Posted by @alexzhang13:
I was wondering how difficult it would be to integrate with other game engines like Unity or Unreal as opposed to Gazebo. I’ve been skimming through the codebase and a lot of components seem pretty heavily integrated with Gazebo.
One idea I had was to communicate with a engine through a ROS bridge as if it were a real fleet of robots and follow this section: Integration - Programming Multiple Robots with ROS 2 but I was wondering if anyone had a starting point to hack something like this together.
That, or if anyone could point me to where (if feasible) I could look to replace Gazebo. Thanks!
Posted by @luca-della-vedova:
Hi!
I believe integrating RMF with an engine that is not Gazebo wouldn’t be too hard, the main repos I would look at are rmf_simulation and rmf_demos.
Most of the logic that you would have to reimplement in your game engine is what is contained in rmf_simulation
. The package is currently split in a modular fashion, where the Gazebo independent logic is contained in _common
packages, and wrappers for Gazebo / Gazebo Classic are in _gz
and _gz_classic
packages respectively. It should be possible to use the _common
packages as a base and just build the interface to your game engine of choice on top of them.
In addition to the robot / infrastructure logic contained in the book you linked / rmf_simulation
, you would also need to create a /clock
publisher from your engine that provides the simulation time to the rest of the ROS 2 stack.
Good luck!
