Posted by @MatteoCarlone:
I followed the instructions from here to install open_rmf by directly installing the rmf_demos:
sudo apt install ros-galactic-rmf-demos-gz
I should have met all the dependecies:
rosdep install --from-paths src --ignore-src --rosdistro galactic -yr
#All required rosdeps installed successfully
When building the workspace colcon build --cmake-args -DCMAKE_BUILD_TYPE=Release I get this error:
Starting >>> rmf_robot_sim_gz_plugins
--- stderr: rmf_building_sim_gz_plugins
/home/matteocarlone/namespc_ws/src/rmf/rmf_simulation/rmf_building_sim_gz_plugins/src/door.cpp:45:8: error: ‘using Doors = class std::unordered_map<std::__cxx11::basic_string<char>, rmf_building_sim_common::DoorCommon::DoorElement>’ is private within this context
45 | std::optional<DoorCommon::Doors> get_doors(
In file included from /home/matteocarlone/namespc_ws/src/rmf/rmf_simulation/rmf_building_sim_gz_plugins/src/door.cpp:14:
/opt/ros/galactic/include/rmf_building_sim_common/door_common.hpp:107:9: note: declared private here
107 | using Doors = std::unordered_map<std::string, DoorElement>;
/home/matteocarlone/namespc_ws/src/rmf/rmf_simulation/rmf_building_sim_gz_plugins/src/door.cpp: In member function ‘std::optional<std::unordered_map<std::__cxx11::basic_string<char>, rmf_building_sim_common::DoorCommon::DoorElement> > rmf_building_sim_gz_plugins::DoorPlugin::get_doors(ignition::gazebo::v6::Model&, const string&, const std::shared_ptr<const sdf::v12::Element>&, ignition::gazebo::v6::EntityComponentManager&)’:
/home/matteocarlone/namespc_ws/src/rmf/rmf_simulation/rmf_building_sim_gz_plugins/src/door.cpp:91:17: error: ‘using Doors = class std::unordered_map<std::__cxx11::basic_string<char>, rmf_building_sim_common::DoorCommon::DoorElement>’ is private within this context
91 | DoorCommon::Doors doors;
/home/matteocarlone/namespc_ws/src/rmf/rmf_simulation/rmf_building_sim_gz_plugins/src/door.cpp:110:19: error: ‘struct rmf_building_sim_common::DoorCommon::DoorElement’ is private within this context
110 | DoorCommon::DoorElement door_element;
/opt/ros/galactic/include/rmf_building_sim_common/door_common.hpp:77:10: note: declared private here
77 | struct DoorElement
/home/matteocarlone/namespc_ws/src/rmf/rmf_simulation/rmf_building_sim_gz_plugins/src/door.cpp:113:36: error: ‘struct rmf_building_sim_common::DoorCommon::DoorElement’ is private within this context
113 | door_element = DoorCommon::DoorElement{lower_limit, upper_limit, true};
/home/matteocarlone/namespc_ws/src/rmf/rmf_simulation/rmf_building_sim_gz_plugins/src/door.cpp:117:36: error: ‘struct rmf_building_sim_common::DoorCommon::DoorElement’ is private within this context
117 | door_element = DoorCommon::DoorElement{lower_limit, upper_limit};
/home/matteocarlone/namespc_ws/src/rmf/rmf_simulation/rmf_building_sim_gz_plugins/src/door.cpp: In member function ‘virtual void rmf_building_sim_gz_plugins::DoorPlugin::Configure(const Entity&, const std::shared_ptr<const sdf::v12::Element>&, ignition::gazebo::v6::EntityComponentManager&, ignition::gazebo::v6::EventManager&)’:
/home/matteocarlone/namespc_ws/src/rmf/rmf_simulation/rmf_building_sim_gz_plugins/src/door.cpp:165:20: error: no matching function for call to ‘rmf_building_sim_common::DoorCommon::make(std::string&, rclcpp::Node::SharedPtr&, const std::shared_ptr<const sdf::v12::Element>&, std::unordered_map<std::__cxx11::basic_string<char>, rmf_building_sim_common::DoorCommon::DoorElement>&)’
165 | doors.value());
/opt/ros/galactic/include/rmf_building_sim_common/door_common.hpp:61:38: note: candidate: ‘template<class SdfPtrT> static std::shared_ptr<rmf_building_sim_common::DoorCommon> rmf_building_sim_common::DoorCommon::make(const string&, rclcpp::Node::SharedPtr, SdfPtrT&)’
61 | static std::shared_ptr<DoorCommon> make(
/opt/ros/galactic/include/rmf_building_sim_common/door_common.hpp:61:38: note: template argument deduction/substitution failed:
/home/matteocarlone/namespc_ws/src/rmf/rmf_simulation/rmf_building_sim_gz_plugins/src/door.cpp:165:20: note: candidate expects 3 arguments, 4 provided
make[2]: *** [CMakeFiles/door.dir/build.make:76: CMakeFiles/door.dir/src/door.cpp.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:118: CMakeFiles/door.dir/all] Error 2
make: *** [Makefile:141: all] Error 2
