Crystal’s third patch release is here!
The changes I’m most excited about:
- Actions are now available in rclpy. You can get the details from ros2/rclpy#257.
- If you’re interested in using log4cxx for your logging needs, the rcl_logging_log4cxx package has now been released. Using this package naturally relies on log4cxx, so refer to the installation instructions for your platform to get it.
The changes in sros2 introduce a new dependency on the rosdep key: python3-lxml
The installation documentation has been updated but I’ll highlight the changes here:
Depending on the platform, users may need to get the additional dependency:
- With Ubuntu debs: apt will install suitable the suitable dependency
- With Ubuntu binary releases: The
rosdeptool should resolve the dependency (installspython3-lxml) - With macOS: The dependency should be resolved by installing
lxmlvia pip until using rosdep is an option (see add rule for python3-lxml for mac os by mikaelarguedas · Pull Request #20560 · ros/rosdistro · GitHub) - With Windows: The dependency should be resolved by installing
lxmlvia pip - With Windows (debug): The dependency should be resolved by installing a custom-built
lxmlvia pip: Release LXML Windows Debug Python Wheel · ros2/ros2 · GitHub
You can check out full list of changes in the patch release tracking issue. We’ve also discovered some issues in Fast-RTPS that are being added to the Known issues section of the Crystal Clemmys release page. I’m linking the section now even though they won’t appear until the next documentation rebuild. This is the change for you first viewers.
Package Updates for crystal
Added Packages [11]:
- ros-crystal-behaviortree-cpp-v3: 3.0.4-0
- ros-crystal-behaviortree-cpp-v3-dbgsym: 3.0.4-0
- ros-crystal-examples-rclpy-minimal-action-client: 0.6.3-0
- ros-crystal-examples-rclpy-minimal-action-server: 0.6.3-0
- ros-crystal-nav2-common: 0.1.7-0
- ros-crystal-py-trees-ros-interfaces: 1.0.0-0
- ros-crystal-py-trees-ros-interfaces-dbgsym: 1.0.0-0
- ros-crystal-rcl-logging-log4cxx: 0.2.0-0
- ros-crystal-rcl-logging-log4cxx-dbgsym: 0.2.0-0
- ros-crystal-rqt-action: 1.0.1-0
- ros-crystal-rqt-topic: 1.0.0-0
Updated Packages [165]:
- ros-crystal-action-msgs: 0.6.2-0 → 0.6.3-0
- ros-crystal-action-msgs-dbgsym: 0.6.2-0 → 0.6.3-0
- ros-crystal-ament-clang-format: 0.6.3-0 → 0.6.4-0
- ros-crystal-ament-cmake: 0.6.0-4 → 0.6.1-0
- ros-crystal-ament-cmake-auto: 0.6.0-4 → 0.6.1-0
- ros-crystal-ament-cmake-clang-format: 0.6.3-0 → 0.6.4-0
- ros-crystal-ament-cmake-copyright: 0.6.3-0 → 0.6.4-0
- ros-crystal-ament-cmake-core: 0.6.0-4 → 0.6.1-0
- ros-crystal-ament-cmake-cppcheck: 0.6.3-0 → 0.6.4-0
- ros-crystal-ament-cmake-cpplint: 0.6.3-0 → 0.6.4-0
- ros-crystal-ament-cmake-export-definitions: 0.6.0-4 → 0.6.1-0
- ros-crystal-ament-cmake-export-dependencies: 0.6.0-4 → 0.6.1-0
- ros-crystal-ament-cmake-export-include-directories: 0.6.0-4 → 0.6.1-0
- ros-crystal-ament-cmake-export-interfaces: 0.6.0-4 → 0.6.1-0
- ros-crystal-ament-cmake-export-libraries: 0.6.0-4 → 0.6.1-0
- ros-crystal-ament-cmake-export-link-flags: 0.6.0-4 → 0.6.1-0
- ros-crystal-ament-cmake-flake8: 0.6.3-0 → 0.6.4-0
- ros-crystal-ament-cmake-gmock: 0.6.0-4 → 0.6.1-0
- ros-crystal-ament-cmake-gtest: 0.6.0-4 → 0.6.1-0
- ros-crystal-ament-cmake-include-directories: 0.6.0-4 → 0.6.1-0
- ros-crystal-ament-cmake-libraries: 0.6.0-4 → 0.6.1-0
- ros-crystal-ament-cmake-lint-cmake: 0.6.3-0 → 0.6.4-0
- ros-crystal-ament-cmake-nose: 0.6.0-4 → 0.6.1-0
- ros-crystal-ament-cmake-pclint: 0.6.3-0 → 0.6.4-0
- ros-crystal-ament-cmake-pep257: 0.6.3-0 → 0.6.4-0
- ros-crystal-ament-cmake-pep8: 0.6.3-0 → 0.6.4-0
- ros-crystal-ament-cmake-pyflakes: 0.6.3-0 → 0.6.4-0
- ros-crystal-ament-cmake-pytest: 0.6.0-4 → 0.6.1-0
- ros-crystal-ament-cmake-python: 0.6.0-4 → 0.6.1-0
- ros-crystal-ament-cmake-target-dependencies: 0.6.0-4 → 0.6.1-0
- ros-crystal-ament-cmake-test: 0.6.0-4 → 0.6.1-0
- ros-crystal-ament-cmake-uncrustify: 0.6.3-0 → 0.6.4-0
- ros-crystal-ament-cmake-xmllint: 0.6.3-0 → 0.6.4-0
- ros-crystal-ament-copyright: 0.6.3-0 → 0.6.4-0
- ros-crystal-ament-cppcheck: 0.6.3-0 → 0.6.4-0
- ros-crystal-ament-cpplint: 0.6.3-0 → 0.6.4-0
- ros-crystal-ament-flake8: 0.6.3-0 → 0.6.4-0
- ros-crystal-ament-lint-auto: 0.6.3-0 → 0.6.4-0
- ros-crystal-ament-lint-cmake: 0.6.3-0 → 0.6.4-0
- ros-crystal-ament-lint-common: 0.6.3-0 → 0.6.4-0
- ros-crystal-ament-pclint: 0.6.3-0 → 0.6.4-0
- ros-crystal-ament-pep257: 0.6.3-0 → 0.6.4-0
- ros-crystal-ament-pep8: 0.6.3-0 → 0.6.4-0
- ros-crystal-ament-pyflakes: 0.6.3-0 → 0.6.4-0
- ros-crystal-ament-uncrustify: 0.6.3-0 → 0.6.4-0
- ros-crystal-ament-xmllint: 0.6.3-0 → 0.6.4-0
- ros-crystal-builtin-interfaces: 0.6.2-0 → 0.6.3-0
- ros-crystal-builtin-interfaces-dbgsym: 0.6.2-0 → 0.6.3-0
- ros-crystal-costmap-queue: 0.1.5-0 → 0.1.7-0
- ros-crystal-dwb-controller: 0.1.5-0 → 0.1.7-0
- ros-crystal-dwb-controller-dbgsym: 0.1.5-0 → 0.1.7-0
- ros-crystal-dwb-core: 0.1.5-0 → 0.1.7-0
- ros-crystal-dwb-core-dbgsym: 0.1.5-0 → 0.1.7-0
- ros-crystal-dwb-critics: 0.1.5-0 → 0.1.7-0
- ros-crystal-dwb-critics-dbgsym: 0.1.5-0 → 0.1.7-0
- ros-crystal-dwb-msgs: 0.1.5-0 → 0.1.7-0
- ros-crystal-dwb-msgs-dbgsym: 0.1.5-0 → 0.1.7-0
- ros-crystal-dwb-plugins: 0.1.5-0 → 0.1.7-0
- ros-crystal-dwb-plugins-dbgsym: 0.1.5-0 → 0.1.7-0
- ros-crystal-examples-rclcpp-minimal-action-client: 0.6.2-0 → 0.6.3-0
- ros-crystal-examples-rclcpp-minimal-action-client-dbgsym: 0.6.2-0 → 0.6.3-0
- ros-crystal-examples-rclcpp-minimal-action-server: 0.6.2-0 → 0.6.3-0
- ros-crystal-examples-rclcpp-minimal-action-server-dbgsym: 0.6.2-0 → 0.6.3-0
- ros-crystal-examples-rclcpp-minimal-client: 0.6.2-0 → 0.6.3-0
- ros-crystal-examples-rclcpp-minimal-client-dbgsym: 0.6.2-0 → 0.6.3-0
- ros-crystal-examples-rclcpp-minimal-composition: 0.6.2-0 → 0.6.3-0
- ros-crystal-examples-rclcpp-minimal-composition-dbgsym: 0.6.2-0 → 0.6.3-0
- ros-crystal-examples-rclcpp-minimal-publisher: 0.6.2-0 → 0.6.3-0
- ros-crystal-examples-rclcpp-minimal-publisher-dbgsym: 0.6.2-0 → 0.6.3-0
- ros-crystal-examples-rclcpp-minimal-service: 0.6.2-0 → 0.6.3-0
- ros-crystal-examples-rclcpp-minimal-service-dbgsym: 0.6.2-0 → 0.6.3-0
- ros-crystal-examples-rclcpp-minimal-subscriber: 0.6.2-0 → 0.6.3-0
- ros-crystal-examples-rclcpp-minimal-subscriber-dbgsym: 0.6.2-0 → 0.6.3-0
- ros-crystal-examples-rclcpp-minimal-timer: 0.6.2-0 → 0.6.3-0
- ros-crystal-examples-rclcpp-minimal-timer-dbgsym: 0.6.2-0 → 0.6.3-0
- ros-crystal-examples-rclpy-executors: 0.6.2-0 → 0.6.3-0
- ros-crystal-examples-rclpy-minimal-client: 0.6.2-0 → 0.6.3-0
- ros-crystal-examples-rclpy-minimal-publisher: 0.6.2-0 → 0.6.3-0
- ros-crystal-examples-rclpy-minimal-service: 0.6.2-0 → 0.6.3-0
- ros-crystal-examples-rclpy-minimal-subscriber: 0.6.2-0 → 0.6.3-0
- ros-crystal-gazebo-dev: 3.1.0-0 → 3.2.0-0
- ros-crystal-gazebo-msgs: 3.1.0-0 → 3.2.0-0
- ros-crystal-gazebo-msgs-dbgsym: 3.1.0-0 → 3.2.0-0
- ros-crystal-gazebo-plugins: 3.1.0-0 → 3.2.0-0
- ros-crystal-gazebo-plugins-dbgsym: 3.1.0-0 → 3.2.0-0
- ros-crystal-gazebo-ros: 3.1.0-0 → 3.2.0-0
- ros-crystal-gazebo-ros-dbgsym: 3.1.0-0 → 3.2.0-0
- ros-crystal-gazebo-ros-pkgs: 3.1.0-0 → 3.2.0-0
- ros-crystal-lifecycle-msgs: 0.6.2-0 → 0.6.3-0
- ros-crystal-lifecycle-msgs-dbgsym: 0.6.2-0 → 0.6.3-0
- ros-crystal-nav-2d-msgs: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav-2d-msgs-dbgsym: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav-2d-utils: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav-2d-utils-dbgsym: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-amcl: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-amcl-dbgsym: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-bringup: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-bt-navigator: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-bt-navigator-dbgsym: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-costmap-2d: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-costmap-2d-dbgsym: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-dwb-controller: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-dynamic-params: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-dynamic-params-dbgsym: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-map-server: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-map-server-dbgsym: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-mission-executor: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-mission-executor-dbgsym: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-motion-primitives: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-motion-primitives-dbgsym: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-msgs: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-msgs-dbgsym: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-navfn-planner: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-navfn-planner-dbgsym: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-robot: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-robot-dbgsym: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-simple-navigator: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-simple-navigator-dbgsym: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-tasks: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-tasks-dbgsym: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-util: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-util-dbgsym: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-voxel-grid: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-voxel-grid-dbgsym: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-world-model: 0.1.5-0 → 0.1.7-0
- ros-crystal-nav2-world-model-dbgsym: 0.1.5-0 → 0.1.7-0
- ros-crystal-navigation2: 0.1.5-0 → 0.1.7-0
- ros-crystal-python-cmake-module: 0.6.2-0 → 0.6.3-0
- ros-crystal-rcl-interfaces: 0.6.2-0 → 0.6.3-0
- ros-crystal-rcl-interfaces-dbgsym: 0.6.2-0 → 0.6.3-0
- ros-crystal-rcl-logging-noop: 0.1.0-0 → 0.2.0-0
- ros-crystal-rcl-logging-noop-dbgsym: 0.1.0-0 → 0.2.0-0
- ros-crystal-rclpy: 0.6.2-0 → 0.6.3-1
- ros-crystal-rclpy-dbgsym: 0.6.2-0 → 0.6.3-1
- ros-crystal-ros1-bridge: 0.6.1-1 → 0.6.2-0
- ros-crystal-ros1-bridge-dbgsym: 0.6.1-1 → 0.6.2-0
- ros-crystal-ros1-rosbag-storage-vendor: 0.0.5-0 → 0.0.6-0
- ros-crystal-ros2bag: 0.0.5-0 → 0.0.6-0
- ros-crystal-rosbag2: 0.0.5-0 → 0.0.6-0
- ros-crystal-rosbag2-bag-v2-plugins: 0.0.5-0 → 0.0.6-0
- ros-crystal-rosbag2-converter-default-plugins: 0.0.5-0 → 0.0.6-0
- ros-crystal-rosbag2-converter-default-plugins-dbgsym: 0.0.5-0 → 0.0.6-0
- ros-crystal-rosbag2-dbgsym: 0.0.5-0 → 0.0.6-0
- ros-crystal-rosbag2-storage: 0.0.5-0 → 0.0.6-0
- ros-crystal-rosbag2-storage-dbgsym: 0.0.5-0 → 0.0.6-0
- ros-crystal-rosbag2-storage-default-plugins: 0.0.5-0 → 0.0.6-0
- ros-crystal-rosbag2-storage-default-plugins-dbgsym: 0.0.5-0 → 0.0.6-0
- ros-crystal-rosbag2-test-common: 0.0.5-0 → 0.0.6-0
- ros-crystal-rosbag2-tests: 0.0.5-0 → 0.0.6-0
- ros-crystal-rosbag2-transport: 0.0.5-0 → 0.0.6-0
- ros-crystal-rosbag2-transport-dbgsym: 0.0.5-0 → 0.0.6-0
- ros-crystal-rosgraph-msgs: 0.6.2-0 → 0.6.3-0
- ros-crystal-rosgraph-msgs-dbgsym: 0.6.2-0 → 0.6.3-0
- ros-crystal-rosidl-generator-py: 0.6.2-0 → 0.6.3-0
- ros-crystal-rosidl-typesupport-c: 0.6.2-0 → 0.6.3-0
- ros-crystal-rosidl-typesupport-c-dbgsym: 0.6.2-0 → 0.6.3-0
- ros-crystal-rosidl-typesupport-cpp: 0.6.2-0 → 0.6.3-0
- ros-crystal-rosidl-typesupport-cpp-dbgsym: 0.6.2-0 → 0.6.3-0
- ros-crystal-shared-queues-vendor: 0.0.5-0 → 0.0.6-0
- ros-crystal-sqlite3-vendor: 0.0.5-0 → 0.0.6-0
- ros-crystal-sros2: 0.6.2-0 → 0.6.3-0
- ros-crystal-sros2-cmake: 0.6.2-0 → 0.6.3-0
- ros-crystal-teleop-twist-keyboard: 2.1.1-1 → 2.2.0-0
- ros-crystal-test-msgs: 0.6.2-0 → 0.6.3-0
- ros-crystal-test-msgs-dbgsym: 0.6.2-0 → 0.6.3-0
Removed Packages [1]:
- ros-crystal-nav2-system-tests
- AWS B9 Team
- Amazon B9
- Brian Wilcox
- Carl Delsey
- Carlos Orduno
- Chris Lalancette
- Daniel Stonier
- David V. Lu!!
- Davide Faconti
- Dirk Thomas
- Jacob Perron
- Jose Luis Rivero
- Juan Pablo Samper
- Karsten Knese
- Michael Carroll
- Michael Ferguson
- Michael Jeronimo
- Mikael Arguedas
- Scott K Logan
- Shane Loretz
- Steve Macenski
- Steven! Ragnarok
- Tully Foote
- William Woodall
