I am building ROS2 Debug Source Build on Windows (Using python_d). C++ examples works fine. But when try to run the python example get the following error:
I’m following the steps mentioned: GitHub - ros2/ros2: The Robot Operating System, is a meta operating system for robots.
Any suggestion, how to resolve these?
Regards
Mrutunjayya,
Errors:
Failed to load entry point 'start': No module named 'rclpy._rclpy'
Failed to load entry point 'status': No module named 'rclpy._rclpy'
Failed to load entry point 'stop': No module named 'rclpy._rclpy'
Failed to load entry point 'list': No module named 'rclpy._rclpy'
Failed to load entry point 'call': No module named 'rclpy._rclpy'
Failed to load entry point 'echo': No module named 'rclpy._rclpy'
Failed to load entry point 'pub': No module named 'rclpy._rclpy'
File "D:\Test\ROS_Source_Build\Debug_Python\install\lib\demo_nodes_py\talker-script.py", line 11, in <module>
load_entry_point('demo-nodes-py==0.0.0', 'console_scripts', 'talker')()
File "C:\Python36\lib\site-packages\pkg_resources\__init__.py", line 561, in load_entry_point
return get_distribution(dist).load_entry_point(group, name)
File "C:\Python36\lib\site-packages\pkg_resources\__init__.py", line 2649, in load_entry_point
return ep.load()
File "C:\Python36\lib\site-packages\pkg_resources\__init__.py", line 2303, in load
return self.resolve()
File "C:\Python36\lib\site-packages\pkg_resources\__init__.py", line 2309, in resolve
module = __import__(self.module_name, fromlist=['__name__'], level=0)
File "D:\Test\ROS_Source_Build\Debug_Python\install\Lib\site-packages\topics\talker.py", line 18, in <module>
import rclpy
File "D:\Test\ROS_Source_Build\Debug_Python\install\Lib\site-packages\rclpy\__init__.py", line 18, in <module>
from rclpy.impl.implementation_singleton import rclpy_implementation as _rclpy
File "D:\Test\ROS_Source_Build\Debug_Python\install\Lib\site-packages\rclpy\impl\implementation_singleton.py", line 32, in <module>
rclpy_implementation = importlib.import_module('._rclpy', package='rclpy')
File "C:\Python36\lib\importlib\__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
ModuleNotFoundError: No module named 'rclpy._rclpy'
thanks @mrutyu1987 for reporting.
By the look of it it looks like the python debug libraries have not been found when you built.
Can you confirm that you have a file called _rclpy_d.pyd in D:\Test\ROS_Source_Build\Debug_Python\install\Lib\site-packages\rclpy ?
I would expect the result to be the same but can you try to run the executable directly:
call D:\Test\ROS_Source_Build\Debug_Python\install\setup.bat
D:\Test\ROS_Source_Build\Debug_Python\install\Lib\demo_nodes_py\talker.exe
Finally can you provide your build output of rclpy and demo_nodes_py ?
rmdir /S D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py D:\Test\ROS_Source_Build\Debug_Python\build\rclpy
python_d D:\Test\ROS_Source_Build\Debug_Python\src\ament\ament_tools\scripts\ament.py build --cmake-args -DCMAKE-BUILD_TYPE=Debug -- --only rclpy demo_nodes_py
Thanks!
Thanks @marguedas .
I do not see _rclply_d.pyd file in the site-packages\rclpy folder.
Re-Built as mentioned in your response still not “_rclply_d.pyd”. Here is the build log as you mentioned:
D:\Test\ROS_Source_Build\Debug_Python>python_d D:\Test\ROS_Source_Build\Debug_Python\src\ament\ament_tools\scripts\ament.py build --cmake-args -DCMAKE-BUILD_TYPE=Debug -- --only rclpy demo_nodes_py
# Topological order
Process package 'rclpy' with context:
source_space => D:\Test\ROS_Source_Build\Debug_Python\src\ros2\rclpy\rclpy
build_space => D:\Test\ROS_Source_Build\Debug_Python\build\rclpy
install_space => D:\Test\ROS_Source_Build\Debug_Python\install
make_flags => -j8, -l8
build_tests => False
+++ Building 'rclpy'
==> 'D:\Test\ROS_Source_Build\Debug_Python\build\rclpy\cmake__build.bat C:\Program Files\CMake\bin\cmake.EXE D:\Test\ROS_Source_Build\Debug_Python\src\ros2\rclpy\rclpy -DBUILD_TESTING=0 -DCMAKE-BUILD_TYPE=Debug -DCMAKE_INSTALL_PREFIX=D:\Test\ROS_Source_Build\Debug_Python\install -G Visual Studio 14 2015 Win64' in 'D:\Test\ROS_Source_Build\Debug_Python\build\rclpy'
-- The C compiler identification is MSVC 19.0.24215.1
-- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio 14.0/VC/bin/x86_amd64/cl.exe
-- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio 14.0/VC/bin/x86_amd64/cl.exe -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Found ament_cmake: 0.0.2 (D:/Test/ROS_Source_Build/Debug_Python/install/share/ament_cmake/cmake)
-- Found PythonInterp: C:/Python36/python.exe (found suitable version "3.6.1", minimum required is "3")
-- Using PYTHON_EXECUTABLE: C:/Python36/python.exe
-- Found rcl: 0.0.2 (D:/Test/ROS_Source_Build/Debug_Python/install/share/rcl/cmake)
-- Found rmw_implementation_cmake: 0.0.2 (D:/Test/ROS_Source_Build/Debug_Python/install/share/rmw_implementation_cmake/cmake)
-- Using RMW implementation 'rmw_fastrtps_cpp' as default
-- Found rmw_fastrtps_cpp: 0.0.2 (D:/Test/ROS_Source_Build/Debug_Python/install/share/rmw_fastrtps_cpp/cmake)
-- Found fastrtps_cmake_module: 0.0.2 (D:/Test/ROS_Source_Build/Debug_Python/install/share/fastrtps_cmake_module/cmake)
-- Found FastRTPS: D:/Test/ROS_Source_Build/Debug_Python/install/include
-- Found python_cmake_module: 0.0.2 (D:/Test/ROS_Source_Build/Debug_Python/install/share/python_cmake_module/cmake)
-- Found PythonInterp: C:/Python36/python.exe (found suitable version "3.6.1", minimum required is "3.5")
-- Found PythonLibs: optimized;C:/Python36/libs/python36.lib;debug;C:/Python36/libs/python36_d.lib (found suitable version "3.6.1", minimum required is "3.5")
-- Using PYTHON_INCLUDE_DIRS: C:/Python36/include
-- Using PYTHON_LIBRARIES: optimized;C:/Python36/libs/python36.lib;debug;C:/Python36/libs/python36_d.lib
-- Found PythonExtra: .pyd
-- Configuring done
-- Generating done
CMake Warning:
Manually-specified variables were not used by the project:
CMAKE-BUILD_TYPE
-- Build files have been written to: D:/Test/ROS_Source_Build/Debug_Python/build/rclpy
==> 'D:\Test\ROS_Source_Build\Debug_Python\build\rclpy\cmake__build.bat C:\Program Files (x86)\MSBuild\14.0\bin\msbuild.EXE /m:8 /p:Configuration=Release D:\Test\ROS_Source_Build\Debug_Python\build\rclpy\rclpy.sln' in 'D:\Test\ROS_Source_Build\Debug_Python\build\rclpy'
Microsoft (R) Build Engine version 14.0.25420.1
Copyright (C) Microsoft Corporation. All rights reserved.
Build started 8/14/2017 11:14:22 AM.
1>Project "D:\Test\ROS_Source_Build\Debug_Python\build\rclpy\rclpy.sln" on node 1 (default targets).
1>ValidateSolutionConfiguration:
Building solution configuration "Release|x64".
ValidateProjects:
The project "INSTALL" is not selected for building in solution configuration "Release|x64".
The project "uninstall" is not selected for building in solution configuration "Release|x64".
1>Project "D:\Test\ROS_Source_Build\Debug_Python\build\rclpy\rclpy.sln" (1) is building "D:\Test\ROS_Sourc
e_Build\Debug_Python\build\rclpy\ALL_BUILD.vcxproj.metaproj" (2) on node 1 (default targets).
2>Project "D:\Test\ROS_Source_Build\Debug_Python\build\rclpy\ALL_BUILD.vcxproj.metaproj" (2) is building "D:\K
idSpace\ROS_Source_Build\Debug_Python\build\rclpy\ZERO_CHECK.vcxproj" (4) on node 2 (default targets).
4>PrepareForBuild:
Creating directory "x64\Release\ZERO_CHECK\".
Creating directory "x64\Release\ZERO_CHECK\ZERO_CHECK.tlog\".
InitializeBuildStatus:
Creating "x64\Release\ZERO_CHECK\ZERO_CHECK.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
CustomBuild:
Checking Build System
CMake does not need to re-run because D:/Test/ROS_Source_Build/Debug_Python/build/rclpy/CMakeFiles/generat
e.stamp is up-to-date.
FinalizeBuildStatus:
Deleting file "x64\Release\ZERO_CHECK\ZERO_CHECK.tlog\unsuccessfulbuild".
Touching "x64\Release\ZERO_CHECK\ZERO_CHECK.tlog\ZERO_CHECK.lastbuildstate".
4>Done Building Project "D:\Test\ROS_Source_Build\Debug_Python\build\rclpy\ZERO_CHECK.vcxproj" (default target
s).
e_Build\Debug_Python\build\rclpy\rclpy.vcxproj.metaproj" (3) on node 1 (default targets).
3>Project "D:\Test\ROS_Source_Build\Debug_Python\build\rclpy\rclpy.vcxproj.metaproj" (3) is building "D:\KidSp
ace\ROS_Source_Build\Debug_Python\build\rclpy\rclpy.vcxproj" (5) on node 1 (default targets).
5>PrepareForBuild:
Creating directory "rclpy.dir\Release\".
Creating directory "rclpy.dir\Release\rclpy.tlog\".
Creating "rclpy.dir\Release\rclpy.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
CustomBuild:
Building Custom Rule D:/Test/ROS_Source_Build/Debug_Python/src/ros2/rclpy/rclpy/CMakeLists.txt
ClCompile:
C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64\CL.exe /c /ID:\Test\ROS_Source_Build\
Debug_Python\install\include /IC:\Python36\include /nologo /W3 /WX- /O2 /Ob2 /D WIN32 /D _WINDOWS /D NDEBUG /D
"CMAKE_INTDIR=\"Release\"" /D rclpy_EXPORTS /D _WINDLL /D _MBCS /Gm- /MD /GS /fp:precise /Zc:wchar_t /Zc:forS
cope /Zc:inline /Fo"rclpy.dir\Release\\" /Fd"rclpy.dir\Release\vc140.pdb" /Gd /TC /errorReport:queue D:\KidSpa
ce\ROS_Source_Build\Debug_Python\src\ros2\rclpy\rclpy\src\rclpy\_rclpy.c
_rclpy.c
MakeDirsForLink:
Creating directory "D:\Test\ROS_Source_Build\Debug_Python\build\rclpy\Release\".
Link:
C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64\link.exe /ERRORREPORT:QUEUE /OUT:"D:\KidS
pace\ROS_Source_Build\Debug_Python\build\rclpy\rclpy\_rclpy.pyd" /INCREMENTAL:NO /NOLOGO kernel32.lib user32.l
ib gdi32.lib winspool.lib shell32.lib ole32.lib oleaut32.lib uuid.lib comdlg32.lib advapi32.lib C:\Python36\li
bs\python36.lib D:\Test\ROS_Source_Build\Debug_Python\install\Lib\rcl_interfaces__rosidl_typesupport_c.lib
D:\Test\ROS_Source_Build\Debug_Python\install\Lib\rcl_interfaces__rosidl_typesupport_cpp.lib D:\Test\
ROS_Source_Build\Debug_Python\install\Lib\rcl_interfaces__rosidl_typesupport_introspection_c.lib D:\Test\R
OS_Source_Build\Debug_Python\install\Lib\rcl_interfaces__rosidl_generator_c.lib D:\Test\ROS_Source_Build\D
ebug_Python\install\Lib\rcl_interfaces__rosidl_typesupport_introspection_cpp.lib "D:\Test\ROS_Source_Build
\Debug_Python\install\Lib\fastrtps-1.5.lib" "D:\Test\ROS_Source_Build\Debug_Python\install\Lib\fastcdr-1.0
.lib" D:\Test\ROS_Source_Build\Debug_Python\install\Lib\rmw.lib D:\Test\ROS_Source_Build\Debug_Python\
install\Lib\rosidl_typesupport_introspection_c.lib D:\Test\ROS_Source_Build\Debug_Python\install\Lib\rosid
l_typesupport_introspection_cpp.lib D:\Test\ROS_Source_Build\Debug_Python\install\Lib\rmw_fastrtps_cpp.lib
D:\Test\ROS_Source_Build\Debug_Python\install\Lib\rosidl_generator_c.lib D:\Test\ROS_Source_Build\Deb
ug_Python\install\Lib\rcl.lib D:\Test\ROS_Source_Build\Debug_Python\install\Lib\rcutils.lib /MANIFEST /MAN
IFESTUAC:"level='asInvoker' uiAccess='false'" /manifest:embed /PDB:"D:/Test/ROS_Source_Build/Debug_Python/
build/rclpy/rclpy/_rclpy.pdb" /SUBSYSTEM:CONSOLE /TLBID:1 /DYNAMICBASE /NXCOMPAT /IMPLIB:"D:/Test/ROS_Sour
ce_Build/Debug_Python/build/rclpy/Release/_rclpy.lib" /MACHINE:X64 /machine:x64 /DLL rclpy.dir\Release\_rclp
y.obj
Creating library D:/Test/ROS_Source_Build/Debug_Python/build/rclpy/Release/_rclpy.lib and object D:/Kid
Space/ROS_Source_Build/Debug_Python/build/rclpy/Release/_rclpy.exp
rclpy.vcxproj -> D:\Test\ROS_Source_Build\Debug_Python\build\rclpy\rclpy\_rclpy.pyd
Deleting file "rclpy.dir\Release\rclpy.tlog\unsuccessfulbuild".
Touching "rclpy.dir\Release\rclpy.tlog\rclpy.lastbuildstate".
5>Done Building Project "D:\Test\ROS_Source_Build\Debug_Python\build\rclpy\rclpy.vcxproj" (default targets).
3>Done Building Project "D:\Test\ROS_Source_Build\Debug_Python\build\rclpy\rclpy.vcxproj.metaproj" (default ta
rgets).
idSpace\ROS_Source_Build\Debug_Python\build\rclpy\ALL_BUILD.vcxproj" (6) on node 1 (default targets).
6>PrepareForBuild:
Creating directory "x64\Release\ALL_BUILD\".
Creating directory "x64\Release\ALL_BUILD\ALL_BUILD.tlog\".
Creating "x64\Release\ALL_BUILD\ALL_BUILD.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
CustomBuild:
Deleting file "x64\Release\ALL_BUILD\ALL_BUILD.tlog\unsuccessfulbuild".
Touching "x64\Release\ALL_BUILD\ALL_BUILD.tlog\ALL_BUILD.lastbuildstate".
6>Done Building Project "D:\Test\ROS_Source_Build\Debug_Python\build\rclpy\ALL_BUILD.vcxproj" (default targets
2>Done Building Project "D:\Test\ROS_Source_Build\Debug_Python\build\rclpy\ALL_BUILD.vcxproj.metaproj" (defaul
t targets).
1>Done Building Project "D:\Test\ROS_Source_Build\Debug_Python\build\rclpy\rclpy.sln" (default targets).
Build succeeded.
0 Warning(s)
0 Error(s)
Time Elapsed 00:00:01.78
+++ Installing 'rclpy'
==> 'D:\Test\ROS_Source_Build\Debug_Python\build\rclpy\cmake__install.bat C:\Program Files (x86)\MSBuild\14.0\bin\msbuild.EXE /p:Configuration=Release D:\Test\ROS_Source_Build\Debug_Python\build\rclpy\INSTALL.vcxproj' in 'D:\Test\ROS_Source_Build\Debug_Python\build\rclpy'
Build started 8/14/2017 11:14:26 AM.
Project "D:\Test\ROS_Source_Build\Debug_Python\build\rclpy\INSTALL.vcxproj" on node 1 (default targets).
Project "D:\Test\ROS_Source_Build\Debug_Python\build\rclpy\INSTALL.vcxproj" (1) is building "D:\Test\ROS_Source
_Build\Debug_Python\build\rclpy\ZERO_CHECK.vcxproj" (2) on node 1 (default targets).
CustomBuild:
All outputs are up-to-date.
Done Building Project "D:\Test\ROS_Source_Build\Debug_Python\build\rclpy\ZERO_CHECK.vcxproj" (default targets).
_Build\Debug_Python\build\rclpy\ALL_BUILD.vcxproj" (3) on node 1 (default targets).
Project "D:\Test\ROS_Source_Build\Debug_Python\build\rclpy\ALL_BUILD.vcxproj" (3) is building "D:\Test\ROS_Sour
ce_Build\Debug_Python\build\rclpy\rclpy.vcxproj" (4) on node 1 (default targets).
CustomBuild:
ClCompile:
Link:
CustomBuild:
Done Building Project "D:\Test\ROS_Source_Build\Debug_Python\build\rclpy\ALL_BUILD.vcxproj" (default targets).
PrepareForBuild:
Creating directory "x64\Release\INSTALL\".
Creating directory "x64\Release\INSTALL\INSTALL.tlog\".
Creating "x64\Release\INSTALL\INSTALL.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
PostBuildEvent:
setlocal
"C:\Program Files\CMake\bin\cmake.exe" -DBUILD_TYPE=Release -P cmake_install.cmake
if %errorlevel% neq 0 goto :cmEnd
:cmEnd
endlocal & call :cmErrorLevel %errorlevel% & goto :cmDone
:cmErrorLevel
exit /b %1
:cmDone
if %errorlevel% neq 0 goto :VCEnd
:VCEnd
-- Install configuration: "Release"
-- Installing: D:/Test/ROS_Source_Build/Debug_Python/install/share/rclpy/environment/pythonpath.bat
-- Up-to-date: D:/Test/ROS_Source_Build/Debug_Python/install/Lib/site-packages/rclpy
-- Up-to-date: D:/Test/ROS_Source_Build/Debug_Python/install/Lib/site-packages/rclpy/client.py
-- Up-to-date: D:/Test/ROS_Source_Build/Debug_Python/install/Lib/site-packages/rclpy/constants.py
-- Up-to-date: D:/Test/ROS_Source_Build/Debug_Python/install/Lib/site-packages/rclpy/exceptions.py
-- Up-to-date: D:/Test/ROS_Source_Build/Debug_Python/install/Lib/site-packages/rclpy/expand_topic_name.py
-- Up-to-date: D:/Test/ROS_Source_Build/Debug_Python/install/Lib/site-packages/rclpy/impl
-- Up-to-date: D:/Test/ROS_Source_Build/Debug_Python/install/Lib/site-packages/rclpy/impl/implementation_singleto
n.py
-- Up-to-date: D:/Test/ROS_Source_Build/Debug_Python/install/Lib/site-packages/rclpy/impl/__init__.py
-- Up-to-date: D:/Test/ROS_Source_Build/Debug_Python/install/Lib/site-packages/rclpy/node.py
-- Up-to-date: D:/Test/ROS_Source_Build/Debug_Python/install/Lib/site-packages/rclpy/publisher.py
-- Up-to-date: D:/Test/ROS_Source_Build/Debug_Python/install/Lib/site-packages/rclpy/qos.py
-- Up-to-date: D:/Test/ROS_Source_Build/Debug_Python/install/Lib/site-packages/rclpy/service.py
-- Up-to-date: D:/Test/ROS_Source_Build/Debug_Python/install/Lib/site-packages/rclpy/subscription.py
-- Up-to-date: D:/Test/ROS_Source_Build/Debug_Python/install/Lib/site-packages/rclpy/timer.py
-- Up-to-date: D:/Test/ROS_Source_Build/Debug_Python/install/Lib/site-packages/rclpy/topic_or_service_is_hidden.p
y
-- Up-to-date: D:/Test/ROS_Source_Build/Debug_Python/install/Lib/site-packages/rclpy/utilities.py
-- Up-to-date: D:/Test/ROS_Source_Build/Debug_Python/install/Lib/site-packages/rclpy/validate_full_topic_name.py
-- Up-to-date: D:/Test/ROS_Source_Build/Debug_Python/install/Lib/site-packages/rclpy/validate_namespace.py
-- Up-to-date: D:/Test/ROS_Source_Build/Debug_Python/install/Lib/site-packages/rclpy/validate_node_name.py
-- Up-to-date: D:/Test/ROS_Source_Build/Debug_Python/install/Lib/site-packages/rclpy/validate_topic_name.py
-- Up-to-date: D:/Test/ROS_Source_Build/Debug_Python/install/Lib/site-packages/rclpy/__init__.py
-- Installing: D:/Test/ROS_Source_Build/Debug_Python/install/Lib/site-packages/rclpy/_rclpy.lib
-- Installing: D:/Test/ROS_Source_Build/Debug_Python/install/Lib/site-packages/rclpy/_rclpy.pyd
-- Installing: D:/Test/ROS_Source_Build/Debug_Python/install/share/ament_index/resource_index/package_run_depende
ncies/rclpy
-- Installing: D:/Test/ROS_Source_Build/Debug_Python/install/share/ament_index/resource_index/parent_prefix_path/
rclpy
-- Up-to-date: D:/Test/ROS_Source_Build/Debug_Python/install/share/rclpy/environment/ament_prefix_path.bat
-- Up-to-date: D:/Test/ROS_Source_Build/Debug_Python/install/share/rclpy/environment/path.bat
-- Installing: D:/Test/ROS_Source_Build/Debug_Python/install/share/rclpy/local_setup.bat
-- Installing: D:/Test/ROS_Source_Build/Debug_Python/install/share/ament_index/resource_index/packages/rclpy
-- Installing: D:/Test/ROS_Source_Build/Debug_Python/install/share/rclpy/cmake/rclpyConfig.cmake
-- Installing: D:/Test/ROS_Source_Build/Debug_Python/install/share/rclpy/cmake/rclpyConfig-version.cmake
-- Up-to-date: D:/Test/ROS_Source_Build/Debug_Python/install/share/rclpy/package.xml
Deleting file "x64\Release\INSTALL\INSTALL.tlog\unsuccessfulbuild".
Touching "x64\Release\INSTALL\INSTALL.tlog\INSTALL.lastbuildstate".
Done Building Project "D:\Test\ROS_Source_Build\Debug_Python\build\rclpy\INSTALL.vcxproj" (default targets).
Build succeeded.
0 Warning(s)
0 Error(s)
Time Elapsed 00:00:00.81
-- [ament] Deploying: D:\Test\ROS_Source_Build\Debug_Python\install\local_setup.bat
-- [ament] Deploying: D:\Test\ROS_Source_Build\Debug_Python\install\setup.bat
-- [ament] Deploying: D:\Test\ROS_Source_Build\Debug_Python\install\_order_packages.py
Process package 'demo_nodes_py' with context:
source_space => D:\Test\ROS_Source_Build\Debug_Python\src\ros2\demos\demo_nodes_py
build_space => D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py
+++ Building 'demo_nodes_py'
+++ Installing 'demo_nodes_py'
-- [ament] Deploying: D:\Test\ROS_Source_Build\Debug_Python\install\share\demo_nodes_py\package.xml
-- [ament] Deploying: D:\Test\ROS_Source_Build\Debug_Python\install\share\demo_nodes_py\environment\ament_prefix_path.bat
-- [ament] Deploying: D:\Test\ROS_Source_Build\Debug_Python\install\share\demo_nodes_py\environment\path.bat
-- [ament] Deploying: D:\Test\ROS_Source_Build\Debug_Python\install\share\demo_nodes_py\environment\pythonpath.bat
-- [ament] Deploying: D:\Test\ROS_Source_Build\Debug_Python\install\share\demo_nodes_py\local_setup.bat
==> 'D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\ament_python__install.bat C:\Python36\python_d.exe setup.py egg_info --egg-base D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py build --build-base D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build install --prefix D:\Test\ROS_Source_Build\Debug_Python\install --install-scripts D:\Test\ROS_Source_Build\Debug_Python\install\bin --record D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\install.log --single-version-externally-managed bdist_egg --dist-dir D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\dist' in 'D:\Test\ROS_Source_Build\Debug_Python\src\ros2\demos\demo_nodes_py'
running egg_info
creating D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\demo_nodes_py.egg-info
writing D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\demo_nodes_py.egg-info\PKG-INFO
writing dependency_links to D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\demo_nodes_py.egg-info\dependency_links.txt
writing entry points to D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\demo_nodes_py.egg-info\entry_points.txt
writing requirements to D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\demo_nodes_py.egg-info\requires.txt
writing top-level names to D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\demo_nodes_py.egg-info\top_level.txt
writing manifest file 'D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\demo_nodes_py.egg-info\SOURCES.txt'
package init file 'topics\__init__.py' not found (or not a regular file)
package init file 'services\__init__.py' not found (or not a regular file)
reading manifest file 'D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\demo_nodes_py.egg-info\SOURCES.txt'
running build
running build_py
creating D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build
creating D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\lib
creating D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\lib\topics
copying topics\listener.py -> D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\lib\topics
copying topics\talker.py -> D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\lib\topics
copying topics\listener_qos.py -> D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\lib\topics
copying topics\talker_qos.py -> D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\lib\topics
creating D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\lib\services
copying services\add_two_ints_client.py -> D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\lib\services
copying services\add_two_ints_client_async.py -> D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\lib\services
copying services\add_two_ints_server.py -> D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\lib\services
running install
running install_lib
running install_data
running install_egg_info
removing 'D:\Test\ROS_Source_Build\Debug_Python\install\Lib\site-packages\demo_nodes_py-0.0.0-py3.6.egg-info' (and everything under it)
Copying D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\demo_nodes_py.egg-info to D:\Test\ROS_Source_Build\Debug_Python\install\Lib\site-packages\demo_nodes_py-0.0.0-py3.6.egg-info
running install_scripts
Installing add_two_ints_client-script.py script to D:\Test\ROS_Source_Build\Debug_Python\install\lib\demo_nodes_py
Installing add_two_ints_client.exe script to D:\Test\ROS_Source_Build\Debug_Python\install\lib\demo_nodes_py
Installing add_two_ints_client_async-script.py script to D:\Test\ROS_Source_Build\Debug_Python\install\lib\demo_nodes_py
Installing add_two_ints_client_async.exe script to D:\Test\ROS_Source_Build\Debug_Python\install\lib\demo_nodes_py
Installing add_two_ints_server-script.py script to D:\Test\ROS_Source_Build\Debug_Python\install\lib\demo_nodes_py
Installing add_two_ints_server.exe script to D:\Test\ROS_Source_Build\Debug_Python\install\lib\demo_nodes_py
Installing listener-script.py script to D:\Test\ROS_Source_Build\Debug_Python\install\lib\demo_nodes_py
Installing listener.exe script to D:\Test\ROS_Source_Build\Debug_Python\install\lib\demo_nodes_py
Installing listener_qos-script.py script to D:\Test\ROS_Source_Build\Debug_Python\install\lib\demo_nodes_py
Installing listener_qos.exe script to D:\Test\ROS_Source_Build\Debug_Python\install\lib\demo_nodes_py
Installing talker-script.py script to D:\Test\ROS_Source_Build\Debug_Python\install\lib\demo_nodes_py
Installing talker.exe script to D:\Test\ROS_Source_Build\Debug_Python\install\lib\demo_nodes_py
Installing talker_qos-script.py script to D:\Test\ROS_Source_Build\Debug_Python\install\lib\demo_nodes_py
Installing talker_qos.exe script to D:\Test\ROS_Source_Build\Debug_Python\install\lib\demo_nodes_py
writing list of installed files to 'D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\install.log'
running bdist_egg
installing library code to D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg
running install_lib
creating D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64
creating D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg
creating D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\services
copying D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\lib\services\add_two_ints_client.py -> D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\services
copying D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\lib\services\add_two_ints_client_async.py -> D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\services
copying D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\lib\services\add_two_ints_server.py -> D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\services
creating D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\topics
copying D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\lib\topics\listener.py -> D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\topics
copying D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\lib\topics\listener_qos.py -> D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\topics
copying D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\lib\topics\talker.py -> D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\topics
copying D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\lib\topics\talker_qos.py -> D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\topics
byte-compiling D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\services\add_two_ints_client.py to add_two_ints_client.cpython-36.pyc
byte-compiling D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\services\add_two_ints_client_async.py to add_two_ints_client_async.cpython-36.pyc
byte-compiling D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\services\add_two_ints_server.py to add_two_ints_server.cpython-36.pyc
byte-compiling D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\topics\listener.py to listener.cpython-36.pyc
byte-compiling D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\topics\listener_qos.py to listener_qos.cpython-36.pyc
byte-compiling D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\topics\talker.py to talker.cpython-36.pyc
byte-compiling D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\topics\talker_qos.py to talker_qos.cpython-36.pyc
installing package data to D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg
creating D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\share
creating D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\share\demo_nodes_py
copying package.xml -> D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\share\demo_nodes_py
creating D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\share\ament_index
creating D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\share\ament_index\resource_index
creating D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\share\ament_index\resource_index\packages
copying resource\demo_nodes_py -> D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\share\ament_index\resource_index\packages
creating D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\EGG-INFO
copying D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\demo_nodes_py.egg-info\PKG-INFO -> D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\EGG-INFO
copying D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\demo_nodes_py.egg-info\SOURCES.txt -> D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\EGG-INFO
copying D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\demo_nodes_py.egg-info\dependency_links.txt -> D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\EGG-INFO
copying D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\demo_nodes_py.egg-info\entry_points.txt -> D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\EGG-INFO
copying D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\demo_nodes_py.egg-info\requires.txt -> D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\EGG-INFO
copying D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\demo_nodes_py.egg-info\top_level.txt -> D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg\EGG-INFO
zip_safe flag not set; analyzing archive contents...
creating D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\dist
creating 'D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\dist\demo_nodes_py-0.0.0-py3.6.egg' and adding 'D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg' to it
removing 'D:\Test\ROS_Source_Build\Debug_Python\build\demo_nodes_py\build\bdist.win-amd64\egg' (and everything under it)
mrutyu1987:
@mrutyu1987 sorry looks like ther was a typo in my message. can you try the same thing with
-DCMAKE_BUILD_TYPE=Debug ?
You should see
Found PythonExtra: _d.pyd
@marguedas
In the build command i’m using
–cmake-args -DCMAKE-BUILD_TYPE=Debug
isn’t it correct?
Regards,
MJay
the name of the cmake variable is CMAKE_BUILD_TYPE (with only underscores) (CMAKE_BUILD_TYPE — CMake 3.5.2 Documentation ). Right now it is trying to build in “None” that’s why the libraries dont have the right suffix
@marguedas
thanks now i can see the file. But I get the following runtime
error attached
screenshot. Should this go on different thread?
Regards,
Mjay
hmm that looks a lot like an issue I faced recently convert bool to int to fix failure on windshield by mikaelarguedas · Pull Request #101 · ros2/rclpy · GitHub
Can you try to apply the same change and see if you still have the same error ?
Yes..still the same error.
Regards,
MJay
Yeah let’s move it to a different thread then.
Can you open an issue on rclpy with:
your configuration:
Windows version
Visual Studio version
Python version
which rmw_implementation you use
the exact list of commands you ran
a stacktrace (or the callstack from Visual Studio debugger)
if it works in Release mode but not in Debug mode
if it works when you build master instead of beta2
Any other information you think will be useful for us to reproduce your issue.
Thanks!
@marguedas Thanks for your assistance. I will create a new thread for the issue under rclpy
