I was researching if there are ROS 2 Gazebo project for humanoid robots that would facilitate in learning robot locomotion and whole-body motion planning. I am looking towards humanoids similar to Unitree’s H1/H2.
A research scientist from ETH Zurich pointed me to the Issac Gym environment that comes with the assets for H1/H2. But as far as I understand, that simulation pipeline does not use any ROS, and is meant for RL like research.
The closet project I found was Unitree’s ROS 1 project GitHub - unitreerobotics/unitree_ros but it has not been updated for the newer ROS 2 and Gazebo.
You can find our TALOS/REEM-C Simulations and the related packages needed for the Gazebo simulation on our GitHub page: GitHub - pal-robotics/talos_simulation
Hi @saikishor thank you very much for pointing to TALOS and REEM-C packages compatible with ROS 2. I looked at the package.xml file for TALOS, is it currently compatible only with Gazebo 6 (Ignition Fortress)?
Hi @saikishor I’m also looking for any humanoid ros2 package for simulation. But the link you have given earlier for ROS2 I can’t find any urdf or .stl file in humble-devel branch. That’s why I’m not able to launch it for gazebo. Could you please help me with complete packages.
The talos_simulation package has the launch files to launch the simulation, but the original robot description is present here: GitHub - pal-robotics/talos_robot . I hope this is helpful.
