ROS2 Subscriber defined in Class (Win10, Visual Studio 14)
using std::placeholders::_1;
class MinimalSubscriber
  public:
    MinimalSubscriber() {}
    init(int m_agrc, char** m_argv)
       rclcpp::init(m_argc, m_argv);
       m_rosnode = std::make_shared\<rclcpp::Node>("node_sub");
       sub = m_rosnode->create_subscription<std_msgs::msg::String>( "topic",
       std::bind(&MinimalSubscriber::topic_callback, this, _1));
       while(rclcpp::ok())
           rclp::spin(m_rosnode);
   private:
       void topic_callback(const std_msgs::msg::String::SharedPtr & msg)
            RCLCPP_INFO(m_rosnode->get_logger(), "I heard: '%s'", msg->data.c_str())
       rclcpp::Publisher<std_msgs::msg::String>::SharedPtr m_rosnode;
       rclcpp::Subscription<std_msgs::msg::String>::SharedPtr sub;
int main(int argc, char * argv[])
     rclcpp::init(argc, argv);
     std::shared_ptr<MinimalSubscriber> m_sub = std::make_shared<MinimalSubscriber>;
     rclcpp::shutdown();
     return 0;
Hi I tried to build this above example, but I got an error:
error C2672: 'rclcpp::AnySubscriptionCallback<MessageT,Alloc>::set': no matching overloaded function found.
this error was caused by this line :
 _subscription_ = m_rosnode->create_subscription<std_msgs::msg::String>( "topic", std::bind(&MinimalSubscriber::topic_callback, this, _1));
Can anyone help me? Thanks in advance!
I solved this problem.
Do you mind posting your solution here? This might be helpful for people stumbling upon the same error from search machines.
void topic_callback(const std_msgs::msg::String::SharedPtr& msg);
should be:
void topic_callback(const std_msgs::msg::String::SharedPtr msg)
Glad you found a solution to your problem.
In general we ask that you please ask questions on http://answers.ros.org following our support guidelines: Support - ROS Wiki
ROS Discourse is for news and general interest discussions. ROS Answers provides a forum which can be filtered by tags to make sure the relevant people can find and/or answer the question, and not overload everyone with hundreds of posts.
