Weβre happy to announce 10 new packages and 46 updates are now available in ROS Noetic. This sync was tagged as noetic/2024-03-07.
Added Packages [10]:
- ros-noetic-atf: 0.1.1-1
- ros-noetic-atf-core: 0.1.1-1
- ros-noetic-atf-metrics: 0.1.1-1
- ros-noetic-atf-msgs: 0.1.1-1
- ros-noetic-atf-plotter: 0.1.1-1
- ros-noetic-atf-recorder-plugins: 0.1.1-1
- ros-noetic-atf-test: 0.1.1-1
- ros-noetic-atf-test-tools: 0.1.1-1
- ros-noetic-etsi-its-rviz-plugins: 2.0.1-1
- ros-noetic-py-binding-tools: 1.0.0-1
Updated Packages [46]:
- ros-noetic-cras-cpp-common: 2.3.8-1 β 2.3.9-1
- ros-noetic-cras-docs-common: 2.3.8-1 β 2.3.9-1
- ros-noetic-cras-py-common: 2.3.8-1 β 2.3.9-1
- ros-noetic-cras-topic-tools: 2.3.8-1 β 2.3.9-1
- ros-noetic-etsi-its-cam-coding: 2.0.0-1 β 2.0.1-1
- ros-noetic-etsi-its-cam-conversion: 2.0.0-1 β 2.0.1-1
- ros-noetic-etsi-its-cam-msgs: 2.0.0-1 β 2.0.1-1
- ros-noetic-etsi-its-coding: 2.0.0-1 β 2.0.1-1
- ros-noetic-etsi-its-conversion: 2.0.0-1 β 2.0.1-1
- ros-noetic-etsi-its-denm-coding: 2.0.0-1 β 2.0.1-1
- ros-noetic-etsi-its-denm-conversion: 2.0.0-1 β 2.0.1-1
- ros-noetic-etsi-its-denm-msgs: 2.0.0-1 β 2.0.1-1
- ros-noetic-etsi-its-messages: 2.0.0-1 β 2.0.1-1
- ros-noetic-etsi-its-msgs: 2.0.0-1 β 2.0.1-1
- ros-noetic-etsi-its-msgs-utils: 2.0.0-1 β 2.0.1-1
- ros-noetic-etsi-its-primitives-conversion: 2.0.0-1 β 2.0.1-1
- ros-noetic-gnss-info: 1.0.1-1 β 1.0.2-1
- ros-noetic-gnss-info-msgs: 1.0.1-1 β 1.0.2-1
- ros-noetic-gnsstk-ros: 1.0.1-1 β 1.0.2-1
- ros-noetic-image-transport-codecs: 2.3.8-1 β 2.3.9-1
- ros-noetic-libmavconn: 1.17.0-1 β 1.18.0-1
- ros-noetic-mavlink: 2023.9.9-1 β 2024.3.3-1
- ros-noetic-mavros: 1.17.0-1 β 1.18.0-1
- ros-noetic-mavros-extras: 1.17.0-1 β 1.18.0-1
- ros-noetic-mavros-msgs: 1.17.0-1 β 1.18.0-1
- ros-noetic-mrpt2: 2.11.9-1 β 2.11.11-1
- ros-noetic-mvsim: 0.8.3-1 β 0.9.1-2
- ros-noetic-ntrip-client: 1.2.0-1 β 1.3.0-1
- ros-noetic-rtabmap: 0.21.3-1 β 0.21.4-1
- ros-noetic-rtabmap-conversions: 0.21.3-4 β 0.21.4-1
- ros-noetic-rtabmap-costmap-plugins: 0.21.3-4 β 0.21.4-1
- ros-noetic-rtabmap-demos: 0.21.3-4 β 0.21.4-1
- ros-noetic-rtabmap-examples: 0.21.3-4 β 0.21.4-1
- ros-noetic-rtabmap-launch: 0.21.3-4 β 0.21.4-1
- ros-noetic-rtabmap-legacy: 0.21.3-4 β 0.21.4-1
- ros-noetic-rtabmap-msgs: 0.21.3-4 β 0.21.4-1
- ros-noetic-rtabmap-odom: 0.21.3-4 β 0.21.4-1
- ros-noetic-rtabmap-python: 0.21.3-4 β 0.21.4-1
- ros-noetic-rtabmap-ros: 0.21.3-4 β 0.21.4-1
- ros-noetic-rtabmap-rviz-plugins: 0.21.3-4 β 0.21.4-1
- ros-noetic-rtabmap-slam: 0.21.3-4 β 0.21.4-1
- ros-noetic-rtabmap-sync: 0.21.3-4 β 0.21.4-1
- ros-noetic-rtabmap-util: 0.21.3-4 β 0.21.4-1
- ros-noetic-rtabmap-viz: 0.21.3-4 β 0.21.4-1
- ros-noetic-test-mavros: 1.17.0-1 β 1.18.0-1
- ros-noetic-ur-client-library: 1.3.4-1 β 1.3.5-1
Removed Packages [0]:
- Felix Exner
- Florian Weisshardt
- Jean-Pierre Busch
- Jose-Luis Blanco-Claraco
- Martin Pecka
- Mathieu Labbe
- Rob Fisher
- Robert Haschke
- Vladimir Ermakov
