We’re happy to announce 53 updated packages and one new package for Kinetic Kame
Thank you to all the package maintainers and contributors who helped make these packages available!
Package Updates for kinetic
Added Packages [1]:
- ros-kinetic-audio-to-spectrogram: 1.2.15-1
Updated Packages [53]:
- ros-kinetic-checkerboard-detector: 1.2.9-0 → 1.2.15-1
- ros-kinetic-cloudwatch-logs-common: 1.1.3-1 → 1.1.4-1
- ros-kinetic-cloudwatch-metrics-common: 1.1.3-1 → 1.1.4-1
- ros-kinetic-costmap-cspace: 0.10.1-1 → 0.10.2-1
- ros-kinetic-dataflow-lite: 1.1.3-1 → 1.1.4-1
- ros-kinetic-dynamixel-workbench: 2.0.0-0 → 2.2.0-0
- ros-kinetic-dynamixel-workbench-controllers: 2.0.0-0 → 2.2.0-0
- ros-kinetic-dynamixel-workbench-operators: 2.0.0-0 → 2.2.0-0
- ros-kinetic-dynamixel-workbench-toolbox: 2.0.0-0 → 2.2.0-0
- ros-kinetic-file-management: 1.1.3-1 → 1.1.4-1
- ros-kinetic-fkie-potree-rviz-plugin: 1.0.0-0 → 1.0.1-1
- ros-kinetic-husky-base: 0.3.7-1 → 0.3.8-1
- ros-kinetic-husky-bringup: 0.3.7-1 → 0.3.8-1
- ros-kinetic-husky-control: 0.3.7-1 → 0.3.8-1
- ros-kinetic-husky-description: 0.3.7-1 → 0.3.8-1
- ros-kinetic-husky-desktop: 0.3.7-1 → 0.3.8-1
- ros-kinetic-husky-gazebo: 0.3.7-1 → 0.3.8-1
- ros-kinetic-husky-msgs: 0.3.7-1 → 0.3.8-1
- ros-kinetic-husky-navigation: 0.3.7-1 → 0.3.8-1
- ros-kinetic-husky-robot: 0.3.7-1 → 0.3.8-1
- ros-kinetic-husky-simulator: 0.3.7-1 → 0.3.8-1
- ros-kinetic-husky-viz: 0.3.7-1 → 0.3.8-1
- ros-kinetic-imagesift: 1.2.9-0 → 1.2.15-1
- ros-kinetic-jackal-control: 0.6.6-1 → 0.6.7-1
- ros-kinetic-jackal-description: 0.6.6-1 → 0.6.7-1
- ros-kinetic-jackal-msgs: 0.6.6-1 → 0.6.7-1
- ros-kinetic-jackal-navigation: 0.6.6-1 → 0.6.7-1
- ros-kinetic-jackal-tutorials: 0.6.6-1 → 0.6.7-1
- ros-kinetic-joystick-interrupt: 0.10.1-1 → 0.10.2-1
- ros-kinetic-jsk-pcl-ros: 1.2.9-0 → 1.2.15-1
- ros-kinetic-jsk-pcl-ros-utils: 1.2.9-0 → 1.2.15-1
- ros-kinetic-jsk-perception: 1.2.9-0 → 1.2.15-1
- ros-kinetic-jsk-recognition: 1.2.9-0 → 1.2.15-1
- ros-kinetic-jsk-recognition-msgs: 1.2.9-0 → 1.2.15-1
- ros-kinetic-jsk-recognition-utils: 1.2.9-0 → 1.2.15-1
- ros-kinetic-map-organizer: 0.10.1-1 → 0.10.2-1
- ros-kinetic-mcl-3dl: 0.3.0-1 → 0.4.0-1
- ros-kinetic-neonavigation: 0.10.1-1 → 0.10.2-1
- ros-kinetic-neonavigation-common: 0.10.1-1 → 0.10.2-1
- ros-kinetic-neonavigation-launch: 0.10.1-1 → 0.10.2-1
- ros-kinetic-obj-to-pointcloud: 0.10.1-1 → 0.10.2-1
- ros-kinetic-planner-cspace: 0.10.1-1 → 0.10.2-1
- ros-kinetic-resized-image-transport: 1.2.9-0 → 1.2.15-1
- ros-kinetic-safety-limiter: 0.10.1-1 → 0.10.2-1
- ros-kinetic-track-odometry: 0.10.1-1 → 0.10.2-1
- ros-kinetic-trajectory-tracker: 0.10.1-1 → 0.10.2-1
- ros-kinetic-turtlebot3: 1.2.1-1 → 1.2.4-1
- ros-kinetic-turtlebot3-bringup: 1.2.1-1 → 1.2.4-1
- ros-kinetic-turtlebot3-description: 1.2.1-1 → 1.2.4-1
- ros-kinetic-turtlebot3-example: 1.2.1-1 → 1.2.4-1
- ros-kinetic-turtlebot3-navigation: 1.2.1-1 → 1.2.4-1
- ros-kinetic-turtlebot3-slam: 1.2.1-1 → 1.2.4-1
- ros-kinetic-turtlebot3-teleop: 1.2.1-1 → 1.2.4-1
Removed Packages [2]:
- AWS RoboMaker
- Atsushi Watanabe
- Kei Okada
- Mike Purvis
- Naoya Yamaguchi
- Paul Bovbel
- Ryohei Ueda
- Timo Röhling
- Will Son
- Yohei Kakiuchi
- Youhei Kakiuchi
