Local Security Observability for Air-Gapped ROS 2 Deployments
Hello ROS 2 Security Working Group,
I’ve developed a lightweight, air-gapped security observability module for
ROS 2 deployments in environments where cloud connectivity is undesirable
(edge robotics, humanitarian infrastructure, privacy-sensitive applications).
Technical Scope:
- Read-only DDS introspection (no publishers/services)
- Localhost-only dashboard (127.0.0.1)
- Docker containerized with non-root execution
- Zero external dependencies
- Real-time system monitoring (CPU, memory, network)
Target Platforms:
- Boston Dynamics Spot (payload compute)
- Humanoid platforms (Digit, Figure 02)
- Edge/lab environments
Current Status:
- Working prototype with backend monitoring
- Docker Compose integration with ROS 2 Humble
- Internal bridge network (air-gapped by default)
Repository: GitHub - coldnsteel/HackerWatchFortress-Sovereign: Sovereign Security Dashboard - No Government Ties
I’m seeking feedback on:
1. SROS 2 alignment best practices
2. Passive DDS monitoring patterns
3. Air-gapped security logging standards
Any guidance would be appreciated.
Best regards,
Monk Bartholomew
lexalytics@yahoo.com
Thanks,
What is this? I read the code, which is absolutely minimal, and doesn’t seem to be doing anything. It serves a minimal web page that establishes a websocket connection to the server which in turn does nothing more than acknowledging the request to start monitoring, but after that it seems neither client nor server are sending any messages. It also starts a second container (humble desktop) which seems unconnected to the first, and in particular the first container doesn’t seem to be “monitoring” anything about the second.
At first I thought this might be malware, but I couldn’t find anything fishy about it even though nothing about this seems overly trustworthy.
Monk: you say “Working prototype with backend monitoring” is part of the current status. What does that mean? What are you monitoring and why does your code not reflect that? Am I missing something?
