Hey there,
I’m releasing ros-opentelemetry, a production-grade library that instruments ROS 2 applications with OpenTelemetry for distributed tracing, correlated logs, and metrics — for both C++ and Python nodes.
Why this matters
Follow a task across nodes (services, actions, topics) with connected spans.
Correlate logs with trace/span IDs for rapid root-cause analysis.
Backend-agnostic: send data to any OTel-compatible stack (e.g., SigNoz; Grafana planned).
What’s inside
ros_opentelemetry_cppandros_opentelemetry_pyhelpers to bootstrap tracers. -
ros_opentelemetry_interfaceswith aTraceMetadatamessage to propagate the trace context between nodes. -
Detailed instructions on how to instrument your ROS2 code.
“Justfile” commands + Docker setup for a one-command demo environment.
Demo
The repo includes Just targets to bring up an example with MoveIt2-based C++ node + a Python task producer instrumented with OpenTelemetry and an OTel stack (e.g., SigNoz).
just docker-up-telemetry -
just docker-up-example -
or run locally with
just run-example-locally(rViz).
Repo: ROS2 x OpenTelemetry: End‑to‑End Telemetry for Robotics
OpenTelemetry background: opentelemetry.io (traces/logs, language SDKs)
How this relates to existing work
- Complements ros2_tracing (LTTng-based tracing of ROS 2 internals) by offering vendor-neutral OpenTelemetry export and cross-service propagation for app-level spans. If you already use
ros2_tracing, you can keep it for low-level insights and layer OTel for end-to-end visibility.
I’m looking forward to your feedback.
Additionally, I will be presenting this library at ROSCon DE&FR 2025, and I would be happy to discuss it in person.
Thanks,
Sergei
