We’re happy to announce 20 new packages and 64 updated packages for Kinetic.
Full details are below.
Thank you to all the maintainers and contributors who helped make these packages available!
Package Updates for kinetic
Added Packages [20]:
- ros-kinetic-autoware-can-msgs: 1.12.0-1
- ros-kinetic-autoware-config-msgs: 1.12.0-1
- ros-kinetic-autoware-external-msgs: 1.12.0-1
- ros-kinetic-autoware-map-msgs: 1.12.0-1
- ros-kinetic-autoware-msgs: 1.12.0-1
- ros-kinetic-autoware-system-msgs: 1.12.0-1
- ros-kinetic-dataflow-lite: 1.1.0-2
- ros-kinetic-file-management: 1.1.0-2
- ros-kinetic-jderobot-assets: 0.0.1-1
- ros-kinetic-laser-filters-jsk-patch: 2.1.13-1
- ros-kinetic-noid-typef-bringup: 0.0.5-1
- ros-kinetic-noid-typef-description: 0.0.5-1
- ros-kinetic-noid-typef-moveit-config: 0.0.5-1
- ros-kinetic-rc-roi-manager-gui: 2.7.0-1
- ros-kinetic-rr-control-input-manager: 0.7.2-1
- ros-kinetic-rr-openrover-driver-msgs: 0.7.2-1
- ros-kinetic-smacha: 0.5.0-1
- ros-kinetic-smacha-ros: 0.5.0-1
- ros-kinetic-tablet-socket-msgs: 1.12.0-1
- ros-kinetic-vector-map-msgs: 1.12.0-1
Updated Packages [64]:
- ros-kinetic-assimp-devel: 2.1.12-1 → 2.1.13-1
- ros-kinetic-aws-common: 2.0.0-2 → 2.1.0-1
- ros-kinetic-bayesian-belief-networks: 2.1.12-1 → 2.1.13-1
- ros-kinetic-can-msgs: 0.7.10-0 → 0.7.11-1
- ros-kinetic-canopen-402: 0.7.10-0 → 0.7.11-1
- ros-kinetic-canopen-chain-node: 0.7.10-0 → 0.7.11-1
- ros-kinetic-canopen-master: 0.7.10-0 → 0.7.11-1
- ros-kinetic-canopen-motor-node: 0.7.10-0 → 0.7.11-1
- ros-kinetic-clock-relay: 0.0.1-0 → 0.0.2-1
- ros-kinetic-cloudwatch-logger: 2.1.0-2 → 2.2.1-1
- ros-kinetic-cloudwatch-logs-common: 1.0.2-1 → 1.1.0-2
- ros-kinetic-cloudwatch-metrics-collector: 2.0.0-1 → 2.1.1-1
- ros-kinetic-cloudwatch-metrics-common: 1.0.2-1 → 1.1.0-2
- ros-kinetic-code-coverage: 0.2.3-0 → 0.2.4-1
- ros-kinetic-collada-urdf-jsk-patch: 2.1.12-1 → 2.1.13-1
- ros-kinetic-cpr-multimaster-tools: 0.0.1-0 → 0.0.2-1
- ros-kinetic-downward: 2.1.12-1 → 2.1.13-1
- ros-kinetic-ff: 2.1.12-1 → 2.1.13-1
- ros-kinetic-ffha: 2.1.12-1 → 2.1.13-1
- ros-kinetic-jsk-3rdparty: 2.1.12-1 → 2.1.13-1
- ros-kinetic-julius: 2.1.12-1 → 2.1.13-1
- ros-kinetic-julius-ros: 2.1.12-1 → 2.1.13-1
- ros-kinetic-kinesis-manager: 2.0.0-0 → 2.0.1-1
- ros-kinetic-libcmt: 2.1.12-1 → 2.1.13-1
- ros-kinetic-libsiftfast: 2.1.12-1 → 2.1.13-1
- ros-kinetic-lpg-planner: 2.1.12-1 → 2.1.13-1
- ros-kinetic-message-relay: 0.0.1-0 → 0.0.2-1
- ros-kinetic-mini-maxwell: 2.1.12-1 → 2.1.13-1
- ros-kinetic-multimaster-launch: 0.0.1-0 → 0.0.2-1
- ros-kinetic-multimaster-msgs: 0.0.1-0 → 0.0.2-1
- ros-kinetic-nlopt: 2.1.12-1 → 2.1.13-1
- ros-kinetic-nmea-gps-plugin: 0.0.1-2 → 0.0.2-1
- ros-kinetic-opt-camera: 2.1.12-1 → 2.1.13-1
- ros-kinetic-pgm-learner: 2.1.12-1 → 2.1.13-1
- ros-kinetic-plotjuggler: 2.1.10-0 → 2.3.0-1
- ros-kinetic-rc-hand-eye-calibration-client: 2.6.4-1 → 2.7.0-1
- ros-kinetic-rc-pick-client: 2.6.4-1 → 2.7.0-1
- ros-kinetic-rc-tagdetect-client: 2.6.4-1 → 2.7.0-1
- ros-kinetic-rc-visard: 2.6.4-1 → 2.7.0-1
- ros-kinetic-rc-visard-description: 2.6.4-1 → 2.7.0-1
- ros-kinetic-rc-visard-driver: 2.6.4-1 → 2.7.0-1
- ros-kinetic-respeaker-ros: 2.1.12-1 → 2.1.13-1
- ros-kinetic-ros-canopen: 0.7.10-0 → 0.7.11-1
- ros-kinetic-ros-speech-recognition: 2.1.12-1 → 2.1.13-1
- ros-kinetic-rospatlite: 2.1.12-1 → 2.1.13-1
- ros-kinetic-rosping: 2.1.12-1 → 2.1.13-1
- ros-kinetic-rostwitter: 2.1.12-1 → 2.1.13-1
- ros-kinetic-sick-safetyscanners: 1.0.2-0 → 1.0.3-1
- ros-kinetic-slic: 2.1.12-1 → 2.1.13-1
- ros-kinetic-socketcan-bridge: 0.7.10-0 → 0.7.11-1
- ros-kinetic-socketcan-interface: 0.7.10-0 → 0.7.11-1
- ros-kinetic-tf2-relay: 0.0.1-0 → 0.0.2-1
- ros-kinetic-toposens: 1.2.0-1 → 1.2.1-1
- ros-kinetic-toposens-description: 1.2.0-1 → 1.2.1-1
- ros-kinetic-toposens-driver: 1.2.0-1 → 1.2.1-1
- ros-kinetic-toposens-markers: 1.2.0-1 → 1.2.1-1
- ros-kinetic-toposens-msgs: 1.2.0-1 → 1.2.1-1
- ros-kinetic-toposens-pointcloud: 1.2.0-1 → 1.2.1-1
- ros-kinetic-toposens-sync: 1.2.0-1 → 1.2.1-1
- ros-kinetic-voice-text: 2.1.12-1 → 2.1.13-1
- ros-kinetic-warthog-control: 0.1.0-0 → 0.1.1-1
- ros-kinetic-warthog-description: 0.1.0-0 → 0.1.1-1
- ros-kinetic-warthog-msgs: 0.1.0-0 → 0.1.1-1
- ros-kinetic-webots-ros: 2.0.4-1 → 2.0.5-1
Removed Packages [0]:
- AWS RoboMaker
- Abraham Monrroy
- Adi Singh
- Barry Ridge
- Cyberbotics
- Davide Faconti
- Felix Ruess
- Hitoshi Kamada
- Kei Okada
- Lennart Puck
- Masaya Kataoka
- Mathias Lüdtke
- Michael Ferguson
- Monika Florek-Jasinska
- MoveIt Setup Assistant
- Nicholas Padilla
- Nikhil Khedekar
- Noda Shintaro
- Paul Bovbel
- Ryohei Ueda
- Shohei Fujii
- Takuya Nakaoka
- Tony Baltovski
- Yohei Kakiuchi
- Yuki Furuta
- Yusuke Fujii
- Yuto Inagaki
- hi-kondo
- k-okada
- mitsudome-r
- seed_solutions
- syouji
