Weβre happy to announce 16 new packages and 73 updated packages for Kinetic. Details are listed below.
Thank you to all the maintainers and contributors who have helped make these packages available!
Package Updates for kinetic
Added Packages [16]:
- ros-kinetic-haros-catkin: 0.1.1-1
- ros-kinetic-lex-common: 1.0.0-1
- ros-kinetic-robot-statemachine: 1.1.3-1
- ros-kinetic-ros-mppt: 0.1.1-1
- ros-kinetic-rsm-additions: 1.1.3-1
- ros-kinetic-rsm-core: 1.1.3-1
- ros-kinetic-rsm-msgs: 1.1.3-1
- ros-kinetic-rsm-rqt-plugins: 1.1.3-1
- ros-kinetic-rsm-rviz-plugins: 1.1.3-1
- ros-kinetic-rxcpp-vendor: 4.1.0-1
- ros-kinetic-seed-r7-bringup: 0.2.0-2
- ros-kinetic-seed-r7-description: 0.2.0-2
- ros-kinetic-seed-r7-navigation: 0.2.0-2
- ros-kinetic-seed-r7-robot-interface: 0.2.0-2
- ros-kinetic-seed-r7-typef-moveit-config: 0.2.0-2
- ros-kinetic-vrx-gazebo: 1.2.4-1
Updated Packages [73]:
- ros-kinetic-costmap-cspace: 0.4.2-1 β 0.4.3-1
- ros-kinetic-dynamixel-sdk: 3.7.11-1 β 3.7.21-1
- ros-kinetic-h264-video-encoder: 1.1.3-1 β 1.1.4-1
- ros-kinetic-ibeo-core: 2.0.2-0 β 2.0.2-1
- ros-kinetic-ibeo-lux: 2.0.1-0 β 2.0.1-1
- ros-kinetic-indoor-localization: 0.1.0-1 β 1.0.0-1
- ros-kinetic-joystick-interrupt: 0.4.2-1 β 0.4.3-1
- ros-kinetic-libmavconn: 0.32.1-1 β 0.32.2-1
- ros-kinetic-map-organizer: 0.4.2-1 β 0.4.3-1
- ros-kinetic-mapviz: 1.1.1-1 β 1.2.0-1
- ros-kinetic-mapviz-plugins: 1.1.1-1 β 1.2.0-1
- ros-kinetic-marti-data-structures: 2.9.0-1 β 2.10.0-1
- ros-kinetic-mavlink: 2019.8.8-1 β 2019.9.9-1
- ros-kinetic-mavros: 0.32.1-1 β 0.32.2-1
- ros-kinetic-mavros-extras: 0.32.1-1 β 0.32.2-1
- ros-kinetic-mavros-msgs: 0.32.1-1 β 0.32.2-1
- ros-kinetic-multires-image: 1.1.1-1 β 1.2.0-1
- ros-kinetic-neonavigation: 0.4.2-1 β 0.4.3-1
- ros-kinetic-neonavigation-common: 0.4.2-1 β 0.4.3-1
- ros-kinetic-neonavigation-launch: 0.4.2-1 β 0.4.3-1
- ros-kinetic-novatel-gps-driver: 3.8.0-1 β 3.9.0-1
- ros-kinetic-novatel-gps-msgs: 3.8.0-1 β 3.9.0-1
- ros-kinetic-obj-to-pointcloud: 0.4.2-1 β 0.4.3-1
- ros-kinetic-pilz-control: 0.4.9-1 β 0.4.10-1
- ros-kinetic-pilz-extensions: 0.3.8-0 β 0.3.9-1
- ros-kinetic-pilz-industrial-motion: 0.3.8-0 β 0.3.9-1
- ros-kinetic-pilz-industrial-motion-testutils: 0.3.8-0 β 0.3.9-1
- ros-kinetic-pilz-msgs: 0.3.8-0 β 0.3.9-1
- ros-kinetic-pilz-robot-programming: 0.3.8-0 β 0.3.9-1
- ros-kinetic-pilz-robots: 0.4.9-1 β 0.4.10-1
- ros-kinetic-pilz-testutils: 0.4.9-1 β 0.4.10-1
- ros-kinetic-pilz-trajectory-generation: 0.3.8-0 β 0.3.9-1
- ros-kinetic-planner-cspace: 0.4.2-1 β 0.4.3-1
- ros-kinetic-prbt-gazebo: 0.4.9-1 β 0.4.10-1
- ros-kinetic-prbt-hardware-support: 0.4.9-1 β 0.4.10-1
- ros-kinetic-prbt-ikfast-manipulator-plugin: 0.4.9-1 β 0.4.10-1
- ros-kinetic-prbt-moveit-config: 0.4.9-1 β 0.4.10-1
- ros-kinetic-prbt-support: 0.4.9-1 β 0.4.10-1
- ros-kinetic-robot-state-publisher: 1.13.6-0 β 1.13.7-1
- ros-kinetic-safety-limiter: 0.4.2-1 β 0.4.3-1
- ros-kinetic-seed-smartactuator-sdk: 0.0.3-1 β 0.0.4-1
- ros-kinetic-swri-console-util: 2.9.0-1 β 2.10.0-1
- ros-kinetic-swri-dbw-interface: 2.9.0-1 β 2.10.0-1
- ros-kinetic-swri-geometry-util: 2.9.0-1 β 2.10.0-1
- ros-kinetic-swri-image-util: 2.9.0-1 β 2.10.0-1
- ros-kinetic-swri-math-util: 2.9.0-1 β 2.10.0-1
- ros-kinetic-swri-nodelet: 2.9.0-1 β 2.10.0-1
- ros-kinetic-swri-opencv-util: 2.9.0-1 β 2.10.0-1
- ros-kinetic-swri-prefix-tools: 2.9.0-1 β 2.10.0-1
- ros-kinetic-swri-roscpp: 2.9.0-1 β 2.10.0-1
- ros-kinetic-swri-rospy: 2.9.0-1 β 2.10.0-1
- ros-kinetic-swri-route-util: 2.9.0-1 β 2.10.0-1
- ros-kinetic-swri-serial-util: 2.9.0-1 β 2.10.0-1
- ros-kinetic-swri-string-util: 2.9.0-1 β 2.10.0-1
- ros-kinetic-swri-system-util: 2.9.0-1 β 2.10.0-1
- ros-kinetic-swri-transform-util: 2.9.0-1 β 2.10.0-1
- ros-kinetic-swri-yaml-util: 2.9.0-1 β 2.10.0-1
- ros-kinetic-test-mavros: 0.32.1-1 β 0.32.2-1
- ros-kinetic-tile-map: 1.1.1-1 β 1.2.0-1
- ros-kinetic-toposens: 1.2.2-1 β 1.2.3-1
- ros-kinetic-toposens-description: 1.2.2-1 β 1.2.3-1
- ros-kinetic-toposens-driver: 1.2.2-1 β 1.2.3-1
- ros-kinetic-toposens-markers: 1.2.2-1 β 1.2.3-1
- ros-kinetic-toposens-msgs: 1.2.2-1 β 1.2.3-1
- ros-kinetic-toposens-pointcloud: 1.2.2-1 β 1.2.3-1
- ros-kinetic-toposens-sync: 1.2.2-1 β 1.2.3-1
- ros-kinetic-track-odometry: 0.4.2-1 β 0.4.3-1
- ros-kinetic-trajectory-tracker: 0.4.2-1 β 0.4.3-1
- ros-kinetic-usv-gazebo-plugins: 1.2.0-1 β 1.2.4-1
- ros-kinetic-wamv-description: 1.2.0-1 β 1.2.4-1
- ros-kinetic-wamv-gazebo: 1.2.0-1 β 1.2.4-1
- ros-kinetic-wave-gazebo: 1.2.0-1 β 1.2.4-1
- ros-kinetic-wave-gazebo-plugins: 1.2.0-1 β 1.2.4-1
Removed Packages [0]:
- AWS RoboMaker
- Adi Singh
- Alexander Gutenkunst
- Atsushi Watanabe
- Carlos Aguero
- Chris Lalancette
- Elcin Erdogan
- G.A. vd. Hoorn (TU Delft Robotics Institute)
- Kris Kozak
- Marc Alban
- Marco Steinbrink
- P. J. Reed
- Pyo
- Rhys Mainwaring
- Vladimir Ermakov
- Yasuto Shiigi
- aaronpb
- hi.kondo
