The ROS PMC meeting for this week was on Tuesday. The notes from the meeting are available at ROS 2 PMC weekly meeting agenda - May 20, 2025
PMC Business
- No formal PMC business today.
Ongoing Tasks
Buildfarm:
- PTAL: Buildfarm Issues Triage Sheet
- @cottsay believes that the rmw_cyclone_dds issue is due to lack of isolation and that using
rmw_test_fixturewill resolve it - @mjcarroll hasn’t had a change to look at the python failures, coverage jobs have been failing for quite some time, so they are going to be disabled until someone repairs and pays attention to them.
Waffle assignments:
- May 22 + May 29: @wjwwood
Rosdistro Assignments
- May 20 - May 27: @tomoyafujita + @marcogg
- Outgoing rosdistro issues: None
ROS Bosses:
- Christophe on behalf of Audrow (Humble)
- Synclast week
- Shane (Noetic)
*Final sync freee - Marco (Jazzy)
- No updates
- Yadu (Rolling)
- No updates
Kilted Development
- Distro freeze on 5/20
- Release on 5/23
Agenda Items
@JM_ROS
ROS_LOCALHOST_ONLYwas removed and deprecated before jazzy, and with kilted all checks that warned you, that you use an outdated feature were also removed. The problem that I see now, is that about every stackoverflow post, and chatgpt tell you to use ROS_LOCALHOST_ONLY and that a user has no way any more to figure out that setting the env variable does nothing. I therefore propose, to keep warnings on outdated env variables basically forever in the client libraries** -
L-turtle name selection
As a reminder, ROS PMC meetings are open to the public, though only committers and members may speak without being called on. If you have topics that you would like discussed, feel free to respond here.
