Hello Noetic maintainers!
Starting now, I will be holding new Noetic ros/rosdistro release PRs with a plan to sync ROS Noetic packages to the main apt repo on 2021-08-13. Please comment here if there are any issues I should know about before performing the sync.
There are currently 82 packages waiting to sync and 3 regressions.
https://github.com/ros-gbp/wifi_ddwrt-release/issues/1
https://github.com/PR2/pr2_apps/issues/43
https://github.com/ignitionrobotics/ros_ign/issues/173
PCL concatenatePointClouds() is deprecated in Noetic and replaced with concatenate(), but I have failed builds for Debian Buster source jobs.
Is this for ira_laser_tools? Since it doesn’t currently have packages in Debian Buster it doesn’t need to be fixed before the sync happens.
Ubuntu Focal uses 1.10 while Debian Buster uses 1.9.1. I would recommend using PCL_VERSION_COMPARE to use concatenatePointClouds() when using 1.9, and concatenate() when using 1.`0. Here’s an example I found.
