ROS Kubernetes Deployment Tutorial (#2)
Hi, ROS and Kubernetes users
I would like to share a couple of updates for tutorial how to deploy ROS 2 with Kubernetes including answering the question at ROSCon 2023.
ROS 2 GUI Display Access
see deployment description ROS 2 turtlesim and rqt
ROS provides many useful tools via GUI such as rqt, rviz and GUI application like turtlesim. This example deploys ROS 2 turtlesim application container bound to the node which has display, and access the xserver from the container, application container can display the turtlesim on the display. At the same time, it will bring up rqt to monitor the topic on the same node which has display. To control the capability such as which node has display , it will use node labels to describe the capability and at the deployment we can select this label as application container requirements.
ROS 2 Zero Copy Data Sharing
This was originally questioned during ROSCon 2023 Talk ROS with Kubernetes / KubeEdge, now we have practical procedure how to use those feature with Kubernetes.
see deployment description ROS 2 Zero Copy Data Sharing
Fast-DDS can achieve zero copy feature without any daemon process running, that makes it easier to use this feature in the container.
If you are interested, please subscribe GitHub - fujitatomoya/ros_k8s: Kuberenetes / ROS&ROS2 Cluster Samples :smile:
thanks,
Tomoya
Hi Tomoya,
I have a question for your implementation.
As I seen your picture, Primary node and Worker node are connected by LAN, which mean it would be totally different host.
How they can zero copy for the message?
BR,
Mark
@Bonggyu_Choi
in that case, of course we cannot use zero copy. (I never said we can do that.)
as you can see the zero copy diagram, Shared Memory is used when publisher and subscriber containers are in the same pod.
please take a look at ros_k8s/docs/ROS2_Deployment_Intermediate.md at master · fujitatomoya/ros_k8s · GitHub for more details.
@tomoyafujita
Thanks for clarification. Can you let me know how much performance is improved before ?
I hope to know you also tried it with video stream also.
BR,
Mark
maybe https://www.eprosima.com/index.php/resources-all/performance/eprosima-fast-dds-performance should explain well.
Hi fujita,
Many thanks !
