We’re happy to announce 10 new packages and 79 updates are now available in ROS Noetic. This sync was tagged as noetic/2024-12-19.
Added Packages [10]:
- ros-noetic-compass-conversions: 2.0.1-1
- ros-noetic-etsi-its-mapem-ts-coding: 3.0.0-1
- ros-noetic-etsi-its-mapem-ts-conversion: 3.0.0-1
- ros-noetic-etsi-its-mapem-ts-msgs: 3.0.0-1
- ros-noetic-etsi-its-spatem-ts-coding: 3.0.0-1
- ros-noetic-etsi-its-spatem-ts-conversion: 3.0.0-1
- ros-noetic-etsi-its-spatem-ts-msgs: 3.0.0-1
- ros-noetic-jsk-rosbag-tools: 2.2.15-4
- ros-noetic-magnetic-model: 2.0.1-1
- ros-noetic-magnetometer-pipeline: 2.0.1-1
Updated Packages [79]:
- ros-noetic-audio-video-recorder: 2.2.12-1 → 2.2.15-4
- ros-noetic-cmd-vel-smoother: 0.1.17-2 → 0.1.18-1
- ros-noetic-compass-msgs: 1.0.3-1 → 2.0.1-1
- ros-noetic-contact-states-observer: 0.1.17-2 → 0.1.18-1
- ros-noetic-cras-cpp-common: 2.4.5-1 → 2.4.7-1
- ros-noetic-cras-docs-common: 2.4.5-1 → 2.4.7-1
- ros-noetic-cras-py-common: 2.4.5-1 → 2.4.7-1
- ros-noetic-cras-topic-tools: 2.4.5-1 → 2.4.7-1
- ros-noetic-dynamic-tf-publisher: 2.2.12-1 → 2.2.15-4
- ros-noetic-eiquadprog: 1.2.8-1 → 1.2.9-1
- ros-noetic-etsi-its-cam-coding: 2.4.0-1 → 3.0.0-1
- ros-noetic-etsi-its-cam-conversion: 2.4.0-1 → 3.0.0-1
- ros-noetic-etsi-its-cam-msgs: 2.4.0-1 → 3.0.0-1
- ros-noetic-etsi-its-cam-ts-coding: 2.4.0-1 → 3.0.0-1
- ros-noetic-etsi-its-cam-ts-conversion: 2.4.0-1 → 3.0.0-1
- ros-noetic-etsi-its-cam-ts-msgs: 2.4.0-1 → 3.0.0-1
- ros-noetic-etsi-its-coding: 2.4.0-1 → 3.0.0-1
- ros-noetic-etsi-its-conversion: 2.4.0-1 → 3.0.0-1
- ros-noetic-etsi-its-cpm-ts-coding: 2.4.0-1 → 3.0.0-1
- ros-noetic-etsi-its-cpm-ts-conversion: 2.4.0-1 → 3.0.0-1
- ros-noetic-etsi-its-cpm-ts-msgs: 2.4.0-1 → 3.0.0-1
- ros-noetic-etsi-its-denm-coding: 2.4.0-1 → 3.0.0-1
- ros-noetic-etsi-its-denm-conversion: 2.4.0-1 → 3.0.0-1
- ros-noetic-etsi-its-denm-msgs: 2.4.0-1 → 3.0.0-1
- ros-noetic-etsi-its-messages: 2.4.0-1 → 3.0.0-1
- ros-noetic-etsi-its-msgs: 2.4.0-1 → 3.0.0-1
- ros-noetic-etsi-its-msgs-utils: 2.4.0-1 → 3.0.0-1
- ros-noetic-etsi-its-primitives-conversion: 2.4.0-1 → 3.0.0-1
- ros-noetic-etsi-its-rviz-plugins: 2.4.0-1 → 3.0.0-1
- ros-noetic-etsi-its-vam-ts-coding: 2.4.0-1 → 3.0.0-1
- ros-noetic-etsi-its-vam-ts-conversion: 2.4.0-1 → 3.0.0-1
- ros-noetic-etsi-its-vam-ts-msgs: 2.4.0-1 → 3.0.0-1
- ros-noetic-eus-nlopt: 0.1.17-2 → 0.1.18-1
- ros-noetic-eus-qp: 0.1.17-2 → 0.1.18-1
- ros-noetic-eus-qpoases: 0.1.17-2 → 0.1.18-1
- ros-noetic-eus-teleop: 0.1.17-2 → 0.1.18-1
- ros-noetic-image-transport-codecs: 2.4.5-1 → 2.4.7-1
- ros-noetic-image-view2: 2.2.12-1 → 2.2.15-4
- ros-noetic-joy-mouse: 0.1.17-2 → 0.1.18-1
- ros-noetic-jsk-calibration: 0.1.17-2 → 0.1.18-1
- ros-noetic-jsk-common: 2.2.12-1 → 2.2.15-4
- ros-noetic-jsk-control: 0.1.17-2 → 0.1.18-1
- ros-noetic-jsk-data: 2.2.12-1 → 2.2.15-4
- ros-noetic-jsk-footstep-controller: 0.1.17-2 → 0.1.18-1
- ros-noetic-jsk-footstep-planner: 0.1.17-2 → 0.1.18-1
- ros-noetic-jsk-ik-server: 0.1.17-2 → 0.1.18-1
- ros-noetic-jsk-interactive: 2.1.8-1 → 2.1.10-1
- ros-noetic-jsk-interactive-marker: 2.1.8-1 → 2.1.10-1
- ros-noetic-jsk-interactive-test: 2.1.8-1 → 2.1.10-1
- ros-noetic-jsk-network-tools: 2.2.12-1 → 2.2.15-4
- ros-noetic-jsk-rqt-plugins: 2.1.8-1 → 2.1.10-1
- ros-noetic-jsk-rviz-plugins: 2.1.8-1 → 2.1.10-1
- ros-noetic-jsk-teleop-joy: 0.1.17-2 → 0.1.18-1
- ros-noetic-jsk-tilt-laser: 2.2.12-1 → 2.2.15-4
- ros-noetic-jsk-tools: 2.2.12-1 → 2.2.15-4
- ros-noetic-jsk-topic-tools: 2.2.12-1 → 2.2.15-4
- ros-noetic-jsk-visualization: 2.1.8-1 → 2.1.10-1
- ros-noetic-magnetometer-compass: 1.0.3-1 → 2.0.1-1
- ros-noetic-mrpt-apps: 2.14.5-1 → 2.14.7-1
- ros-noetic-mrpt-libapps: 2.14.5-1 → 2.14.7-1
- ros-noetic-mrpt-libbase: 2.14.5-1 → 2.14.7-1
- ros-noetic-mrpt-libgui: 2.14.5-1 → 2.14.7-1
- ros-noetic-mrpt-libhwdrivers: 2.14.5-1 → 2.14.7-1
- ros-noetic-mrpt-libmaps: 2.14.5-1 → 2.14.7-1
- ros-noetic-mrpt-libmath: 2.14.5-1 → 2.14.7-1
- ros-noetic-mrpt-libnav: 2.14.5-1 → 2.14.7-1
- ros-noetic-mrpt-libobs: 2.14.5-1 → 2.14.7-1
- ros-noetic-mrpt-libopengl: 2.14.5-1 → 2.14.7-1
- ros-noetic-mrpt-libposes: 2.14.5-1 → 2.14.7-1
- ros-noetic-mrpt-libros-bridge: 2.14.5-1 → 2.14.7-1
- ros-noetic-mrpt-libslam: 2.14.5-1 → 2.14.7-1
- ros-noetic-mrpt-libtclap: 2.14.5-1 → 2.14.7-1
- ros-noetic-multi-map-server: 2.2.12-1 → 2.2.15-4
- ros-noetic-mvsim: 0.11.2-1 → 0.12.1-1
- ros-noetic-pinocchio: 2.6.21-1 → 3.3.0-1
- ros-noetic-python-mrpt: 2.14.5-1 → 2.14.7-1
- ros-noetic-ur-client-library: 1.4.0-1 → 1.5.0-1
- ros-noetic-urg-stamped: 0.3.0-1 → 0.4.0-1
- ros-noetic-virtual-force-publisher: 2.2.12-1 → 2.2.15-4
Removed Packages [0]:
- Atsushi Watanabe
- Felix Exner
- Guilhem Saurel
- Iori Yanokura
- Jean-Pierre Busch
- Jose-Luis Blanco-Claraco
- Justin Carpentier
- Kei Okada
- Martin Pecka
- Noda Shintaro
- Ryohei Ueda
- Shingo Kitagawa
- Shunichi Nozawa
- YoheiKakiuchi
- Yuki Furuta
- Yusuke Furuta
- furuta
- nozawa
