Marine_msgs build
Sorry for the noob question, but I was exptecting new message packages from marine_msgs to be included here. This is my first time releasing packages so I may have missed something.
https://github.com/ros/rosdistro/pull/39899
Can anyone give me a clue as to what I’m missing?
Thanks,
Roland
Hi @rolker, it looks like the builds for those packages are failing: Nbin_uF64__marine_sensor_msgs__ubuntu_focal_amd64__binary [Jenkins]
There should be build failures messages sent to the maintainer listed in the package.xml.
Thanks, I’ll look into that.
It looks like the build is failing because it’s assuming that the folder name is the package name which is not guarenteed
https://github.com/apl-ocean-engineering/marine_msgs/issues/58
Thanks for pointing that out! I had scrolled to the bottom of the output and was being sent on a wild goose chase with the pthred errors!
I’ll fix that and resubmit.
