Index.ros.org/doc/ros2 is being retired
Hot on the heels of Docs.ros2.org is being retired - ROS General - Open Robotics Discourse , we are also retiring the ROS 2 documentation on https://index.ros.org/doc/ros2.
Note that this is not retiring the index; you will still be able to search for and find packages there. What this is doing is moving the ROS 2 documentation that is hosted there to https://docs.ros.org . Once the transition happens, there will be redirects from all of the old pages to appropriate places on https://docs.ros.org . I’ll drop another note here once the transition actually happens. As before, if you notice problems after the switch, please reply to this thread and we’ll look into it.
All right, the transition has happened. Hitting any of the old pages on https://index.ros.org/doc/ros2 should now redirect you to https://docs.ros.org in the appropriate place. Please respond to this thread if you notice issues with any pages you have linked/bookmarked.
