Running ROS across multiple machines is failed
Hi All,
I am trying to run ROS across 2 machines, master is starting with out any issues when I tried to run listener getting below errors.
root@test:/opt/ros/indigo# rosrun rospy_tutorials listener.py
[rospack] Error: package ‘rospy_tutorials’ not found
find: ‘’: No such file or directory
I have followed below procedures.
System 1-
setting static IP-
ifconfig eth0 192.168.0.1 netmask 255.255.255.0
route add default gw 192.168.0.1 dev eth0
export ROS_IP=192.168.0.1
export ROS_HOSTNAME=192.168.0.1
roscore &
export ROS_MASTER_URI=http://192.168.0.1:11311/
System-2
setting static IP-
ifconfig eth0 192.168.0.2 netmask 255.255.255.0
route add default gw 192.168.0.2 dev eth0
export ROS_IP=192.168.0.2
export ROS_HOSTNAME=192.168.0.2
rosrun rospy_tutorials talker.py
Note: I could able to ping between system 1 & 2.
Kindly help us to debug this issue in my setup.
Kindly let me know if you need any more information,
Regards
Bharath
Thanks for your question. However we ask that you please ask questions on http://answers.ros.org following our support guidelines: Support - ROS Wiki
ROS Discourse is for news and general interest discussions. ROS Answers provides a forum which can be filtered by tags to make sure the relevant people can find and/or answer the question, and not overload everyone with hundreds of posts.
