-0
  • ros-jade-grid-map-loader: 1.4.1-0 → 1.4.2-0
  • ros-jade-grid-map-msgs: 1.4.1-0 → 1.4.2-0
  • ros-jade-grid-map-pcl: 1.4.1-0 → 1.4.2-0
  • ros-jade-grid-map-ros: 1.4.1-0 → 1.4.2-0
  • ros-jade-grid-map-rviz-plugin: 1.4.1-0 → 1.4.2-0
  • ros-jade-grid-map-visualization: 1.4.1-0 → 1.4.2-0
  • ros-jade-image-common: 1.11.11-0 → 1.11.12-0
  • ros-jade-image-geometry: 1.11.14-0 → 1.11.15-0
  • ros-jade-image-transport: 1.11.11-0 → 1.11.12-0
  • ros-jade-image-view2: 2.1.2-1 → 2.2.2-0
  • ros-jade-imagesift: 0.3.29-0 → 1.1.0-0
  • ros-jade-industrial-core: 0.5.0-0 → 0.5.1-0
  • ros-jade-industrial-deprecated: 0.5.0-0 → 0.5.1-0
  • ros-jade-industrial-msgs: 0.5.0-0 → 0.5.1-0
  • ros-jade-industrial-robot-client: 0.5.0-0 → 0.5.1-0
  • ros-jade-industrial-robot-simulator: 0.5.0-0 → 0.5.1-0
  • ros-jade-industrial-trajectory-filters: 0.5.0-0 → 0.5.1-0
  • ros-jade-industrial-utils: 0.5.0-0 → 0.5.1-0
  • ros-jade-joint-state-publisher: 1.11.11-0 → 1.11.12-0
  • ros-jade-joy: 1.10.1-0 → 1.11.0-0
  • ros-jade-joystick-drivers: 1.10.1-0 → 1.11.0-0
  • ros-jade-jsk-3rdparty: 2.0.17-0 → 2.0.19-0
  • ros-jade-jsk-common: 2.1.2-1 → 2.2.2-0
  • ros-jade-jsk-data: 2.1.2-1 → 2.2.2-0
  • ros-jade-jsk-interactive: 2.0.0-0 → 2.1.0-0
  • ros-jade-jsk-interactive-marker: 2.0.0-0 → 2.1.0-0
  • ros-jade-jsk-interactive-test: 2.0.0-0 → 2.1.0-0
  • ros-jade-jsk-network-tools: 2.1.2-1 → 2.2.2-0
  • ros-jade-jsk-pcl-ros: 0.3.29-0 → 1.1.0-0
  • ros-jade-jsk-pcl-ros-utils: 0.3.29-0 → 1.1.0-0
  • ros-jade-jsk-perception: 0.3.29-0 → 1.1.0-0
  • ros-jade-jsk-pr2eus: 0.3.5-0 → 0.3.9-0
  • ros-jade-jsk-recognition: 0.3.29-0 → 1.1.0-0
  • ros-jade-jsk-recognition-msgs: 0.3.29-0 → 1.1.0-0
  • ros-jade-jsk-recognition-utils: 0.3.29-0 → 1.1.0-0
  • ros-jade-jsk-rqt-plugins: 2.0.0-0 → 2.1.0-0
  • ros-jade-jsk-rviz-plugins: 2.0.0-0 → 2.1.0-0
  • ros-jade-jsk-tilt-laser: 2.1.2-1 → 2.2.2-0
  • ros-jade-jsk-tools: 2.1.2-1 → 2.2.2-0
  • ros-jade-jsk-topic-tools: 2.1.2-1 → 2.2.2-0
  • ros-jade-jsk-visualization: 2.0.0-0 → 2.1.0-0
  • ros-jade-jskeus: 1.0.13-1 → 1.0.14-0
  • ros-jade-julius: 2.0.17-0 → 2.0.19-0
  • ros-jade-katana: 1.0.5-0 → 1.0.7-0
  • ros-jade-katana-arm-gazebo: 1.0.5-0 → 1.0.7-0
  • ros-jade-katana-description: 1.0.5-0 → 1.0.7-0
  • ros-jade-katana-driver: 1.0.5-0 → 1.0.7-0
  • ros-jade-katana-gazebo-plugins: 1.0.5-0 → 1.0.7-0
  • ros-jade-katana-moveit-ikfast-plugin: 1.0.5-0 → 1.0.7-0
  • ros-jade-katana-msgs: 1.0.5-0 → 1.0.7-0
  • ros-jade-katana-teleop: 1.0.5-0 → 1.0.7-0
  • ros-jade-katana-tutorials: 1.0.5-0 → 1.0.7-0
  • ros-jade-kdl-parser: 1.11.11-0 → 1.11.12-0
  • ros-jade-kdl-parser-py: 1.11.11-0 → 1.11.12-0
  • ros-jade-kni: 1.0.5-0 → 1.0.7-0
  • ros-jade-leap-motion: 0.0.10-0 → 0.0.11-0
  • ros-jade-libcmt: 2.0.17-0 → 2.0.19-0
  • ros-jade-libmavconn: 0.17.4-0 → 0.17.5-0
  • ros-jade-libsiftfast: 2.0.17-0 → 2.0.19-0
  • ros-jade-lpg-planner: 2.0.17-0 → 2.0.19-0
  • ros-jade-marti-can-msgs: 0.0.6-0 → 0.0.7-0
  • ros-jade-marti-common-msgs: 0.0.6-0 → 0.0.7-0
  • ros-jade-marti-nav-msgs: 0.0.6-0 → 0.0.7-0
  • ros-jade-marti-perception-msgs: 0.0.6-0 → 0.0.7-0
  • ros-jade-marti-sensor-msgs: 0.0.6-0 → 0.0.7-0
  • ros-jade-marti-visualization-msgs: 0.0.6-0 → 0.0.7-0
  • ros-jade-master-discovery-fkie: 0.6.2-0 → 0.7.2-0
  • ros-jade-master-sync-fkie: 0.6.2-0 → 0.7.2-0
  • ros-jade-mavros: 0.17.4-0 → 0.17.5-0
  • ros-jade-mavros-extras: 0.17.4-0 → 0.17.5-0
  • ros-jade-mavros-msgs: 0.17.4-0 → 0.17.5-0
  • ros-jade-mini-maxwell: 2.0.17-0 → 2.0.19-0
  • ros-jade-moveit: 0.8.3-0 → 0.8.5-0
  • ros-jade-moveit-commander: 0.8.3-0 → 0.8.5-0
  • ros-jade-moveit-controller-manager-example: 0.8.3-0 → 0.8.5-0
  • ros-jade-moveit-core: 0.8.3-0 → 0.8.5-0
  • ros-jade-moveit-fake-controller-manager: 0.8.3-0 → 0.8.5-0
  • ros-jade-moveit-planners: 0.8.3-0 → 0.8.5-0
  • ros-jade-moveit-planners-ompl: 0.8.3-0 → 0.8.5-0
  • ros-jade-moveit-plugins: 0.8.3-0 → 0.8.5-0
  • ros-jade-moveit-ros: 0.8.3-0 → 0.8.5-0
  • ros-jade-moveit-ros-benchmarks: 0.8.3-0 → 0.8.5-0
  • ros-jade-moveit-ros-benchmarks-gui: 0.8.3-0 → 0.8.5-0
  • ros-jade-moveit-ros-control-interface: 0.8.3-0 → 0.8.5-0
  • ros-jade-moveit-ros-manipulation: 0.8.3-0 → 0.8.5-0
  • ros-jade-moveit-ros-move-group: 0.8.3-0 → 0.8.5-0
  • ros-jade-moveit-ros-perception: 0.8.3-0 → 0.8.5-0
  • ros-jade-moveit-ros-planning: 0.8.3-0 → 0.8.5-0
  • ros-jade-moveit-ros-planning-interface: 0.8.3-0 → 0.8.5-0
  • ros-jade-moveit-ros-robot-interaction: 0.8.3-0 → 0.8.5-0
  • ros-jade-moveit-ros-visualization: 0.8.3-0 → 0.8.5-0
  • ros-jade-moveit-ros-warehouse: 0.8.3-0 → 0.8.5-0
  • ros-jade-moveit-setup-assistant: 0.8.3-0 → 0.8.5-0
  • ros-jade-moveit-simple-controller-manager: 0.8.3-0 → 0.8.5-0
  • ros-jade-multi-map-server: 2.1.2-1 → 2.2.2-0
  • ros-jade-multimaster-fkie: 0.6.2-0 → 0.7.2-0
  • ros-jade-multimaster-msgs-fkie: 0.6.2-0 → 0.7.2-0
  • ros-jade-multisense: 3.4.7-0 → 4.0.0-0
  • ros-jade-multisense-bringup: 3.4.7-0 → 4.0.0-0
  • ros-jade-multisense-cal-check: 3.4.7-0 → 4.0.0-0
  • ros-jade-multisense-description: 3.4.7-0 → 4.0.0-0
  • ros-jade-multisense-lib: 3.4.7-0 → 4.0.0-0
  • ros-jade-multisense-ros: 3.4.7-0 → 4.0.0-0
  • ros-jade-nao-moveit-config: 0.0.10-0 → 0.0.11-0
  • ros-jade-nav2d: 0.3.0-0 → 0.3.1-0
  • ros-jade-nav2d-exploration: 0.3.0-0 → 0.3.1-0
  • ros-jade-nav2d-karto: 0.3.0-0 → 0.3.1-0
  • ros-jade-nav2d-localizer: 0.3.0-0 → 0.3.1-0
  • ros-jade-nav2d-msgs: 0.3.0-0 → 0.3.1-0
  • ros-jade-nav2d-navigator: 0.3.0-0 → 0.3.1-0
  • ros-jade-nav2d-operator: 0.3.0-0 → 0.3.1-0
  • ros-jade-nav2d-remote: 0.3.0-0 → 0.3.1-0
  • ros-jade-nav2d-tutorials: 0.3.0-0 → 0.3.1-0
  • ros-jade-nerian-sp1: 1.4.0-0 → 1.6.0-0
  • ros-jade-nlopt: 2.0.17-0 → 2.0.19-0
  • ros-jade-node-manager-fkie: 0.6.2-0 → 0.7.2-0
  • ros-jade-object-recognition-core: 0.6.5-0 → 0.6.7-0
  • ros-jade-opencv3: 3.1.0-1 → 3.2.0-2
  • ros-jade-openhrp3: 3.1.8-0 → 3.1.9-0
  • ros-jade-opt-camera: 2.0.17-0 → 2.0.19-0
  • ros-jade-pepper-bringup: 0.1.7-0 → 0.1.10-1
  • ros-jade-pepper-dcm-bringup: 0.0.1-0 → 0.0.3-0
  • ros-jade-pepper-description: 0.1.7-0 → 0.1.10-1
  • ros-jade-pepper-moveit-config: 0.0.6-0 → 0.0.8-0
  • ros-jade-pepper-robot: 0.1.7-0 → 0.1.10-1
  • ros-jade-pepper-sensors-py: 0.1.7-0 → 0.1.10-1
  • ros-jade-pgm-learner: 2.0.17-0 → 2.0.19-0
  • ros-jade-polled-camera: 1.11.11-0 → 1.11.12-0
  • ros-jade-pr2eus: 0.3.5-0 → 0.3.9-0
  • ros-jade-pr2eus-moveit: 0.3.5-0 → 0.3.9-0
  • ros-jade-pr2eus-tutorials: 0.3.5-0 → 0.3.9-0
  • ros-jade-ps3joy: 1.10.1-0 → 1.11.0-0
  • ros-jade-pyros: 0.3.0-1 → 0.3.1-0
  • ros-jade-pyros-utils: 0.1.2-0 → 0.1.3-0
  • ros-jade-qt-dotgraph: 0.2.31-0 → 0.2.32-0
  • ros-jade-qt-gui: 0.2.31-0 → 0.2.32-0
  • ros-jade-qt-gui-app: 0.2.31-0 → 0.2.32-0
  • ros-jade-qt-gui-core: 0.2.31-0 → 0.2.32-0
  • ros-jade-qt-gui-cpp: 0.2.31-0 → 0.2.32-0
  • ros-jade-qt-gui-py-common: 0.2.31-0 → 0.2.32-0
  • ros-jade-resized-image-transport: 0.3.29-0 → 1.1.0-0
  • ros-jade-robot-model: 1.11.11-0 → 1.11.12-0
  • ros-jade-robot-self-filter: 0.1.29-0 → 0.1.30-0
  • ros-jade-robot-upstart: 0.2.0-0 → 0.2.2-0
  • ros-jade-romeo-bringup: 0.1.3-1 → 0.1.5-0
  • ros-jade-romeo-description: 0.1.3-1 → 0.1.5-0
  • ros-jade-romeo-robot: 0.1.3-1 → 0.1.5-0
  • ros-jade-romeo-sensors-py: 0.1.3-1 → 0.1.5-0
  • ros-jade-ros-type-introspection: 0.3.1-0 → 0.4.3-0
  • ros-jade-rospatlite: 2.0.17-0 → 2.0.19-0
  • ros-jade-rospeex: 2.15.0-0 → 2.15.4-0
  • ros-jade-rospeex-audiomonitor: 2.15.0-0 → 2.15.4-0
  • ros-jade-rospeex-core: 2.15.0-0 → 2.15.4-0
  • ros-jade-rospeex-if: 2.15.0-0 → 2.15.4-0
  • ros-jade-rospeex-launch: 2.15.0-0 → 2.15.4-0
  • ros-jade-rospeex-msgs: 2.15.0-0 → 2.15.4-0
  • ros-jade-rospeex-samples: 2.15.0-0 → 2.15.4-0
  • ros-jade-rospeex-webaudiomonitor: 2.15.0-0 → 2.15.4-0
  • ros-jade-rosping: 2.0.17-0 → 2.0.19-0
  • ros-jade-rostwitter: 2.0.17-0 → 2.0.19-0
  • ros-jade-rplidar-ros: 1.5.5-0 → 1.5.7-0
  • ros-jade-rqt-action: 0.4.3-0 → 0.4.5-0
  • ros-jade-rqt-bag: 0.4.3-0 → 0.4.5-0
  • ros-jade-rqt-bag-plugins: 0.4.3-0 → 0.4.5-0
  • ros-jade-rqt-common-plugins: 0.4.3-0 → 0.4.5-0
  • ros-jade-rqt-console: 0.4.3-0 → 0.4.5-0
  • ros-jade-rqt-dep: 0.4.3-0 → 0.4.5-0
  • ros-jade-rqt-graph: 0.4.3-0 → 0.4.5-0
  • ros-jade-rqt-image-view: 0.4.3-0 → 0.4.5-0
  • ros-jade-rqt-launch: 0.4.3-0 → 0.4.5-0
  • ros-jade-rqt-logger-level: 0.4.3-0 → 0.4.5-0
  • ros-jade-rqt-moveit: 0.5.5-0 → 0.5.6-0
  • ros-jade-rqt-msg: 0.4.3-0 → 0.4.5-0
  • ros-jade-rqt-multiplot: 0.0.5-1 → 0.0.6-0
  • ros-jade-rqt-nav-view: 0.5.5-0 → 0.5.6-0
  • ros-jade-rqt-plot: 0.4.3-0 → 0.4.5-0
  • ros-jade-rqt-pose-view: 0.5.5-0 → 0.5.6-0
  • ros-jade-rqt-publisher: 0.4.3-0 → 0.4.5-0
  • ros-jade-rqt-py-common: 0.4.3-0 → 0.4.5-0
  • ros-jade-rqt-py-console: 0.4.3-0 → 0.4.5-0
  • ros-jade-rqt-reconfigure: 0.4.3-0 → 0.4.5-0
  • ros-jade-rqt-robot-dashboard: 0.5.5-0 → 0.5.6-0
  • ros-jade-rqt-robot-monitor: 0.5.5-0 → 0.5.6-0
  • ros-jade-rqt-robot-plugins: 0.5.5-0 → 0.5.6-0
  • ros-jade-rqt-robot-steering: 0.5.5-0 → 0.5.6-0
  • ros-jade-rqt-runtime-monitor: 0.5.5-0 → 0.5.6-0
  • ros-jade-rqt-rviz: 0.5.5-0 → 0.5.6-0
  • ros-jade-rqt-service-caller: 0.4.3-0 → 0.4.5-0
  • ros-jade-rqt-shell: 0.4.3-0 → 0.4.5-0
  • ros-jade-rqt-srv: 0.4.3-0 → 0.4.5-0
  • ros-jade-rqt-tf-tree: 0.5.5-0 → 0.5.6-0
  • ros-jade-rqt-top: 0.4.3-0 → 0.4.5-0
  • ros-jade-rqt-topic: 0.4.3-0 → 0.4.5-0
  • ros-jade-rqt-web: 0.4.3-0 → 0.4.5-0
  • ros-jade-sick-tim: 0.0.9-0 → 0.0.10-0
  • ros-jade-simple-message: 0.5.0-0 → 0.5.1-0
  • ros-jade-slic: 2.0.17-0 → 2.0.19-0
  • ros-jade-spacenav-node: 1.10.1-0 → 1.11.0-0
  • ros-jade-srdfdom: 0.3.3-0 → 0.3.5-0
  • ros-jade-stdr-gui: 0.3.1-0 → 0.3.2-0
  • ros-jade-stdr-launchers: 0.3.1-0 → 0.3.2-0
  • ros-jade-stdr-msgs: 0.3.1-0 → 0.3.2-0
  • ros-jade-stdr-parser: 0.3.1-0 → 0.3.2-0
  • ros-jade-stdr-resources: 0.3.1-0 → 0.3.2-0
  • ros-jade-stdr-robot: 0.3.1-0 → 0.3.2-0
  • ros-jade-stdr-samples: 0.3.1-0 → 0.3.2-0
  • ros-jade-stdr-server: 0.3.1-0 → 0.3.2-0
  • ros-jade-stdr-simulator: 0.3.1-0 → 0.3.2-0
  • ros-jade-test-mavros: 0.17.4-0 → 0.17.5-0
  • ros-jade-tf2: 0.5.13-0 → 0.5.15-0
  • ros-jade-tf2-bullet: 0.5.13-0 → 0.5.15-0
  • ros-jade-tf2-eigen: 0.5.13-0 → 0.5.15-0
  • ros-jade-tf2-geometry-msgs: 0.5.13-0 → 0.5.15-0
  • ros-jade-tf2-kdl: 0.5.13-0 → 0.5.15-0
  • ros-jade-tf2-msgs: 0.5.13-0 → 0.5.15-0
  • ros-jade-tf2-py: 0.5.13-0 → 0.5.15-0
  • ros-jade-tf2-ros: 0.5.13-0 → 0.5.15-0
  • ros-jade-tf2-sensor-msgs: 0.5.13-0 → 0.5.15-0
  • ros-jade-tf2-tools: 0.5.13-0 → 0.5.15-0
  • ros-jade-tornado: 4.2.1-0 → 4.2.1-1
  • ros-jade-trac-ik: 1.4.3-0 → 1.4.5-0
  • ros-jade-trac-ik-examples: 1.4.3-0 → 1.4.5-0
  • ros-jade-trac-ik-kinematics-plugin: 1.4.3-0 → 1.4.5-0
  • ros-jade-trac-ik-lib: 1.4.3-0 → 1.4.5-0
  • ros-jade-ueye-cam: 1.0.15-0 → 1.0.16-0
  • ros-jade-urdf: 1.11.11-0 → 1.11.12-0
  • ros-jade-urdf-parser-plugin: 1.11.11-0 → 1.11.12-0
  • ros-jade-urdfdom-py: 0.3.1-0 → 0.3.3-0
  • ros-jade-virtual-force-publisher: 2.1.2-1 → 2.2.2-0
  • ros-jade-vision-opencv: 1.11.14-0 → 1.11.15-0
  • ros-jade-vision-visp: 0.9.1-0 → 0.10.0-0
  • ros-jade-visp: 3.0.0-4 → 3.0.1-2
  • ros-jade-visp-auto-tracker: 0.9.1-0 → 0.10.0-0
  • ros-jade-visp-bridge: 0.9.1-0 → 0.10.0-0
  • ros-jade-visp-camera-calibration: 0.9.1-0 → 0.10.0-0
  • ros-jade-visp-hand2eye-calibration: 0.9.1-0 → 0.10.0-0
  • ros-jade-visp-tracker: 0.9.1-0 → 0.10.0-0
  • ros-jade-voice-text: 2.0.17-0 → 2.0.19-0
  • ros-jade-wiimote: 1.10.1-0 → 1.11.0-0
Removed Packages [2]:
  • ros-jade-aubo-kinematics
  • ros-jade-gauges
  • Aaron Blasdel
  • AlexV
  • Alexander Tiderko
  • Anqi Xu
  • Antons Rebguns
  • Austin Hendrix
  • Benjamin Maidel
  • Carnegie Robotics
  • Chris Lalancette
  • Chris Zalidis
  • Dan Lazewatsky
  • Daniel Miller
  • Dave Coleman
  • David V. Lu!!
  • Davide Faconti
  • Devon Ash
  • Dirk Thomas
  • Dorian Scholz
  • Edmond DuPont
  • Elliot Johnson
  • Fabien Spindler
  • Felipe R. Fabresse (University of Seville)
  • Florian Lier
  • Henning Deeken
  • Hitoshi Kamada
  • Ioan Sucan
  • Isaac I. Y. Saito
  • Isaac Saito
  • Jack O’Quin
  • Jackie Kay
  • Jonathan Bohren
  • Jose Luis Rivero
  • Kei Okada
  • Koji Terada
  • Komei Sugiura
  • Konstantin Schauwecker
  • Maintained by Carnegie Robotics LLC
  • Marc Alban
  • Martin Guenther
  • Martin Günther
  • Mathias Lüdtke
  • Michael Ferguson
  • Mike Purvis
  • Natalia Lyubova
  • Noda Shintaro
  • Patrick Beeson
  • Paul Bovbel
  • Procopio Stein
  • Péter Fankhauser
  • Ralf Kaestner
  • Ryohei Ueda
  • Sachin Chitta
  • Scott K Logan
  • Scott Niekum
  • Sebastian Kasperski
  • Shaun Edwards
  • Slamtec ROS Maintainer
  • Surya Ambrose
  • TORK
  • Takuya Nakaoka
  • Tully Foote
  • Vincent Rabaud
  • Vladimir Ermakov
  • William Woodall
  • Yohei Kakiuchi
  • YoheiKakiuchi
  • Youhei Kakiuchi
  • Yuki Furuta
  • Yusuke Furuta
  • Yuto Inagaki
  • furuta
  • k-okada
  • nozawa
