New packages for Kilted Kaiju 2025-08-13
This sync brings 53 new packages to Kilted and updates 121 others. Thanks very much to the many developers that were a part of this effort, including the 28 maintainers listed below.
ros/rosdistro tag: kilted/2025-08-13
Added Packages [53]:
  • ros-kilted-clips-executive: 0.1.3-1
  • ros-kilted-cx-bringup: 0.1.3-1
  • ros-kilted-cx-clips-env-manager: 0.1.3-1
  • ros-kilted-cx-msgs: 0.1.3-1
  • ros-kilted-cx-ros-param-plugin: 0.1.3-1
  • ros-kilted-cx-tutorial-agents: 0.1.3-1
  • ros-kilted-depthai: 3.0.2-2
  • ros-kilted-depthai-bridge: 3.0.1-1
  • ros-kilted-depthai-descriptions: 3.0.1-1
  • ros-kilted-depthai-examples: 3.0.1-1
  • ros-kilted-depthai-filters: 3.0.1-1
  • ros-kilted-depthai-ros: 3.0.1-1
  • ros-kilted-depthai-ros-driver: 3.0.1-1
  • ros-kilted-depthai-ros-msgs: 3.0.1-1
  • ros-kilted-etsi-its-cam-coding: 3.3.0-1
  • ros-kilted-etsi-its-cam-conversion: 3.3.0-1
  • ros-kilted-etsi-its-cam-msgs: 3.3.0-1
  • ros-kilted-etsi-its-cam-ts-coding: 3.3.0-1
  • ros-kilted-etsi-its-cam-ts-conversion: 3.3.0-1
  • ros-kilted-etsi-its-cam-ts-msgs: 3.3.0-1
  • ros-kilted-etsi-its-coding: 3.3.0-1
  • ros-kilted-etsi-its-conversion: 3.3.0-1
  • ros-kilted-etsi-its-cpm-ts-coding: 3.3.0-1
  • ros-kilted-etsi-its-cpm-ts-conversion: 3.3.0-1
  • ros-kilted-etsi-its-cpm-ts-msgs: 3.3.0-1
  • ros-kilted-etsi-its-denm-coding: 3.3.0-1
  • ros-kilted-etsi-its-denm-conversion: 3.3.0-1
  • ros-kilted-etsi-its-denm-msgs: 3.3.0-1
  • ros-kilted-etsi-its-denm-ts-coding: 3.3.0-1
  • ros-kilted-etsi-its-denm-ts-conversion: 3.3.0-1
  • ros-kilted-etsi-its-denm-ts-msgs: 3.3.0-1
  • ros-kilted-etsi-its-mapem-ts-coding: 3.3.0-1
  • ros-kilted-etsi-its-mapem-ts-conversion: 3.3.0-1
  • ros-kilted-etsi-its-mapem-ts-msgs: 3.3.0-1
  • ros-kilted-etsi-its-mcm-uulm-coding: 3.3.0-1
  • ros-kilted-etsi-its-mcm-uulm-conversion: 3.3.0-1
  • ros-kilted-etsi-its-mcm-uulm-msgs: 3.3.0-1
  • ros-kilted-etsi-its-messages: 3.3.0-1
  • ros-kilted-etsi-its-msgs: 3.3.0-1
  • ros-kilted-etsi-its-msgs-utils: 3.3.0-1
  • ros-kilted-etsi-its-primitives-conversion: 3.3.0-1
  • ros-kilted-etsi-its-rviz-plugins: 3.3.0-1
  • ros-kilted-etsi-its-spatem-ts-coding: 3.3.0-1
  • ros-kilted-etsi-its-spatem-ts-conversion: 3.3.0-1
  • ros-kilted-etsi-its-spatem-ts-msgs: 3.3.0-1
  • ros-kilted-etsi-its-vam-ts-coding: 3.3.0-1
  • ros-kilted-etsi-its-vam-ts-conversion: 3.3.0-1
  • ros-kilted-etsi-its-vam-ts-msgs: 3.3.0-1
  • ros-kilted-omni-wheel-drive-controller: 5.5.0-2
  • ros-kilted-plotjuggler: 3.10.11-1
  • ros-kilted-plotjuggler-ros: 2.3.0-1
  • ros-kilted-robotraconteur-companion: 0.4.2-1
  • ros-kilted-rviz-satellite: 4.2.1-1
Updated Packages [121]:
Removed Packages [0]:
  • (none)
  • Aarav Gupta
  • Adam Serafin
  • Addisu Z. Taddese
  • Alejandro Hernandez Cordero
  • Bence Magyar
  • Bernd Pfrommer
  • Chris Bollinger
  • Chris Lalancette
  • Davide Faconti
  • Dirk Thomas
  • Enrique Fernandez
  • Felix Exner
  • Felix Ruess
  • Fictionlab
  • G.A. vd. Hoorn
  • Geoff Sokoll
  • Jean-Pierre Busch
  • John Wason
  • José-Luis Blanco-Claraco
  • Markus Bader
  • Nick Hortovanyi
  • Severn Lortie
  • Stephen Williams
  • TRACLabs Robotics
  • Tarik Viehmann
  • Tim Clephas
  • Tom Moore
  • ruess
