The ROS PMC meeting for this week was on Tuesday. The notes from the meeting are available at ROS 2 PMC weekly meeting agenda - April 22, 2025
PMC Business
- Formal Decision: @ahcorde is the sole nominee for ROS representative to TGC
- Formal Decision: Add
rosidl_rustto REP 2005 (ROS Project Charter - article 4.9.ii) - There is a TGC Meeting this week, @mjcarroll to circulate update slides
Ongoing Tasks
- Buildfarm:
- PTAL: Buildfarm Issues Triage Sheet
- Increase Rci_release timeout 👨🌾 Increase timeout for Rci__nightly-release_ubuntu_noble_amd64 by Blast545 · Pull Request #323 · ros2/ros_buildfarm_config · GitHub
- Increases build times from 300 to 360 minutes on the buildfarm as we have recently been timing out. Likely due to the addition of
rmw_zenohto the test matrix. - @cottsay reports that test parallelization should help better help resource utilization once all isolation patches have landed.
- Test to be disabled + added to kilted board:
- RHEL rmw_cyclonedds problem
- Reported issues with jetson and ARM compilation:
- ARM Binaries Not Functioning on Jetson Platforms (Nav2/MPPI) · Issue #1092 · ros-infrastructure/ros_buildfarm · GitHub
- Addition of new server instances in AWS have more architecture-specific flags than Jetson or RPi boards have.
- Short term fix is to remove the new AWS instances temporarily, long term fix is to ensure that builds only use a specific subset of arch-flags when building generic binaries.
- Waffle assignments:
- April 24 + May 1: @MichaelOrlov
- Rosdistro Assignments
- April 22 - April 29: @cottsay + @mjcarroll
- Outgoing rosdistro issues: None
- ROS Bosses:
- Audrow (Humble)
- Shane (Noetic)
- Noetic Syncthis week, freeze today
- @sloretz to close feature PRs on ROS 1 repos
- Marco (Jazzy)
- Yadu (Rolling)
Kilted Development
- Next milestone will be branching for kilted and bumps for package versions in rolling.
- Scheduled for yesterday, didn’t happen
- Two critical fixes in rmw_desert and rmw_gurumdds to eliminate cyclic dependencies.
- Connextdds now works in arm64, rebuild started this morning, scaled to meet demand
- Plan to run migration today once critical mass of arm64 builds
- Next steps:
- Beta announcement on Monday.
- We have regressions that need to be addressed
Agenda Items
- @tomoyafujita -
ros2 service info -vsupport- What information should be presented when running
ros2 service info -vdepending on the middleware implementation? - https://github.com/ros2/rmw/pull/371#issuecomment-2763634820
- Conclusion: by default, the user should really on see things that are potentially useful when instancing things in ROS. If there are implementation-specific details, those are still potentially useful, but should be hidden behind a higher verbosity level flag.
- @mjcarroll ROS 2 Migration Pain Points
- @peci1 has put together a good list of pain points they have run into with ROS 2 migration. Things on this list that aren’t currently represented in issue trackers should probably be turned into issues.
- This is worth reading over to see if there are easy documentation gaps to address
- @claraberendsen Windows 2025 on ci.ros2.org.
- We now have a CI machine configured for Windows 2025 (Windows 11)
- We will run a few nightlies to find regressions between Windows 10 + Windows 11
- @mjcarroll Informal ROSCon Talk Proposal brainstorming
As a reminder, ROS PMC meetings are open to the public, though only committers and members may speak without being called on. If you have topics that you would like discussed, feel free to respond here.
