Is OTA for ROS 2 robots a solved problem?
I could not find anything out there built specifically for OTA updates in the ROS 2 ecosystem. Coming from the web I wanted to see how close I could get to the developer experience I know, so I built a small project on a Raspberry Pi. The device pulls new container images from GitHub releases, runs a health check and rolls back automatically if a release is broken.
It turned out to be harder than just shipping Docker containers. My updater for example could not update itself. A/B updates seem to solve that, but each approach has its trade-offs.
So I would love to hear from people who run robots in production. What did you pick and why? Is anything still painful with Mender, balena or other tools or do they already cover everything?
Write-up: The code was the easy part - Max Riazantsev
Code: https://github.com/maxriazantsev/vision-stand
There recently was a related thread: How are you handling firmware updates on fleet robots without bricking one?
Very nice write-up! You said MacOS is not really supported. Did you go the Homebrew way or the Pixi way?
Love the project, nice work and thanks for sharing! OTA for robots is far from a solved problem – in fact, it’s our first product at Agency Tool Company because it’s such a common bottleneck to fielding real robots.
Web tools like Docker can help get an initial system up and running like you did here but to go beyond (e.g. signed releases, OS management, push and pull workflows, delta updates) I believe it takes something designed and built specifically for our sorts of robotics applications with all the challenges you mention in your post.
Feel free to join the waitlist here
Thanks everyone for the replies!
@JRTG Really good thread, thank you for sharing. Microcontrollers are new to me and it seems like a really hard problem to solve. As I understand this is a main gap right now
@peci1 Neither actually. I ran Linux in a virtual machine on my MacBook and connected to it from my IDE through JetBrains Gateway. It was quite painful to set up but works fine once everything is in place. What would you recommend for macOS today?
@chachi Glad you liked it and good to see someone tackling this. Robots clearly need a lot more than what I built. Joined the waitlist and will follow along. Would love to try it once it is ready
Hi @maxh1t!
Nice project! The challenge of updating the updater itself is an interesting one.
At Toradex, we use OSTree in Torizon OS as an alternative to traditional A/B partitioning. It provides atomic OS updates and rollback without requiring two full rootfs partitions, while our OTA infrastructure follows the Uptane standard for secure updates.
The OTA client (Aktualizr) is part of the OS, so it can also be updated through an OS update. We support container updates as well, allowing both the OS and applications to be managed through the same update infrastructure.
Might be worth checking out our architecture: Torizon Updates Architecture | Toradex Developer Center
I’m not a macOS user myself, but I have tried the Pixi way on MacOS. I’m a big fan of RoboStack with Pixi on Ubuntu (22.04, 24.04 and 26.04). It makes switching between ROS distros really easy.
While preparing MSc labs in early 2026, I tried Pixi on macOS to see whether we could support every student’s laptop. It mostly worked, but networking was the sticking point. The main issue was nodes not discovering each other, which I never fully got to the bottom of.
I’d be curious what is recommended today, and whether those issues are common or have a known solution.
Hi, I recently moved most of my ROS development from Ubuntu to macOS. While there are still some rough edges, I really like the Pixi + RoboStack workflow and have not encountered any network discovery issues so far.
Could you share which distro and RMW implementation you were using? A minimal reproducer would be ideal, and I would be happy to take a look when I have some free time
