New packages and patch release for ROS 2 Crystal Clemmys
After a wonderful year with more than 300 bloom releases it is time to say farewell to ROS 2 Crystal Clemmys. Unless there are major regressions reported with this sync there won’t be any further releases into Crystal.
You can get the release here.
ROS 2 Crystal mascot
Changes in ROS 2 core packages are shown on the Released column of the patch release board.
Package Updates for crystal
Added Packages [2]:
  • ros-crystal-ament-cmake-virtualenv: 0.0.4-1
  • ros-crystal-ament-virtualenv: 0.0.4-1
Updated Packages [21]:
  • ros-crystal-rclcpp: 0.6.4-0 → 0.6.5-1
  • ros-crystal-rclcpp-action: 0.6.4-0 → 0.6.5-1
  • ros-crystal-rclcpp-lifecycle: 0.6.4-0 → 0.6.5-1
  • ros-crystal-rclpy: 0.6.4-0 → 0.6.5-1
  • ros-crystal-rviz-assimp-vendor: 5.1.0-0 → 5.1.1-1
  • ros-crystal-rviz-common: 5.1.0-0 → 5.1.1-1
  • ros-crystal-rviz-default-plugins: 5.1.0-0 → 5.1.1-1
  • ros-crystal-rviz-ogre-vendor]: 5.1.0-0 → 5.1.1-1
  • ros-crystal-rviz-rendering: 5.1.0-0 → 5.1.1-1
  • ros-crystal-rviz-rendering-tests: 5.1.0-0 → 5.1.1-1
  • ros-crystal-rviz-visual-testing-framework: 5.1.0-0 → 5.1.1-1
  • ros-crystal-rviz2: 5.1.0-0 → 5.1.1-1
Removed Packages [0]:
  • Dirk Thomas
  • Karsten Knese
  • Max Krichenbauer
  • Scott K Logan
  • William Woodall
The release link doesn’t actually work yet because binaries are still uploading. I just finished the draft post and got excited.
Update: The binaries are now uploaded.
