Posted by @IshaaanVyas:
Configuration
- Laptop with Ubuntu 20.04 and Galactic+Noetic installed
- Using a real robot (similar to turtlebot) and using free fleet client and server to relay messages from the fleet adapter to the robot
I am using the same full control fleet adapter as used in the rmf_demos (the one from here: rmf_ros2/rmf_fleet_adapter/launch/fleet_adapter.launch.xml at main · open-rmf/rmf_ros2 · GitHub ) which sends /robot_path_requests to my free fleet server and subscribes to /fleet_states .
Problem
Upon reaching certain waypoints in my map (other waypoints seem to be fine most of the time but this problem sometimes on them also) the fleet adapter stops sending any new path requests under /robot_path_requests (no /robot_destination_requests or /robot_mode_requests being sent to the free fleet server either) and this happens even when I am sending it a new task.
I have confirmed that the robot has correctly reached the waypoint and also that the /fleet_states of the robot have an empty path which I think means that the fleet adapter understands that the robot has reached his position (not very sure)? Moreover, normally when the robot reaches a waypoint and this error doesn’t occur, there is a message when I submit a new request to it such as:
[full_control-1] [INFO] [1661998969.526974945] [k_fleet_adapter]: Beginning new task [patrol.dispatch-1] for [k_fleet/robot]. Remaining queue size: 0
However, when this error is occurring this does not show from the fleet adapter.
I have confirmed that the robot has reached the location properly and the free fleet client does print out that it has succeeded, but it doesn’t get any new requests. Here is the /fleet_states that are printed out when this error occur:
robots:
- name: robot
model: robot_model
task_id: '7'
seq: 0
mode:
mode: 0
mode_request_id: 0
battery_percent: 100.0
t:
sec: 1661999287
nanosec: 112484873
x: 31.029001235961914
y: -8.669319152832031
yaw: -0.040468599647283554
obey_approach_speed_limit: false
approach_speed_limit: 0.0
level_name: L2
index: 0
path: []
Any help regarding how I could debug this would be greatly appreciated as right now I am abit clueless to why this is happening. I have attached a .txt file which contains the .building.yaml information about the map I am testing on : office.txt
I am trying to mimic multiple floors using only a single floor and have set up a mock lift node that correctly goes from L1 and L2 and transports the robot. The problem usually occurs in the production waypoint, however I have noticed it sometimes occurs in other waypoints as well.
Edited by @IshaaanVyas at 2022-09-01T03:49:14Z
