We’re happy to announce 5 new packages and 46 updated packages for Kinetic Kame.
Thank you to all the maintainers and contributors who have helped make this possible!
Full details are below.
Package Updates for kinetic
Added Packages [5]:
- ros-kinetic-file-uploader-msgs: 1.0.1-1
- ros-kinetic-recorder-msgs: 1.0.1-1
- ros-kinetic-rosbag-cloud-recorders: 1.0.1-1
- ros-kinetic-s3-common: 1.0.1-1
- ros-kinetic-s3-file-uploader: 1.0.1-1
Updated Packages [46]:
- ros-kinetic-carla-msgs: 1.0.1-1 → 1.1.0-1
- ros-kinetic-costmap-cspace: 0.8.8-1 → 0.9.0-1
- ros-kinetic-joystick-interrupt: 0.8.8-1 → 0.9.0-1
- ros-kinetic-libfranka: 0.7.1-1 → 0.8.0-1
- ros-kinetic-map-organizer: 0.8.8-1 → 0.9.0-1
- ros-kinetic-marti-data-structures: 2.13.1-1 → 2.13.7-1
- ros-kinetic-mir-actions: 1.0.5-1 → 1.0.6-1
- ros-kinetic-mir-description: 1.0.5-1 → 1.0.6-1
- ros-kinetic-mir-driver: 1.0.5-1 → 1.0.6-1
- ros-kinetic-mir-dwb-critics: 1.0.5-1 → 1.0.6-1
- ros-kinetic-mir-gazebo: 1.0.5-1 → 1.0.6-1
- ros-kinetic-mir-msgs: 1.0.5-1 → 1.0.6-1
- ros-kinetic-mir-navigation: 1.0.5-1 → 1.0.6-1
- ros-kinetic-mir-robot: 1.0.5-1 → 1.0.6-1
- ros-kinetic-multisense: 4.0.0-0 → 4.0.4-1
- ros-kinetic-multisense-bringup: 4.0.0-0 → 4.0.4-1
- ros-kinetic-multisense-cal-check: 4.0.0-0 → 4.0.4-1
- ros-kinetic-multisense-description: 4.0.0-0 → 4.0.4-1
- ros-kinetic-multisense-lib: 4.0.0-0 → 4.0.4-1
- ros-kinetic-multisense-ros: 4.0.0-0 → 4.0.4-1
- ros-kinetic-neonavigation: 0.8.8-1 → 0.9.0-1
- ros-kinetic-neonavigation-common: 0.8.8-1 → 0.9.0-1
- ros-kinetic-neonavigation-launch: 0.8.8-1 → 0.9.0-1
- ros-kinetic-obj-to-pointcloud: 0.8.8-1 → 0.9.0-1
- ros-kinetic-planner-cspace: 0.8.8-1 → 0.9.0-1
- ros-kinetic-safety-limiter: 0.8.8-1 → 0.9.0-1
- ros-kinetic-sdc21x0: 1.0.5-1 → 1.0.6-1
- ros-kinetic-swri-console-util: 2.13.1-1 → 2.13.7-1
- ros-kinetic-swri-dbw-interface: 2.13.1-1 → 2.13.7-1
- ros-kinetic-swri-geometry-util: 2.13.1-1 → 2.13.7-1
- ros-kinetic-swri-image-util: 2.13.1-1 → 2.13.7-1
- ros-kinetic-swri-math-util: 2.13.1-1 → 2.13.7-1
- ros-kinetic-swri-nodelet: 2.13.1-1 → 2.13.7-1
- ros-kinetic-swri-opencv-util: 2.13.1-1 → 2.13.7-1
- ros-kinetic-swri-prefix-tools: 2.13.1-1 → 2.13.7-1
- ros-kinetic-swri-roscpp: 2.13.1-1 → 2.13.7-1
- ros-kinetic-swri-rospy: 2.13.1-1 → 2.13.7-1
- ros-kinetic-swri-route-util: 2.13.1-1 → 2.13.7-1
- ros-kinetic-swri-serial-util: 2.13.1-1 → 2.13.7-1
- ros-kinetic-swri-string-util: 2.13.1-1 → 2.13.7-1
- ros-kinetic-swri-system-util: 2.13.1-1 → 2.13.7-1
- ros-kinetic-swri-transform-util: 2.13.1-1 → 2.13.7-1
- ros-kinetic-swri-yaml-util: 2.13.1-1 → 2.13.7-1
- ros-kinetic-teleop-twist-keyboard: 0.6.2-0 → 1.0.0-2
- ros-kinetic-track-odometry: 0.8.8-1 → 0.9.0-1
- ros-kinetic-trajectory-tracker: 0.8.8-1 → 0.9.0-1
Removed Packages [0]:
- AWS RoboMaker
- Atsushi Watanabe
- Austin Hendrix
- CARLA Simulator Team
- Carnegie Robotics
- Franka Emika GmbH
- Kris Kozak
- Maintained by Carnegie Robotics LLC
- Marc Alban
- Martin Günther
- P. J. Reed
