Problem with RVIZ and ROS fom source
I have successfully compiled ROS lunar in archlinux, already have done some PR in github to update the packages to python3.
Now I have a big problem with xacro and I don’t know why..
... logging to /home/patrick/.ros/log/74169546-c973-11e7-82e7-f8da0c93ee61/roslaunch-dell-26975.log
Checking log directory for disk usage. This may take awhile.
Press Ctrl-C to interrupt
Done checking log file disk usage. Usage is <1GB.
  File "/mnt/hd/ros_ws/lunar/install_isolated/share/xacro/xacro.py", line 55, in <module>
    import xacro
  File "/mnt/hd/ros_ws/lunar/install_isolated/lib/python3.6/site-packages/xacro/__init__.py", line 35, in <module>
    import glob
  File "/usr/lib/python3.6/glob.py", line 5, in <module>
    import fnmatch
ModuleNotFoundError: No module named 'fnmatch'
Invalid <param> tag: Cannot load command parameter [robot_description]: command [/mnt/hd/ros_ws/lunar/install_isolated/share/xacro/xacro.py /mnt/hd/ros_ws/lunar/install_isolated/share/bluerov_ros_playground/model/BlueRov2.urdf.xacro] returned with code [1].
Param xml is <param command="$(find xacro)/xacro.py $(arg model)" name="robot_description"/>
The traceback for the exception was written to the log file
I can import xacro, fnmatch and glob in python2 and python3 after sourcing setup.zsh.
PYTHONPATH = /mnt/hd/ros_ws/lunar/install_isolated/lib/python3.6/site-packages
log: http://ix.io/Cgq
Thanks @patrickelectric for the report. However we ask that you please ask questions on http://answers.ros.org following our support guidelines: Support - ROS Wiki
ROS Discourse is for news and general interest discussions. ROS Answers provides a forum which can be filtered by tags to make sure the relevant people can find and/or answer the question, and not overload everyone with hundreds of posts.
(To reproduce manually with a minimal example you can try to source your workspace and run rospack find xacro and if it fails look at if you can import it with the resulting PYTHONPATH)
Sorry for that, thanks @marguedas, I’ll ask there.
