We’re happy to announce 8 new packages and 74 updates are now available in ROS 2 Iron Irwini
. This sync was tagged as iron/2024-03-22 .
Package Updates for iron
Added Packages [8]:
- ros-iron-kobuki-core: 1.4.0-3
- ros-iron-kobuki-core-dbgsym: 1.4.0-3
- ros-iron-marine-acoustic-msgs: 2.1.0-1
- ros-iron-marine-acoustic-msgs-dbgsym: 2.1.0-1
- ros-iron-marine-sensor-msgs: 2.1.0-1
- ros-iron-marine-sensor-msgs-dbgsym: 2.1.0-1
- ros-iron-spinnaker-synchronized-camera-driver: 2.2.14-1
- ros-iron-spinnaker-synchronized-camera-driver-dbgsym: 2.2.14-1
Updated Packages [74]:
- ros-iron-azure-iot-sdk-c: 1.12.0-1 → 1.13.0-1
- ros-iron-cartographer: 2.0.9002-5 → 2.0.9003-1
- ros-iron-cartographer-dbgsym: 2.0.9002-5 → 2.0.9003-1
- ros-iron-cartographer-ros: 2.0.9001-2 → 2.0.9002-1
- ros-iron-cartographer-ros-dbgsym: 2.0.9001-2 → 2.0.9002-1
- ros-iron-cartographer-ros-msgs: 2.0.9001-2 → 2.0.9002-1
- ros-iron-cartographer-ros-msgs-dbgsym: 2.0.9001-2 → 2.0.9002-1
- ros-iron-cartographer-rviz: 2.0.9001-2 → 2.0.9002-1
- ros-iron-cartographer-rviz-dbgsym: 2.0.9001-2 → 2.0.9002-1
- ros-iron-depthai: 2.23.0-1 → 2.24.0-1
- ros-iron-depthai-dbgsym: 2.23.0-1 → 2.24.0-1
- ros-iron-event-camera-py: 1.2.4-1 → 1.2.5-1
- ros-iron-ffmpeg-image-transport: 1.2.0-1 → 1.2.1-1
- ros-iron-ffmpeg-image-transport-dbgsym: 1.2.0-1 → 1.2.1-1
- ros-iron-flir-camera-description: 2.0.8-2 → 2.2.14-1
- ros-iron-flir-camera-msgs: 2.0.8-2 → 2.2.14-1
- ros-iron-flir-camera-msgs-dbgsym: 2.0.8-2 → 2.2.14-1
- ros-iron-libphidget22: 2.3.2-1 → 2.3.3-1
- ros-iron-libphidget22-dbgsym: 2.3.2-1 → 2.3.3-1
- ros-iron-message-tf-frame-transformer: 1.1.0-1 → 1.1.1-1
- ros-iron-message-tf-frame-transformer-dbgsym: 1.1.0-1 → 1.1.1-1
- ros-iron-motion-capture-tracking: 1.0.2-1 → 1.0.4-1
- ros-iron-motion-capture-tracking-dbgsym: 1.0.2-1 → 1.0.4-1
- ros-iron-motion-capture-tracking-interfaces: 1.0.2-1 → 1.0.4-1
- ros-iron-motion-capture-tracking-interfaces-dbgsym: 1.0.2-1 → 1.0.4-1
- ros-iron-mp2p-icp: 1.2.0-1 → 1.3.0-1
- ros-iron-mp2p-icp-dbgsym: 1.2.0-1 → 1.3.0-1
- ros-iron-mqtt-client: 2.2.0-1 → 2.2.1-1
- ros-iron-mqtt-client-dbgsym: 2.2.0-1 → 2.2.1-1
- ros-iron-mqtt-client-interfaces: 2.2.0-1 → 2.2.1-1
- ros-iron-mqtt-client-interfaces-dbgsym: 2.2.0-1 → 2.2.1-1
- ros-iron-mrpt-path-planning: 0.1.0-1 → 0.1.1-1
- ros-iron-mrpt-path-planning-dbgsym: 0.1.0-1 → 0.1.1-1
- ros-iron-mrpt2: 2.11.11-1 → 2.12.0-1
- ros-iron-mrpt2-dbgsym: 2.11.11-1 → 2.12.0-1
- ros-iron-novatel-gps-driver: 4.1.1-1 → 4.1.2-1
- ros-iron-novatel-gps-driver-dbgsym: 4.1.1-1 → 4.1.2-1
- ros-iron-novatel-gps-msgs: 4.1.1-1 → 4.1.2-1
- ros-iron-novatel-gps-msgs-dbgsym: 4.1.1-1 → 4.1.2-1
- ros-iron-phidgets-accelerometer: 2.3.2-1 → 2.3.3-1
- ros-iron-phidgets-accelerometer-dbgsym: 2.3.2-1 → 2.3.3-1
- ros-iron-phidgets-analog-inputs: 2.3.2-1 → 2.3.3-1
- ros-iron-phidgets-analog-inputs-dbgsym: 2.3.2-1 → 2.3.3-1
- ros-iron-phidgets-analog-outputs: 2.3.2-1 → 2.3.3-1
- ros-iron-phidgets-analog-outputs-dbgsym: 2.3.2-1 → 2.3.3-1
- ros-iron-phidgets-api: 2.3.2-1 → 2.3.3-1
- ros-iron-phidgets-api-dbgsym: 2.3.2-1 → 2.3.3-1
- ros-iron-phidgets-digital-inputs: 2.3.2-1 → 2.3.3-1
- ros-iron-phidgets-digital-inputs-dbgsym: 2.3.2-1 → 2.3.3-1
- ros-iron-phidgets-digital-outputs: 2.3.2-1 → 2.3.3-1
- ros-iron-phidgets-digital-outputs-dbgsym: 2.3.2-1 → 2.3.3-1
- ros-iron-phidgets-drivers: 2.3.2-1 → 2.3.3-1
- ros-iron-phidgets-gyroscope: 2.3.2-1 → 2.3.3-1
- ros-iron-phidgets-gyroscope-dbgsym: 2.3.2-1 → 2.3.3-1
- ros-iron-phidgets-high-speed-encoder: 2.3.2-1 → 2.3.3-1
- ros-iron-phidgets-high-speed-encoder-dbgsym: 2.3.2-1 → 2.3.3-1
- ros-iron-phidgets-ik: 2.3.2-1 → 2.3.3-1
- ros-iron-phidgets-magnetometer: 2.3.2-1 → 2.3.3-1
- ros-iron-phidgets-magnetometer-dbgsym: 2.3.2-1 → 2.3.3-1
- ros-iron-phidgets-motors: 2.3.2-1 → 2.3.3-1
- ros-iron-phidgets-motors-dbgsym: 2.3.2-1 → 2.3.3-1
- ros-iron-phidgets-msgs: 2.3.2-1 → 2.3.3-1
- ros-iron-phidgets-msgs-dbgsym: 2.3.2-1 → 2.3.3-1
- ros-iron-phidgets-spatial: 2.3.2-1 → 2.3.3-1
- ros-iron-phidgets-spatial-dbgsym: 2.3.2-1 → 2.3.3-1
- ros-iron-phidgets-temperature: 2.3.2-1 → 2.3.3-1
- ros-iron-phidgets-temperature-dbgsym: 2.3.2-1 → 2.3.3-1
- ros-iron-robotraconteur: 1.0.0-2 → 1.1.1-1
- ros-iron-robotraconteur-dbgsym: 1.0.0-2 → 1.1.1-1
- ros-iron-rqt-gauges: 0.0.2-1 → 0.0.3-1
- ros-iron-sophus: 1.3.1-3 → 1.3.2-1
- ros-iron-spinnaker-camera-driver: 2.0.8-2 → 2.2.14-1
- ros-iron-spinnaker-camera-driver-dbgsym: 2.0.8-2 → 2.2.14-1
- ros-iron-teleop-twist-keyboard: 2.3.2-5 → 2.4.0-1
Removed Packages [0]:
- Bernd Pfrommer
- Chris Lalancette
- Daniel Stonier
- Eloy Bricneo
- John Wason
- Jose-Luis Blanco-Claraco
- Laura Lindzey
- Lennart Reiher
- Luis Camero
- Martin Günther
- P. J. Reed
- Sachin Guruswamy
- Tim Clephas
- Wolfgang Hönig
