We’re happy to announce the next update of ROS Melodic. There are 33 new packages as well as 257 updated packages. Full details are below.
Package Updates for melodic
Added Packages [33]:
- ros-melodic-hdf5-map-io: 1.0.0-2
- ros-melodic-hironx-calibration: 2.2.0-1
- ros-melodic-hironx-moveit-config: 2.2.0-1
- ros-melodic-hironx-ros-bridge: 2.2.0-1
- ros-melodic-iris-lama: 1.0.0-1
- ros-melodic-iris-lama-ros: 1.0.0-1
- ros-melodic-label-manager: 1.0.0-2
- ros-melodic-mbf-recovery-behaviors: 0.1.0-1
- ros-melodic-mesh-msgs: 1.0.0-2
- ros-melodic-mesh-msgs-hdf5: 1.0.0-2
- ros-melodic-mesh-msgs-transform: 1.0.0-2
- ros-melodic-mesh-tools: 1.0.0-2
- ros-melodic-moveback-recovery: 0.1.0-1
- ros-melodic-moveit-opw-kinematics-plugin: 0.2.1-1
- ros-melodic-moveit-ros-occupancy-map-monitor: 1.0.3-2
- ros-melodic-novatel-oem7-driver: 1.1.0-1
- ros-melodic-novatel-oem7-msgs: 1.1.0-1
- ros-melodic-plotjuggler-msgs: 0.1.1-1
- ros-melodic-rc-silhouettematch-client: 3.0.1-1
- ros-melodic-ros-ethercat-eml: 0.3.2-5
- ros-melodic-rqt-virtual-joy: 0.1.2-1
- ros-melodic-rtmros-hironx: 2.2.0-1
- ros-melodic-rviz-map-plugin: 1.0.0-2
- ros-melodic-rviz-mesh-plugin: 1.0.0-2
- ros-melodic-sdc21x0: 1.0.5-1
- ros-melodic-tf2-urdf: 0.1.0-1
- ros-melodic-timed-roslaunch: 0.1.4-1
- ros-melodic-uos-common-urdf: 1.0.0-1
- ros-melodic-uos-diffdrive-teleop: 1.0.0-1
- ros-melodic-uos-freespace: 1.0.0-1
- ros-melodic-uos-gazebo-worlds: 1.0.0-1
- ros-melodic-uos-maps: 1.0.0-1
- ros-melodic-uos-tools: 1.0.0-1
Updated Packages [257]:
- ros-melodic-ackermann-steering-controller: 0.16.0-1 → 0.17.0-1
- ros-melodic-actionlib-lisp: 0.2.12-1 → 0.2.13-1
- ros-melodic-audio-capture: 0.3.4-1 → 0.3.5-1
- ros-melodic-audio-common: 0.3.4-1 → 0.3.5-1
- ros-melodic-audio-common-msgs: 0.3.4-1 → 0.3.5-1
- ros-melodic-audio-play: 0.3.4-1 → 0.3.5-1
- ros-melodic-behaviortree-cpp-v3: 3.1.0-2 → 3.5.0-1
- ros-melodic-bond: 1.8.3-0 → 1.8.5-1
- ros-melodic-bond-core: 1.8.3-0 → 1.8.5-1
- ros-melodic-bondcpp: 1.8.3-0 → 1.8.5-1
- ros-melodic-bondpy: 1.8.3-0 → 1.8.5-1
- ros-melodic-camera-calibration: 1.14.0-1 → 1.15.0-1
- ros-melodic-can-msgs: 0.8.2-1 → 0.8.3-1
- ros-melodic-canopen-402: 0.8.2-1 → 0.8.3-1
- ros-melodic-canopen-chain-node: 0.8.2-1 → 0.8.3-1
- ros-melodic-canopen-master: 0.8.2-1 → 0.8.3-1
- ros-melodic-canopen-motor-node: 0.8.2-1 → 0.8.3-1
- ros-melodic-chomp-motion-planner: 1.0.2-1 → 1.0.3-2
- ros-melodic-cl-tf: 0.2.12-1 → 0.2.13-1
- ros-melodic-cl-tf2: 0.2.12-1 → 0.2.13-1
- ros-melodic-cl-transforms: 0.2.12-1 → 0.2.13-1
- ros-melodic-cl-transforms-stamped: 0.2.12-1 → 0.2.13-1
- ros-melodic-cl-urdf: 0.2.12-1 → 0.2.13-1
- ros-melodic-cl-utils: 0.2.12-1 → 0.2.13-1
- ros-melodic-code-coverage: 0.4.0-1 → 0.4.2-1
- ros-melodic-combined-robot-hw: 0.18.0-1 → 0.18.1-1
- ros-melodic-combined-robot-hw-tests: 0.18.0-1 → 0.18.1-1
- ros-melodic-control-box-rst: 0.0.2-1 → 0.0.6-1
- ros-melodic-controller-interface: 0.18.0-1 → 0.18.1-1
- ros-melodic-controller-manager: 0.18.0-1 → 0.18.1-1
- ros-melodic-controller-manager-msgs: 0.18.0-1 → 0.18.1-1
- ros-melodic-controller-manager-tests: 0.18.0-1 → 0.18.1-1
- ros-melodic-costmap-cspace: 0.8.2-1 → 0.8.7-1
- ros-melodic-depth-image-proc: 1.14.0-1 → 1.15.0-1
- ros-melodic-diff-drive-controller: 0.16.0-1 → 0.17.0-1
- ros-melodic-drone-wrapper: 1.3.1-1 → 1.3.2-1
- ros-melodic-effort-controllers: 0.16.0-1 → 0.17.0-1
- ros-melodic-fcl-catkin: 0.6.0-1 → 0.6.1-2
- ros-melodic-force-torque-sensor-controller: 0.16.0-1 → 0.17.0-1
- ros-melodic-forward-command-controller: 0.16.0-1 → 0.17.0-1
- ros-melodic-four-wheel-steering-controller: 0.16.0-1 → 0.17.0-1
- ros-melodic-gazebo-dev: 2.8.6-1 → 2.8.7-1
- ros-melodic-gazebo-msgs: 2.8.6-1 → 2.8.7-1
- ros-melodic-gazebo-plugins: 2.8.6-1 → 2.8.7-1
- ros-melodic-gazebo-ros: 2.8.6-1 → 2.8.7-1
- ros-melodic-gazebo-ros-control: 2.8.6-1 → 2.8.7-1
- ros-melodic-gazebo-ros-pkgs: 2.8.6-1 → 2.8.7-1
- ros-melodic-geometric-shapes: 0.6.1-0 → 0.6.3-1
- ros-melodic-gripper-action-controller: 0.16.0-1 → 0.17.0-1
- ros-melodic-hardware-interface: 0.18.0-1 → 0.18.1-1
- ros-melodic-hector-compressed-map-transport: 0.4.0-1 → 0.4.1-1
- ros-melodic-hector-geotiff: 0.4.0-1 → 0.4.1-1
- ros-melodic-hector-geotiff-plugins: 0.4.0-1 → 0.4.1-1
- ros-melodic-hector-imu-attitude-to-tf: 0.4.0-1 → 0.4.1-1
- ros-melodic-hector-imu-tools: 0.4.0-1 → 0.4.1-1
- ros-melodic-hector-map-server: 0.4.0-1 → 0.4.1-1
- ros-melodic-hector-map-tools: 0.4.0-1 → 0.4.1-1
- ros-melodic-hector-mapping: 0.4.0-1 → 0.4.1-1
- ros-melodic-hector-marker-drawing: 0.4.0-1 → 0.4.1-1
- ros-melodic-hector-nav-msgs: 0.4.0-1 → 0.4.1-1
- ros-melodic-hector-slam: 0.4.0-1 → 0.4.1-1
- ros-melodic-hector-slam-launch: 0.4.0-1 → 0.4.1-1
- ros-melodic-hector-trajectory-server: 0.4.0-1 → 0.4.1-1
- ros-melodic-hrpsys: 315.15.0-2 → 315.15.0-8
- ros-melodic-husky-base: 0.4.2-1 → 0.4.3-1
- ros-melodic-husky-bringup: 0.4.2-1 → 0.4.3-1
- ros-melodic-husky-control: 0.4.2-1 → 0.4.3-1
- ros-melodic-husky-description: 0.4.2-1 → 0.4.3-1
- ros-melodic-husky-desktop: 0.4.2-1 → 0.4.3-1
- ros-melodic-husky-gazebo: 0.4.2-1 → 0.4.3-1
- ros-melodic-husky-msgs: 0.4.2-1 → 0.4.3-1
- ros-melodic-husky-navigation: 0.4.2-1 → 0.4.3-1
- ros-melodic-husky-robot: 0.4.2-1 → 0.4.3-1
- ros-melodic-husky-simulator: 0.4.2-1 → 0.4.3-1
- ros-melodic-husky-viz: 0.4.2-1 → 0.4.3-1
- ros-melodic-image-exposure-msgs: 0.14.0-1 → 0.14.1-1
- ros-melodic-image-pipeline: 1.14.0-1 → 1.15.0-1
- ros-melodic-image-proc: 1.14.0-1 → 1.15.0-1
- ros-melodic-image-publisher: 1.14.0-1 → 1.15.0-1
- ros-melodic-image-rotate: 1.14.0-1 → 1.15.0-1
- ros-melodic-image-view: 1.14.0-1 → 1.15.0-1
- ros-melodic-imu-complementary-filter: 1.2.1-1 → 1.2.2-1
- ros-melodic-imu-filter-madgwick: 1.2.1-1 → 1.2.2-1
- ros-melodic-imu-sensor-controller: 0.16.0-1 → 0.17.0-1
- ros-melodic-imu-tools: 1.2.1-1 → 1.2.2-1
- ros-melodic-interactive-marker-tutorials: 0.10.3-0 → 0.10.5-1
- ros-melodic-jackal-control: 0.6.4-3 → 0.7.0-1
- ros-melodic-jackal-description: 0.6.4-3 → 0.7.0-1
- ros-melodic-jackal-msgs: 0.6.4-3 → 0.7.0-1
- ros-melodic-jackal-navigation: 0.6.4-3 → 0.7.0-1
- ros-melodic-jackal-tutorials: 0.6.4-3 → 0.7.0-1
- ros-melodic-jderobot-assets: 1.0.1-1 → 1.0.2-1
- ros-melodic-jderobot-drones: 1.3.1-1 → 1.3.2-1
- ros-melodic-joint-limits-interface: 0.18.0-1 → 0.18.1-1
- ros-melodic-joint-state-controller: 0.16.0-1 → 0.17.0-1
- ros-melodic-joint-trajectory-controller: 0.16.0-1 → 0.17.0-1
- ros-melodic-joystick-interrupt: 0.8.2-1 → 0.8.7-1
- ros-melodic-libmavconn: 1.1.0-1 → 1.2.0-1
- ros-melodic-librviz-tutorial: 0.10.3-0 → 0.10.5-1
- ros-melodic-map-organizer: 0.8.2-1 → 0.8.7-1
- ros-melodic-mapviz: 1.2.0-1 → 1.3.0-1
- ros-melodic-mapviz-plugins: 1.2.0-1 → 1.3.0-1
- ros-melodic-marti-data-structures: 2.12.0-1 → 2.13.1-1
- ros-melodic-mavlink: 2020.4.4-1 → 2020.5.21-1
- ros-melodic-mavros: 1.1.0-1 → 1.2.0-1
- ros-melodic-mavros-extras: 1.1.0-1 → 1.2.0-1
- ros-melodic-mavros-msgs: 1.1.0-1 → 1.2.0-1
- ros-melodic-mbf-abstract-core: 0.3.1-1 → 0.3.2-1
- ros-melodic-mbf-abstract-nav: 0.3.1-1 → 0.3.2-1
- ros-melodic-mbf-costmap-core: 0.3.1-1 → 0.3.2-1
- ros-melodic-mbf-costmap-nav: 0.3.1-1 → 0.3.2-1
- ros-melodic-mbf-msgs: 0.3.1-1 → 0.3.2-1
- ros-melodic-mbf-simple-nav: 0.3.1-1 → 0.3.2-1
- ros-melodic-mbf-utility: 0.3.1-1 → 0.3.2-1
- ros-melodic-mcl-3dl: 0.2.3-1 → 0.2.4-1
- ros-melodic-mir-actions: 1.0.4-1 → 1.0.5-1
- ros-melodic-mir-description: 1.0.4-1 → 1.0.5-1
- ros-melodic-mir-driver: 1.0.4-1 → 1.0.5-1
- ros-melodic-mir-dwb-critics: 1.0.4-1 → 1.0.5-1
- ros-melodic-mir-gazebo: 1.0.4-1 → 1.0.5-1
- ros-melodic-mir-msgs: 1.0.4-1 → 1.0.5-1
- ros-melodic-mir-navigation: 1.0.4-1 → 1.0.5-1
- ros-melodic-mir-robot: 1.0.4-1 → 1.0.5-1
- ros-melodic-move-base-flex: 0.3.1-1 → 0.3.2-1
- ros-melodic-moveit: 1.0.2-1 → 1.0.3-2
- ros-melodic-moveit-chomp-optimizer-adapter: 1.0.2-1 → 1.0.3-2
- ros-melodic-moveit-commander: 1.0.2-1 → 1.0.3-2
- ros-melodic-moveit-controller-manager-example: 1.0.2-1 → 1.0.3-2
- ros-melodic-moveit-core: 1.0.2-1 → 1.0.3-2
- ros-melodic-moveit-experimental: 1.0.2-1 → 1.0.3-2
- ros-melodic-moveit-fake-controller-manager: 1.0.2-1 → 1.0.3-2
- ros-melodic-moveit-kinematics: 1.0.2-1 → 1.0.3-2
- ros-melodic-moveit-msgs: 0.10.0-0 → 0.10.1-1
- ros-melodic-moveit-planners: 1.0.2-1 → 1.0.3-2
- ros-melodic-moveit-planners-chomp: 1.0.2-1 → 1.0.3-2
- ros-melodic-moveit-planners-ompl: 1.0.2-1 → 1.0.3-2
- ros-melodic-moveit-plugins: 1.0.2-1 → 1.0.3-2
- ros-melodic-moveit-python: 0.3.3-1 → 0.3.4-1
- ros-melodic-moveit-ros: 1.0.2-1 → 1.0.3-2
- ros-melodic-moveit-ros-benchmarks: 1.0.2-1 → 1.0.3-2
- ros-melodic-moveit-ros-control-interface: 1.0.2-1 → 1.0.3-2
- ros-melodic-moveit-ros-manipulation: 1.0.2-1 → 1.0.3-2
- ros-melodic-moveit-ros-move-group: 1.0.2-1 → 1.0.3-2
- ros-melodic-moveit-ros-perception: 1.0.2-1 → 1.0.3-2
- ros-melodic-moveit-ros-planning: 1.0.2-1 → 1.0.3-2
- ros-melodic-moveit-ros-planning-interface: 1.0.2-1 → 1.0.3-2
- ros-melodic-moveit-ros-robot-interaction: 1.0.2-1 → 1.0.3-2
- ros-melodic-moveit-ros-visualization: 1.0.2-1 → 1.0.3-2
- ros-melodic-moveit-ros-warehouse: 1.0.2-1 → 1.0.3-2
- ros-melodic-moveit-runtime: 1.0.2-1 → 1.0.3-2
- ros-melodic-moveit-setup-assistant: 1.0.2-1 → 1.0.3-2
- ros-melodic-moveit-simple-controller-manager: 1.0.2-1 → 1.0.3-2
- ros-melodic-multires-image: 1.2.0-1 → 1.3.0-1
- ros-melodic-neonavigation: 0.8.2-1 → 0.8.7-1
- ros-melodic-neonavigation-common: 0.8.2-1 → 0.8.7-1
- ros-melodic-neonavigation-launch: 0.8.2-1 → 0.8.7-1
- ros-melodic-neonavigation-rviz-plugins: 0.3.0-0 → 0.3.1-1
- ros-melodic-obj-to-pointcloud: 0.8.2-1 → 0.8.7-1
- ros-melodic-octomap-mapping: 0.6.4-1 → 0.6.5-1
- ros-melodic-octomap-msgs: 0.3.3-1 → 0.3.5-1
- ros-melodic-octomap-ros: 0.4.0-0 → 0.4.1-1
- ros-melodic-octomap-server: 0.6.4-1 → 0.6.5-1
- ros-melodic-open-karto: 1.2.0-0 → 1.2.1-1
- ros-melodic-openhrp3: 3.1.9-4 → 3.1.9-5
- ros-melodic-pilz-control: 0.5.14-1 → 0.5.16-1
- ros-melodic-pilz-robots: 0.5.14-1 → 0.5.16-1
- ros-melodic-pilz-status-indicator-rqt: 0.5.14-1 → 0.5.16-1
- ros-melodic-pilz-testutils: 0.5.14-1 → 0.5.16-1
- ros-melodic-pilz-utils: 0.5.14-1 → 0.5.16-1
- ros-melodic-planner-cspace: 0.8.2-1 → 0.8.7-1
- ros-melodic-plotjuggler: 2.6.3-1 → 2.8.0-1
- ros-melodic-pointgrey-camera-description: 0.14.0-1 → 0.14.1-1
- ros-melodic-pointgrey-camera-driver: 0.14.0-1 → 0.14.1-1
- ros-melodic-position-controllers: 0.16.0-1 → 0.17.0-1
- ros-melodic-prbt-gazebo: 0.5.14-1 → 0.5.16-1
- ros-melodic-prbt-hardware-support: 0.5.14-1 → 0.5.16-1
- ros-melodic-prbt-ikfast-manipulator-plugin: 0.5.14-1 → 0.5.16-1
- ros-melodic-prbt-moveit-config: 0.5.14-1 → 0.5.16-1
- ros-melodic-prbt-support: 0.5.14-1 → 0.5.16-1
- ros-melodic-rc-common-msgs: 0.4.1-1 → 0.5.0-1
- ros-melodic-rc-hand-eye-calibration-client: 2.7.0-1 → 3.0.1-1
- ros-melodic-rc-pick-client: 2.7.0-1 → 3.0.1-1
- ros-melodic-rc-roi-manager-gui: 2.7.0-1 → 3.0.1-1
- ros-melodic-rc-tagdetect-client: 2.7.0-1 → 3.0.1-1
- ros-melodic-rc-visard: 2.7.0-1 → 3.0.1-1
- ros-melodic-rc-visard-description: 2.7.0-1 → 3.0.1-1
- ros-melodic-rc-visard-driver: 2.7.0-1 → 3.0.1-1
- ros-melodic-ridgeback-control: 0.2.3-1 → 0.3.0-1
- ros-melodic-ridgeback-description: 0.2.3-1 → 0.3.0-1
- ros-melodic-ridgeback-desktop: 0.1.1-1 → 0.1.2-1
- ros-melodic-ridgeback-msgs: 0.2.3-1 → 0.3.0-1
- ros-melodic-ridgeback-navigation: 0.2.3-1 → 0.3.0-1
- ros-melodic-ridgeback-viz: 0.1.1-1 → 0.1.2-1
- ros-melodic-robot-calibration: 0.6.2-1 → 0.6.3-1
- ros-melodic-robot-calibration-msgs: 0.6.2-1 → 0.6.3-1
- ros-melodic-ros-canopen: 0.8.2-1 → 0.8.3-1
- ros-melodic-ros-control: 0.18.0-1 → 0.18.1-1
- ros-melodic-ros-controllers: 0.16.0-1 → 0.17.0-1
- ros-melodic-ros-emacs-utils: 0.4.13-0 → 0.4.14-1
- ros-melodic-rosapi: 0.11.5-1 → 0.11.8-1
- ros-melodic-rosbridge-library: 0.11.5-1 → 0.11.8-1
- ros-melodic-rosbridge-msgs: 0.11.5-1 → 0.11.8-1
- ros-melodic-rosbridge-server: 0.11.5-1 → 0.11.8-1
- ros-melodic-rosbridge-suite: 0.11.5-1 → 0.11.8-1
- ros-melodic-rosemacs: 0.4.13-0 → 0.4.14-1
- ros-melodic-roslisp-common: 0.2.12-1 → 0.2.13-1
- ros-melodic-roslisp-repl: 0.4.13-0 → 0.4.14-1
- ros-melodic-roslisp-utilities: 0.2.12-1 → 0.2.13-1
- ros-melodic-rospy-message-converter: 0.5.0-0 → 0.5.1-1
- ros-melodic-rqt-controller-manager: 0.18.0-1 → 0.18.1-1
- ros-melodic-rqt-drone-teleop: 1.3.1-1 → 1.3.2-1
- ros-melodic-rqt-ground-robot-teleop: 1.3.1-1 → 1.3.2-1
- ros-melodic-rqt-joint-trajectory-controller: 0.16.0-1 → 0.17.0-1
- ros-melodic-rviz: 1.13.9-2 → 1.13.12-1
- ros-melodic-rviz-imu-plugin: 1.2.1-1 → 1.2.2-1
- ros-melodic-rviz-plugin-tutorials: 0.10.3-0 → 0.10.5-1
- ros-melodic-rviz-python-tutorial: 0.10.3-0 → 0.10.5-1
- ros-melodic-safety-limiter: 0.8.2-1 → 0.8.7-1
- ros-melodic-sick-scan: 1.4.2-1 → 1.6.0-1
- ros-melodic-sick-tim: 0.0.16-1 → 0.0.17-1
- ros-melodic-slime-ros: 0.4.13-0 → 0.4.14-1
- ros-melodic-slime-wrapper: 0.4.13-0 → 0.4.14-1
- ros-melodic-smclib: 1.8.3-0 → 1.8.5-1
- ros-melodic-socketcan-bridge: 0.8.2-1 → 0.8.3-1
- ros-melodic-socketcan-interface: 0.8.2-1 → 0.8.3-1
- ros-melodic-sound-play: 0.3.4-1 → 0.3.5-1
- ros-melodic-statistics-msgs: 0.14.0-1 → 0.14.1-1
- ros-melodic-stereo-image-proc: 1.14.0-1 → 1.15.0-1
- ros-melodic-swri-console-util: 2.12.0-1 → 2.13.1-1
- ros-melodic-swri-dbw-interface: 2.12.0-1 → 2.13.1-1
- ros-melodic-swri-geometry-util: 2.12.0-1 → 2.13.1-1
- ros-melodic-swri-image-util: 2.12.0-1 → 2.13.1-1
- ros-melodic-swri-math-util: 2.12.0-1 → 2.13.1-1
- ros-melodic-swri-nodelet: 2.12.0-1 → 2.13.1-1
- ros-melodic-swri-opencv-util: 2.12.0-1 → 2.13.1-1
- ros-melodic-swri-prefix-tools: 2.12.0-1 → 2.13.1-1
- ros-melodic-swri-roscpp: 2.12.0-1 → 2.13.1-1
- ros-melodic-swri-rospy: 2.12.0-1 → 2.13.1-1
- ros-melodic-swri-route-util: 2.12.0-1 → 2.13.1-1
- ros-melodic-swri-serial-util: 2.12.0-1 → 2.13.1-1
- ros-melodic-swri-string-util: 2.12.0-1 → 2.13.1-1
- ros-melodic-swri-system-util: 2.12.0-1 → 2.13.1-1
- ros-melodic-swri-transform-util: 2.12.0-1 → 2.13.1-1
- ros-melodic-swri-yaml-util: 2.12.0-1 → 2.13.1-1
- ros-melodic-test-mavros: 1.1.0-1 → 1.2.0-1
- ros-melodic-tile-map: 1.2.0-1 → 1.3.0-1
- ros-melodic-track-odometry: 0.8.2-1 → 0.8.7-1
- ros-melodic-trajectory-tracker: 0.8.2-1 → 0.8.7-1
- ros-melodic-trajectory-tracker-rviz-plugins: 0.3.0-0 → 0.3.1-1
- ros-melodic-transmission-interface: 0.18.0-1 → 0.18.1-1
- ros-melodic-velocity-controllers: 0.16.0-1 → 0.17.0-1
- ros-melodic-visualization-marker-tutorials: 0.10.3-0 → 0.10.5-1
- ros-melodic-visualization-tutorials: 0.10.3-0 → 0.10.5-1
- ros-melodic-warehouse-ros: 0.9.3-1 → 0.9.4-1
- ros-melodic-webrtc: 59.0.3-0 → 59.0.4-1
- ros-melodic-webrtc-ros: 59.0.3-0 → 59.0.4-1
- ros-melodic-wfov-camera-msgs: 0.14.0-1 → 0.14.1-1
Removed Packages [0]:
- Alexander Gutenkunst
- Andrey Stepanov
- Armin Hornung
- Atsushi Watanabe
- Austin Hendrix
- Bence Magyar
- Chittaranjan Srinivas Swaminathan
- Christoph Rösmann
- Dave Coleman
- Davide Faconti
- Eurico Pedrosa
- Felix Ruess
- Gayane Kazhoyan
- Hans-Joachim Krauch
- Hikaru Sugiura
- Isaac I. Y. Saito
- Jeroen De Maeyer
- Jochen Sprickerhof
- Johannes Meyer
- John Hsu
- Jon Binney
- Jorge Santos
- Jose Luis Rivero
- Kei Okada
- Kris Kozak
- Marc Alban
- Martin Guenther
- Martin Günther
- Masaru Morita
- Mathias Lüdtke
- Michael Carroll
- Michael Ferguson
- Michael Görner
- Michael Lehning
- Mike Purvis
- Monika Florek-Jasinska
- MoveIt! Release Team
- Nikhil Khedekar
- NovAtel Support
- P. J. Reed
- Paul Bovbel
- Pedro Arias
- Raghavender Sahdev
- Roberto G. Valenti
- Russell Toris
- Sachin Chitta
- Sebastian Pütz
- Shadow Robot’s software team
- TORK
- Timo Röhling
- Tony Baltovski
- Vincent Rabaud
- Vincent Rousseau
- Vladimir Ermakov
- William Woodall
- Wolfgang Merkt
- daf
