Posted by @royito55:
I’ve been setting up the RMF schedule for two robots, and although I can launch the basics, I keep getting the error shown in the title after I send a task to the schedule that includes two waypoints that are 2m or more apart.
It seems like the fleet adapter does not update correctly to where the robot actually is (the purple circle is where the robot is), and as soon as the error appears, I can’t send any more tasks and I have to restart the schedule to start again.
The system definitely knows where the robot is, otherwise the goals sent to nav2 would not even work, and the robot does start moving.
I’ve noticed that the threshold for this error to appear is 2 meters. If the waypoints are closer than that, then the fleet adapter sends a message saying that even though the robot is not where expected, it will continue.
Is this an issue with the fleet adapter, the free fleet client/server, or the rmf schedule? Can this be a network issue? I’m running everything with cycloneDDS; the robots have their own nav2 setup and the free fleet clients and server, while I launch the schedule in a central computer. Attached is a video of what happens.
- Also, as a general question, what does the purple circle AND the yellow circle represent? Is it a bad sign if the yellow circle disappears from time to time? Once the schedule plans the path, I can see that the purple circle takes longer than the yellow one to move, and it feels like they should be synced.
