Weβre happy to announce a new Iron release
The latest sync brings 28 new packages and 188 updates to ROS 2 Iron Irwini. This sync was tagged as iron/2023-07-17 .
Package Updates for iron
Added Packages [28]:
- ros-iron-catch-ros2: 0.1.0-1
- ros-iron-catch-ros2-dbgsym: 0.1.0-1
- ros-iron-depthai-bridge: 2.7.4-1
- ros-iron-depthai-bridge-dbgsym: 2.7.4-1
- ros-iron-depthai-descriptions: 2.7.4-1
- ros-iron-depthai-examples: 2.7.4-1
- ros-iron-depthai-examples-dbgsym: 2.7.4-1
- ros-iron-depthai-filters: 2.7.4-1
- ros-iron-depthai-filters-dbgsym: 2.7.4-1
- ros-iron-depthai-ros: 2.7.4-1
- ros-iron-depthai-ros-driver: 2.7.4-1
- ros-iron-depthai-ros-driver-dbgsym: 2.7.4-1
- ros-iron-depthai-ros-msgs: 2.7.4-1
- ros-iron-depthai-ros-msgs-dbgsym: 2.7.4-1
- ros-iron-executive-smach: 3.0.3-1
- ros-iron-librealsense2: 2.54.1-2
- ros-iron-librealsense2-dbgsym: 2.54.1-2
- ros-iron-realsense2-camera: 4.54.1-2
- ros-iron-realsense2-camera-dbgsym: 4.54.1-2
- ros-iron-realsense2-camera-msgs: 4.54.1-2
- ros-iron-realsense2-camera-msgs-dbgsym: 4.54.1-2
- ros-iron-realsense2-description: 4.54.1-2
- ros-iron-smach: 3.0.3-1
- ros-iron-smach-msgs: 3.0.3-1
- ros-iron-smach-msgs-dbgsym: 3.0.3-1
- ros-iron-smach-ros: 3.0.3-1
- ros-iron-twist-mux-msgs: 3.0.1-1
- ros-iron-twist-mux-msgs-dbgsym: 3.0.1-1
Updated Packages [188]:
- ros-iron-ackermann-steering-controller: 3.10.1-1 β 3.11.0-1
- ros-iron-ackermann-steering-controller-dbgsym: 3.10.1-1 β 3.11.0-1
- ros-iron-admittance-controller: 3.10.1-1 β 3.11.0-1
- ros-iron-admittance-controller-dbgsym: 3.10.1-1 β 3.11.0-1
- ros-iron-behaviortree-cpp: 4.3.1-1 β 4.3.3-1
- ros-iron-behaviortree-cpp-dbgsym: 4.3.1-1 β 4.3.3-1
- ros-iron-behaviortree-cpp-v3: 3.8.3-5 β 3.8.4-1
- ros-iron-behaviortree-cpp-v3-dbgsym: 3.8.3-5 β 3.8.4-1
- ros-iron-bicycle-steering-controller: 3.10.1-1 β 3.11.0-1
- ros-iron-bicycle-steering-controller-dbgsym: 3.10.1-1 β 3.11.0-1
- ros-iron-diff-drive-controller: 3.10.1-1 β 3.11.0-1
- ros-iron-diff-drive-controller-dbgsym: 3.10.1-1 β 3.11.0-1
- ros-iron-effort-controllers: 3.10.1-1 β 3.11.0-1
- ros-iron-effort-controllers-dbgsym: 3.10.1-1 β 3.11.0-1
- ros-iron-examples-tf2-py: 0.31.3-1 β 0.31.4-1
- ros-iron-fastrtps-cmake-module: 3.0.0-2 β 3.0.1-1
- ros-iron-force-torque-sensor-broadcaster: 3.10.1-1 β 3.11.0-1
- ros-iron-force-torque-sensor-broadcaster-dbgsym: 3.10.1-1 β 3.11.0-1
- ros-iron-forward-command-controller: 3.10.1-1 β 3.11.0-1
- ros-iron-forward-command-controller-dbgsym: 3.10.1-1 β 3.11.0-1
- ros-iron-foxglove-bridge: 0.6.3-1 β 0.6.4-1
- ros-iron-foxglove-bridge-dbgsym: 0.6.3-1 β 0.6.4-1
- ros-iron-geometry2: 0.31.3-1 β 0.31.4-1
- ros-iron-gripper-controllers: 3.10.1-1 β 3.11.0-1
- ros-iron-gripper-controllers-dbgsym: 3.10.1-1 β 3.11.0-1
- ros-iron-gurumdds-cmake-module: 4.2.0-3 β 5.0.0-1
- ros-iron-imu-sensor-broadcaster: 3.10.1-1 β 3.11.0-1
- ros-iron-imu-sensor-broadcaster-dbgsym: 3.10.1-1 β 3.11.0-1
- ros-iron-joint-state-broadcaster: 3.10.1-1 β 3.11.0-1
- ros-iron-joint-state-broadcaster-dbgsym: 3.10.1-1 β 3.11.0-1
- ros-iron-joint-trajectory-controller: 3.10.1-1 β 3.11.0-1
- ros-iron-joint-trajectory-controller-dbgsym: 3.10.1-1 β 3.11.0-1
- ros-iron-launch: 2.0.1-2 β 2.0.2-1
- ros-iron-launch-pytest: 2.0.1-2 β 2.0.2-1
- ros-iron-launch-testing: 2.0.1-2 β 2.0.2-1
- ros-iron-launch-testing-ament-cmake: 2.0.1-2 β 2.0.2-1
- ros-iron-launch-xml: 2.0.1-2 β 2.0.2-1
- ros-iron-launch-yaml: 2.0.1-2 β 2.0.2-1
- ros-iron-mcap-vendor: 0.22.1-1 β 0.22.2-1
- ros-iron-mcap-vendor-dbgsym: 0.22.1-1 β 0.22.2-1
- ros-iron-mrpt2: 2.9.3-1 β 2.9.4-1
- ros-iron-mrpt2-dbgsym: 2.9.3-1 β 2.9.4-1
- ros-iron-position-controllers: 3.10.1-1 β 3.11.0-1
- ros-iron-position-controllers-dbgsym: 3.10.1-1 β 3.11.0-1
- ros-iron-rclcpp: 21.0.1-1 β 21.0.2-1
- ros-iron-rclcpp-action: 21.0.1-1 β 21.0.2-1
- ros-iron-rclcpp-action-dbgsym: 21.0.1-1 β 21.0.2-1
- ros-iron-rclcpp-components: 21.0.1-1 β 21.0.2-1
- ros-iron-rclcpp-components-dbgsym: 21.0.1-1 β 21.0.2-1
- ros-iron-rclcpp-dbgsym: 21.0.1-1 β 21.0.2-1
- ros-iron-rclcpp-lifecycle: 21.0.1-1 β 21.0.2-1
- ros-iron-rclcpp-lifecycle-dbgsym: 21.0.1-1 β 21.0.2-1
- ros-iron-rclpy: 4.1.1-1 β 4.1.2-1
- ros-iron-rmf-api-msgs: 0.1.0-1 β 0.1.1-1
- ros-iron-rmf-building-sim-common: 2.1.0-1 β 2.1.1-1
- ros-iron-rmf-building-sim-common-dbgsym: 2.1.0-1 β 2.1.1-1
- ros-iron-rmf-building-sim-gz-classic-plugins: 2.1.0-1 β 2.1.1-1
- ros-iron-rmf-building-sim-gz-classic-plugins-dbgsym: 2.1.0-1 β 2.1.1-1
- ros-iron-rmf-building-sim-gz-plugins: 2.1.0-1 β 2.1.1-1
- ros-iron-rmf-building-sim-gz-plugins-dbgsym: 2.1.0-1 β 2.1.1-1
- ros-iron-rmf-robot-sim-common: 2.1.0-1 β 2.1.1-1
- ros-iron-rmf-robot-sim-common-dbgsym: 2.1.0-1 β 2.1.1-1
- ros-iron-rmf-robot-sim-gz-classic-plugins: 2.1.0-1 β 2.1.1-1
- ros-iron-rmf-robot-sim-gz-classic-plugins-dbgsym: 2.1.0-1 β 2.1.1-1
- ros-iron-rmf-robot-sim-gz-plugins: 2.1.0-1 β 2.1.1-1
- ros-iron-rmf-robot-sim-gz-plugins-dbgsym: 2.1.0-1 β 2.1.1-1
- ros-iron-rmf-task: 2.2.0-1 β 2.2.1-1
- ros-iron-rmf-task-dbgsym: 2.2.0-1 β 2.2.1-1
- ros-iron-rmf-task-sequence: 2.2.0-1 β 2.2.1-1
- ros-iron-rmf-task-sequence-dbgsym: 2.2.0-1 β 2.2.1-1
- ros-iron-rmw-gurumdds-cpp: 4.2.0-3 β 5.0.0-1
- ros-iron-rmw-gurumdds-cpp-dbgsym: 4.2.0-3 β 5.0.0-1
- ros-iron-ros2-controllers: 3.10.1-1 β 3.11.0-1
- ros-iron-ros2-controllers-test-nodes: 3.10.1-1 β 3.11.0-1
- ros-iron-ros2action: 0.25.1-1 β 0.25.2-1
- ros-iron-ros2bag: 0.22.1-1 β 0.22.2-1
- ros-iron-ros2cli: 0.25.1-1 β 0.25.2-1
- ros-iron-ros2cli-test-interfaces: 0.25.1-1 β 0.25.2-1
- ros-iron-ros2cli-test-interfaces-dbgsym: 0.25.1-1 β 0.25.2-1
- ros-iron-ros2component: 0.25.1-1 β 0.25.2-1
- ros-iron-ros2doctor: 0.25.1-1 β 0.25.2-1
- ros-iron-ros2interface: 0.25.1-1 β 0.25.2-1
- ros-iron-ros2lifecycle: 0.25.1-1 β 0.25.2-1
- ros-iron-ros2lifecycle-test-fixtures: 0.25.1-1 β 0.25.2-1
- ros-iron-ros2lifecycle-test-fixtures-dbgsym: 0.25.1-1 β 0.25.2-1
- ros-iron-ros2multicast: 0.25.1-1 β 0.25.2-1
- ros-iron-ros2node: 0.25.1-1 β 0.25.2-1
- ros-iron-ros2param: 0.25.1-1 β 0.25.2-1
- ros-iron-ros2pkg: 0.25.1-1 β 0.25.2-1
- ros-iron-ros2run: 0.25.1-1 β 0.25.2-1
- ros-iron-ros2service: 0.25.1-1 β 0.25.2-1
- ros-iron-ros2topic: 0.25.1-1 β 0.25.2-1
- ros-iron-rosbag2: 0.22.1-1 β 0.22.2-1
- ros-iron-rosbag2-compression: 0.22.1-1 β 0.22.2-1
- ros-iron-rosbag2-compression-dbgsym: 0.22.1-1 β 0.22.2-1
- ros-iron-rosbag2-compression-zstd: 0.22.1-1 β 0.22.2-1
- ros-iron-rosbag2-compression-zstd-dbgsym: 0.22.1-1 β 0.22.2-1
- ros-iron-rosbag2-cpp: 0.22.1-1 β 0.22.2-1
- ros-iron-rosbag2-cpp-dbgsym: 0.22.1-1 β 0.22.2-1
- ros-iron-rosbag2-examples-cpp: 0.22.1-1 β 0.22.2-1
- ros-iron-rosbag2-examples-cpp-dbgsym: 0.22.1-1 β 0.22.2-1
- ros-iron-rosbag2-examples-py: 0.22.1-1 β 0.22.2-1
- ros-iron-rosbag2-interfaces: 0.22.1-1 β 0.22.2-1
- ros-iron-rosbag2-interfaces-dbgsym: 0.22.1-1 β 0.22.2-1
- ros-iron-rosbag2-performance-benchmarking: 0.22.1-1 β 0.22.2-1
- ros-iron-rosbag2-performance-benchmarking-msgs: 0.22.1-1 β 0.22.2-1
- ros-iron-rosbag2-py: 0.22.1-1 β 0.22.2-1
- ros-iron-rosbag2-storage: 0.22.1-1 β 0.22.2-1
- ros-iron-rosbag2-storage-dbgsym: 0.22.1-1 β 0.22.2-1
- ros-iron-rosbag2-storage-default-plugins: 0.22.1-1 β 0.22.2-1
- ros-iron-rosbag2-storage-mcap: 0.22.1-1 β 0.22.2-1
- ros-iron-rosbag2-storage-mcap-dbgsym: 0.22.1-1 β 0.22.2-1
- ros-iron-rosbag2-storage-sqlite3: 0.22.1-1 β 0.22.2-1
- ros-iron-rosbag2-storage-sqlite3-dbgsym: 0.22.1-1 β 0.22.2-1
- ros-iron-rosbag2-test-common: 0.22.1-1 β 0.22.2-1
- ros-iron-rosbag2-test-msgdefs: 0.22.1-1 β 0.22.2-1
- ros-iron-rosbag2-test-msgdefs-dbgsym: 0.22.1-1 β 0.22.2-1
- ros-iron-rosbag2-tests: 0.22.1-1 β 0.22.2-1
- ros-iron-rosbag2-transport: 0.22.1-1 β 0.22.2-1
- ros-iron-rosbag2-transport-dbgsym: 0.22.1-1 β 0.22.2-1
- ros-iron-rosidl-adapter: 4.0.0-2 β 4.0.1-1
- ros-iron-rosidl-cli: 4.0.0-2 β 4.0.1-1
- ros-iron-rosidl-cmake: 4.0.0-2 β 4.0.1-1
- ros-iron-rosidl-generator-c: 4.0.0-2 β 4.0.1-1
- ros-iron-rosidl-generator-cpp: 4.0.0-2 β 4.0.1-1
- ros-iron-rosidl-generator-type-description: 4.0.0-2 β 4.0.1-1
- ros-iron-rosidl-parser: 4.0.0-2 β 4.0.1-1
- ros-iron-rosidl-pycommon: 4.0.0-2 β 4.0.1-1
- ros-iron-rosidl-runtime-c: 4.0.0-2 β 4.0.1-1
- ros-iron-rosidl-runtime-c-dbgsym: 4.0.0-2 β 4.0.1-1
- ros-iron-rosidl-runtime-cpp: 4.0.0-2 β 4.0.1-1
- ros-iron-rosidl-typesupport-c: 3.0.0-2 β 3.0.1-1
- ros-iron-rosidl-typesupport-c-dbgsym: 3.0.0-2 β 3.0.1-1
- ros-iron-rosidl-typesupport-cpp: 3.0.0-2 β 3.0.1-1
- ros-iron-rosidl-typesupport-cpp-dbgsym: 3.0.0-2 β 3.0.1-1
- ros-iron-rosidl-typesupport-fastrtps-c: 3.0.0-2 β 3.0.1-1
- ros-iron-rosidl-typesupport-fastrtps-c-dbgsym: 3.0.0-2 β 3.0.1-1
- ros-iron-rosidl-typesupport-fastrtps-cpp: 3.0.0-2 β 3.0.1-1
- ros-iron-rosidl-typesupport-fastrtps-cpp-dbgsym: 3.0.0-2 β 3.0.1-1
- ros-iron-rosidl-typesupport-interface: 4.0.0-2 β 4.0.1-1
- ros-iron-rosidl-typesupport-introspection-c: 4.0.0-2 β 4.0.1-1
- ros-iron-rosidl-typesupport-introspection-c-dbgsym: 4.0.0-2 β 4.0.1-1
- ros-iron-rosidl-typesupport-introspection-cpp: 4.0.0-2 β 4.0.1-1
- ros-iron-rosidl-typesupport-introspection-cpp-dbgsym: 4.0.0-2 β 4.0.1-1
- ros-iron-rqt-bag: 1.3.2-1 β 1.3.3-1
- ros-iron-rqt-bag-plugins: 1.3.2-1 β 1.3.3-1
- ros-iron-rqt-joint-trajectory-controller: 3.10.1-1 β 3.11.0-1
- ros-iron-rviz-assimp-vendor: 12.4.0-2 β 12.4.1-1
- ros-iron-rviz-common: 12.4.0-2 β 12.4.1-1
- ros-iron-rviz-common-dbgsym: 12.4.0-2 β 12.4.1-1
- ros-iron-rviz-default-plugins: 12.4.0-2 β 12.4.1-1
- ros-iron-rviz-default-plugins-dbgsym: 12.4.0-2 β 12.4.1-1
- ros-iron-rviz-ogre-vendor: 12.4.0-2 β 12.4.1-1
- ros-iron-rviz-ogre-vendor-dbgsym: 12.4.0-2 β 12.4.1-1
- ros-iron-rviz-rendering: 12.4.0-2 β 12.4.1-1
- ros-iron-rviz-rendering-dbgsym: 12.4.0-2 β 12.4.1-1
- ros-iron-rviz-rendering-tests: 12.4.0-2 β 12.4.1-1
- ros-iron-rviz-visual-testing-framework: 12.4.0-2 β 12.4.1-1
- ros-iron-rviz2: 12.4.0-2 β 12.4.1-1
- ros-iron-rviz2-dbgsym: 12.4.0-2 β 12.4.1-1
- ros-iron-shared-queues-vendor: 0.22.1-1 β 0.22.2-1
- ros-iron-sqlite3-vendor: 0.22.1-1 β 0.22.2-1
- ros-iron-steering-controllers-library: 3.10.1-1 β 3.11.0-1
- ros-iron-steering-controllers-library-dbgsym: 3.10.1-1 β 3.11.0-1
- ros-iron-tf2: 0.31.3-1 β 0.31.4-1
- ros-iron-tf2-bullet: 0.31.3-1 β 0.31.4-1
- ros-iron-tf2-dbgsym: 0.31.3-1 β 0.31.4-1
- ros-iron-tf2-eigen: 0.31.3-1 β 0.31.4-1
- ros-iron-tf2-eigen-kdl: 0.31.3-1 β 0.31.4-1
- ros-iron-tf2-eigen-kdl-dbgsym: 0.31.3-1 β 0.31.4-1
- ros-iron-tf2-geometry-msgs: 0.31.3-1 β 0.31.4-1
- ros-iron-tf2-kdl: 0.31.3-1 β 0.31.4-1
- ros-iron-tf2-msgs: 0.31.3-1 β 0.31.4-1
- ros-iron-tf2-msgs-dbgsym: 0.31.3-1 β 0.31.4-1
- ros-iron-tf2-py: 0.31.3-1 β 0.31.4-1
- ros-iron-tf2-py-dbgsym: 0.31.3-1 β 0.31.4-1
- ros-iron-tf2-ros: 0.31.3-1 β 0.31.4-1
- ros-iron-tf2-ros-dbgsym: 0.31.3-1 β 0.31.4-1
- ros-iron-tf2-ros-py: 0.31.3-1 β 0.31.4-1
- ros-iron-tf2-sensor-msgs: 0.31.3-1 β 0.31.4-1
- ros-iron-tf2-tools: 0.31.3-1 β 0.31.4-1
- ros-iron-tricycle-controller: 3.10.1-1 β 3.11.0-1
- ros-iron-tricycle-controller-dbgsym: 3.10.1-1 β 3.11.0-1
- ros-iron-tricycle-steering-controller: 3.10.1-1 β 3.11.0-1
- ros-iron-tricycle-steering-controller-dbgsym: 3.10.1-1 β 3.11.0-1
- ros-iron-velocity-controllers: 3.10.1-1 β 3.11.0-1
- ros-iron-velocity-controllers-dbgsym: 3.10.1-1 β 3.11.0-1
- ros-iron-zstd-vendor: 0.22.1-1 β 0.22.2-1
Removed Packages [0]:
- Adam Serafin
- Aditya Pande
- Alejandro Hernandez Cordero
- Audrow Nash
- Bence Magyar
- Davide Faconti
- Denis Ε togl
- Dharini Dutia
- Emerson Knapp
- Foxglove
- Grey
- Isaac I. Y. Saito
- Isaac Saito
- Ivan Paunovic
- John Hurliman
- Jose-Luis Blanco-Claraco
- LibRealSense ROS Team
- Luca Della Vedova
- Michael Jeronimo
- Michael Orlov
- Morgan Quigley
- Nick Morales
- ROS Tooling Working Group
- Sachin Guruswamy
- Shane Loretz
- Yadunund
- Youngjin Yun
- geoff
- sachin
