Gamepad Control for PiPER Manipulator
1. Abstract
This document implements intuitive control of the PiPER robotic arm using a standard gamepad. With a common gamepad, you can operate the PiPER manipulator in a visualized environment, delivering a precise and intuitive control experience.
Tags
PiPER Manipulator, Gamepad Teleoperation, Joint Control, Pose Control, Gripper Control, Forward & Inverse Kinematics
2. Repositories
- Navigation Repository: GitHub - agilexrobotics/Agilex-College: Agilex College · GitHub
- Project Repository: GitHub - kehuanjack/Gamepad_PiPER: This project implements the functionality of teleoperating a PiPER robotic arm using a gamepad. · GitHub
3. Function Demo
4. Environment Setup
- OS: Ubuntu 20.04 or later
- Python Environment: Python 3.9 or later. Anaconda or Miniconda is recommended
Clone the project and enter the root directory:
git clone https://github.com/kehuanjack/Gamepad_PiPER.git
cd Gamepad_PiPER
Install common dependencies and kinematics libraries (choose one option; pytracik is recommended):
Option 1: Based on pinocchio
(Python == 3.9; requires piper_ros and sourcing the ROS workspace, otherwise meshes will not be found)
conda create -n test_pinocchio python=3.9.* -y
conda activate test_pinocchio
pip3 install -r requirements_common.txt --upgrade
conda install pinocchio=3.6.0 -c conda-forge
pip install meshcat
pip install casadi
In main.py and main_virtual.py, select:from src.gamepad_pin import RoboticArmController
Option 2: Based on PyRoKi
(Python >= 3.10)
conda create -n test_pyroki python=3.10.* -y
conda activate test_pyroki
pip3 install pyroki@git+https://github.com/chungmin99/pyroki.git@f234516
In main.py and main_virtual.py, select:from src.gamepad_limit import RoboticArmController orfrom src.gamepad_no_limit import RoboticArmController
Option 3: Based on cuRobo
(Python >= 3.8; CUDA 11.8 recommended)
conda create -n test_curobo python=3.10.* -y
conda activate test_curobo
sudo apt install git-lfs && cd ../
git clone https://github.com/NVlabs/curobo.git && cd curobo
pip3 install "numpy<2.0" "torch==2.0.0" pytest lark
pip3 install -e . --no-build-isolation
python3 -m pytest .
cd ../Gamepad_PiPER
In main.py and main_virtual.py, select:from src.gamepad_curobo import RoboticArmController
Option 4: Based on pytracik
(Python >= 3.10)
conda create -n test_tracik python=3.10.* -y
conda activate test_tracik
git clone https://github.com/chenhaox/pytracik.git
cd pytracik
pip install -r requirements.txt
sudo apt install g++ libboost-all-dev libeigen3-dev liborocos-kdl-dev libnlopt-dev libnlopt-cxx-dev
python setup_linux.py install --user
In main.py and main_virtual.py, select:from src.gamepad_trac_ik import RoboticArmController
5. Execution Steps
Connect manipulator and activate CAN interface:
sudo ip link set can0 up type can bitrate 1000000 -
Connect gamepad:Connect the gamepad to the PC via USB or Bluetooth.
Launch control script:Run
python3 main.pyorpython3 main_virtual.pyin the project directory.It is recommended to test withmain_virtual.pyfirst in simulation mode. -
Verify gamepad connection:Check console output to confirm the gamepad is recognized.
Web visualization:Open a browser and go to
http://localhost:8080to view the manipulator status. -
Start control:Operate the manipulator according to the gamepad mapping.
6. Gamepad Control Instructions
6.1 Button Mapping
| Button | Short Press Function | Long Press Function |
| HOME | Connect / Disconnect manipulator | None |
| START | Switch high-level control mode (Joint / Pose) | Switch low-level control mode (Joint / Pose) |
| BACK | Switch low-level command mode (Position-Velocity 0x00 / Fast Response 0xAD) | None |
| Y | Go to home position | None |
| A | Save current position | Clear current saved position |
| B | Restore previous saved position | None |
| X | Switch playback order | Clear all saved positions |
| LB | Increase speed factor (high-level) | Decrease speed factor (high-level) |
| RB | Increase movement speed (low-level) | Decrease movement speed (low-level) |
6.2 Joystick & Trigger Functions
| Control | Joint Mode | Pose Mode |
| Left Joystick | J1 (Base rotation): Left / RightJ2 (Shoulder): Up / Down | End-effector X / Y translation |
| Right Joystick | J3 (Elbow): Up / DownJ6 (Wrist rotation): Left / Right | End-effector Z translation & Z-axis rotation |
| D-Pad | J4 (Wrist yaw): Left / RightJ5 (Wrist pitch): Up / Down | End-effector X / Y-axis rotation |
| Left Trigger (LT) | Close gripper | Close gripper |
| Right Trigger (RT) | Open gripper | Open gripper |
6.3 Special Functions
6.3.1 Gripper Control
- Gripper opening range: 0–100%
- Quick toggle: When fully open (100%) or fully closed (0%), a quick press and release of the trigger toggles the state.
6.3.2 Speed Control
- Speed factor: 0.25x, 0.5x, 1.0x, 2.0x, 3.0x, 4.0x, 5.0x (adjust with LB)
- Movement speed: 10%–100% (adjust with RB)
6.3.3 Position Memory
- Supports saving multiple waypoints
- Supports forward and reverse playback
Notes
- You may run
main_virtual.pyfirst to test in simulation. - For first-time use, start with low speed and increase gradually after familiarization.
- Keep a safe distance during operation. Do not approach the moving manipulator.
- Numerical solutions may cause large joint jumps near singularities — maintain safe distance.
- Fast response mode (0xAD) is dangerous. Use with extreme caution and keep clear.
- If using pinocchio, source the ROS workspace of the manipulator in advance, otherwise meshes will not be detected.
