Introducing: `ros2_fmt_logger`
Tired of fixing compile issues like:
warning: format ‘%d’ expects argument of type ‘int’, but argument has type ‘std::vector<int>::size_type’ {aka ‘long unsigned int’} [-Wformat=]
when you want to print a vector size?
Or writing .c_str() when printing an std::string?
Confused when using milliseconds to throttle?[1]
Introducing:
ros2_fmt_logger
A modern, ROS 2 logging library that provides fmt-style formatting as a replacement for RCLCPP logging macros.
Features
  • Function calls instead of macros: logger.info("Hello, {}!", name) instead of RCLCPP_INFO(logger, "Hello, %s", name.c_str())
  • Additional .on_change() method for logging changes in values
  • chrono syntax for throttling: logger.warn_throttle(1s, "Warning: {}", value)
  • backwards compatible with the macros, so easy to start using in existing projects without a full rewrite of the current log statements
Examples
Once-only logging
logger.info_once("This message will only appear once, no matter how many times called");
Throttled logging
using std::chrono_literals::operator""s;
logger.warn_throttle(1s, "This warning appears at most once per second: {}", value);
Change-based logging
// Log only when the value changes
logger.info_on_change(sensor_value, "Sensor reading changed to: {}", sensor_value);
// Log only when change exceeds threshold
logger.error_on_change(temperature, 5.0, "Temperature changed significantly: {:.1f}°C", temperature);
Format String Syntax
Uses the powerful fmt library format syntax:
// Basic formatting
logger.info("Hello, {}!", name);
// Positional arguments
logger.info("Processing {1} of {0} items", total, current);
// Format specifiers
logger.info("Progress: {:.1%}", progress);  // Percentage with 1 decimal
logger.info("Value: {:08.2f}", value);     // Zero-padded floating point
logger.info("Hex: {:#x}", number);         // Hexadecimal with 0x prefix
// Container formatting (requires fmt/ranges.h)
logger.info("Values: {}", std::vector{1, 2, 3, 4});
See demo_ros2_fmt_logger.cpp for more examples.
NAQ
  • Why not use std::format?
    • fmt is still more powerful, like when printing ranges. Also rclcpp already depends on it indirectly, so it’s kind of free.
  • Isn’t this why we have _STREAM macros?
    • Yes, but it’s longer :smiley:
      double progress = 0.756;
      logger.info("Progress: {:.1} %", progress);
      RCLCPP_INFO_STREAM(logger, "Progress: " << std::setprecision(1) << progress << " %");
  1. This is a direct violation of REP-103 ↩︎
I thought I was having déjà vu, but it turns out @facontidavide released something similar a few years ago: GitHub - facontidavide/ros2_logging_fmt.
I would love to see this style of logging be adopted in rclcpp.
Indeed! I did encounter that during my search for it.
But I wanted to avoid using the macros altogether.
Perhaps I should have named it YAfmt_logger :smiley:
:glowing_star: Feature update: ROS Type Formatting :glowing_star:
There is now support for for common ROS types
As per request by @solonovamax
Supported types
Type Example output
rclcpp::Duration 0.8s, 5s
rclcpp::Time 2024-05-11 10:40:00
rclcpp::(Wall)Rate 10Hz, 0.5Hz
#include <ros2_fmt_logger/rclcpp_formatters.hpp>
#include <ros2_fmt_logger/ros2_fmt_logger.hpp>
rclcpp::Duration duration{800ms};
logger.info("Duration: {}", duration);  // "Duration: 0.8s"
rclcpp::Time time = node->get_clock()->now();
// Default human-readable format or custom fmt chrono format specifiers:
logger.info("Default: {}", time);        // "Default: 2026-02-24 08:59:17"
logger.info("Date: {:%Y-%m-%d}", time);  // "Date: 2026-02-24"
