Hi everyone,
I found some bugs in the repository examples-master:
download examples-master into C:\dev\ros2
open developer cmd prompt for 2015
go to C:\dev\ros2
call local_setup.bat
go to C:\dev\ros2\examples-master\rclcpp\minimal_publisher\
mkdir src
move all files into C:\dev\ros2\examples-master\rclcpp\minimal_publisher\src\
ament build
9: error_info:
“C:\dev\ros2\examples-ardent\rclcpp\minimal_publisher\build\examples_rclcpp_minimal_publisher\examples_rclcpp_mi
nimal_publisher.sln” (default target) (1) →
“C:\dev\ros2\examples-ardent\rclcpp\minimal_publisher\build\examples_rclcpp_minimal_publisher\publisher_not_comp
osable.vcxproj.metaproj” (default target) (5) →
osable.vcxproj” (default target) (7) →
(ClCompile target) →
C:\dev\ros2\examples-ardent\rclcpp\minimal_publisher\src\not_composable.cpp(37): error C2039: ‘get_logger’: is
not a member of ‘rclcpp::node::Node’ [C:\dev\ros2\examples-ardent\rclcpp\minimal_publisher\build\examples_rclcp
p_minimal_publisher\publisher_not_composable.vcxproj]"C:\dev\ros2\examples-ardent\rclcpp\minimal_publisher\build\examples_rclcpp_minimal_publisher\examples_rclcpp_mi nimal_publisher.sln" (default target) (1) -> "C:\dev\ros2\examples-ardent\rclcpp\minimal_publisher\build\examples_rclcpp_minimal_publisher\publisher_member_f unction.vcxproj.metaproj" (default target) (4) -> "C:\dev\ros2\examples-ardent\rclcpp\minimal_publisher\build\examples_rclcpp_minimal_publisher\publisher_member_f unction.vcxproj" (default target) (8) -> C:\dev\ros2\examples-ardent\rclcpp\minimal_publisher\src\member_function.cpp(39): error C2039: 'get_logger': i s not a member of 'MinimalPublisher' [C:\dev\ros2\examples-ardent\rclcpp\minimal_publisher\build\examples_rclcpp _minimal_publisher\publisher_member_function.vcxproj] "C:\dev\ros2\examples-ardent\rclcpp\minimal_publisher\build\examples_rclcpp_minimal_publisher\examples_rclcpp_mi nimal_publisher.sln" (default target) (1) -> "C:\dev\ros2\examples-ardent\rclcpp\minimal_publisher\build\examples_rclcpp_minimal_publisher\publisher_lambda.v cxproj.metaproj" (default target) (3) -> "C:\dev\ros2\examples-ardent\rclcpp\minimal_publisher\build\examples_rclcpp_minimal_publisher\publisher_lambda.v cxproj" (default target) (9) -> C:\dev\ros2\examples-ardent\rclcpp\minimal_publisher\src\lambda.cpp(35): error C2039: 'get_logger': is not a m ember of 'MinimalPublisher' [C:\dev\ros2\examples-ardent\rclcpp\minimal_publisher\build\examples_rclcpp_minimal_ publisher\publisher_lambda.vcxproj] C:\dev\ros2\examples-ardent\rclcpp\minimal_publisher\src\lambda.cpp(35): error C2039: '__this': is not a membe r of 'MinimalPublisher' [C:\dev\ros2\examples-ardent\rclcpp\minimal_publisher\build\examples_rclcpp_minimal_publ isher\publisher_lambda.vcxproj]3 Warning(s)
4 Error(s)
