We’re happy to announce 1 new package and 74 update packages.
This is an out of cycle sync for a regression in ros_comm that effected the build of some downstream packages.
Thank you to everyone who contributed to these releases. Full details are below.
Package Updates for kinetic
Added Packages [1]:
- ros-kinetic-hfl-driver: 0.0.17-1
Updated Packages [74]:
- ros-kinetic-actionlib: 1.11.13-0 → 1.11.16-2
- ros-kinetic-amcl: 1.14.7-1 → 1.14.8-1
- ros-kinetic-base-local-planner: 1.14.7-1 → 1.14.8-1
- ros-kinetic-can-msgs: 0.7.12-1 → 0.7.13-1
- ros-kinetic-canopen-402: 0.7.12-1 → 0.7.13-1
- ros-kinetic-canopen-chain-node: 0.7.12-1 → 0.7.13-1
- ros-kinetic-canopen-master: 0.7.12-1 → 0.7.13-1
- ros-kinetic-canopen-motor-node: 0.7.12-1 → 0.7.13-1
- ros-kinetic-carrot-planner: 1.14.7-1 → 1.14.8-1
- ros-kinetic-catkin-virtualenv: 0.5.2-1 → 0.6.1-1
- ros-kinetic-clear-costmap-recovery: 1.14.7-1 → 1.14.8-1
- ros-kinetic-costmap-2d: 1.14.7-1 → 1.14.8-1
- ros-kinetic-costmap-cspace: 0.10.0-1 → 0.10.1-1
- ros-kinetic-dwa-local-planner: 1.14.7-1 → 1.14.8-1
- ros-kinetic-eigenpy: 2.3.1-3 → 2.5.0-1
- ros-kinetic-fake-localization: 1.14.7-1 → 1.14.8-1
- ros-kinetic-global-planner: 1.14.7-1 → 1.14.8-1
- ros-kinetic-jackal-control: 0.6.5-2 → 0.6.6-1
- ros-kinetic-jackal-description: 0.6.5-2 → 0.6.6-1
- ros-kinetic-jackal-gazebo: 0.3.0-0 → 0.3.1-1
- ros-kinetic-jackal-msgs: 0.6.5-2 → 0.6.6-1
- ros-kinetic-jackal-navigation: 0.6.5-2 → 0.6.6-1
- ros-kinetic-jackal-simulator: 0.3.0-0 → 0.3.1-1
- ros-kinetic-jackal-tutorials: 0.6.5-2 → 0.6.6-1
- ros-kinetic-joystick-interrupt: 0.10.0-1 → 0.10.1-1
- ros-kinetic-kinesis-manager: 2.0.1-1 → 2.0.3-1
- ros-kinetic-map-organizer: 0.10.0-1 → 0.10.1-1
- ros-kinetic-map-server: 1.14.7-1 → 1.14.8-1
- ros-kinetic-mecanum-gazebo-plugin: 0.0.3-0 → 0.0.4-1
- ros-kinetic-message-filters: 1.12.15-1 → 1.12.16-1
- ros-kinetic-move-base: 1.14.7-1 → 1.14.8-1
- ros-kinetic-move-slow-and-clear: 1.14.7-1 → 1.14.8-1
- ros-kinetic-nav-core: 1.14.7-1 → 1.14.8-1
- ros-kinetic-navfn: 1.14.7-1 → 1.14.8-1
- ros-kinetic-navigation: 1.14.7-1 → 1.14.8-1
- ros-kinetic-neonavigation: 0.10.0-1 → 0.10.1-1
- ros-kinetic-neonavigation-common: 0.10.0-1 → 0.10.1-1
- ros-kinetic-neonavigation-launch: 0.10.0-1 → 0.10.1-1
- ros-kinetic-obj-to-pointcloud: 0.10.0-1 → 0.10.1-1
- ros-kinetic-planner-cspace: 0.10.0-1 → 0.10.1-1
- ros-kinetic-ridgeback-gazebo: 0.0.3-0 → 0.0.4-1
- ros-kinetic-ridgeback-gazebo-plugins: 0.0.3-0 → 0.0.4-1
- ros-kinetic-ridgeback-simulator: 0.0.3-0 → 0.0.4-1
- ros-kinetic-robot-pose-ekf: 1.14.7-1 → 1.14.8-1
- ros-kinetic-ros-canopen: 0.7.12-1 → 0.7.13-1
- ros-kinetic-ros-comm: 1.12.15-1 → 1.12.16-1
- ros-kinetic-rosbag: 1.12.15-1 → 1.12.16-1
- ros-kinetic-rosbag-storage: 1.12.15-1 → 1.12.16-1
- ros-kinetic-rosconsole: 1.12.15-1 → 1.12.16-1
- ros-kinetic-roscpp: 1.12.15-1 → 1.12.16-1
- ros-kinetic-rosgraph: 1.12.15-1 → 1.12.16-1
- ros-kinetic-roslaunch: 1.12.15-1 → 1.12.16-1
- ros-kinetic-roslz4: 1.12.15-1 → 1.12.16-1
- ros-kinetic-rosmaster: 1.12.15-1 → 1.12.16-1
- ros-kinetic-rosmsg: 1.12.15-1 → 1.12.16-1
- ros-kinetic-rosnode: 1.12.15-1 → 1.12.16-1
- ros-kinetic-rosout: 1.12.15-1 → 1.12.16-1
- ros-kinetic-rosparam: 1.12.15-1 → 1.12.16-1
- ros-kinetic-rospy: 1.12.15-1 → 1.12.16-1
- ros-kinetic-rospy-message-converter: 0.5.2-1 → 0.5.3-1
- ros-kinetic-rosservice: 1.12.15-1 → 1.12.16-1
- ros-kinetic-rostest: 1.12.15-1 → 1.12.16-1
- ros-kinetic-rostopic: 1.12.15-1 → 1.12.16-1
- ros-kinetic-roswtf: 1.12.15-1 → 1.12.16-1
- ros-kinetic-rotate-recovery: 1.14.7-1 → 1.14.8-1
- ros-kinetic-safety-limiter: 0.10.0-1 → 0.10.1-1
- ros-kinetic-socketcan-bridge: 0.7.12-1 → 0.7.13-1
- ros-kinetic-socketcan-interface: 0.7.12-1 → 0.7.13-1
- ros-kinetic-topic-tools: 1.12.15-1 → 1.12.16-1
- ros-kinetic-track-odometry: 0.10.0-1 → 0.10.1-1
- ros-kinetic-trajectory-tracker: 0.10.0-1 → 0.10.1-1
- ros-kinetic-voxel-grid: 1.14.7-1 → 1.14.8-1
- ros-kinetic-xmlrpcpp: 1.12.15-1 → 1.12.16-1
- ros-kinetic-ypspur: 1.18.2-1 → 1.19.0-1
Removed Packages [0]:
- AWS RoboMaker
- Atsushi Watanabe
- Ben Charrow
- David V. Lu!!
- Dirk Thomas
- Evan Flynn
- Johannes Meyer
- Justin Carpentier
- Martin Günther
- Mathias Lüdtke
- Michael Carroll
- Mike Purvis
- Paul Bovbel
