Posted by @alex-roba:
I’ve identified a scenario where the robot’s in-place rotation can be unintentionally skipped. This issue arises when a fleet adapter receives a new go_to_place command that overrides an existing one. Specifically, if the robot is currently rotating to align itself with a docking station, the new go_to_place command can override the correct in-place rotation, causing the robot to approach the dock at an incorrect angle. Below, I’ll describe the problem and provide supporting log evidence.
Scenario Description
Initial State: The robot (nanos10002) is following a path with multiple waypoints, including an in-place rotation to face the dock correctly.
Correct Rotation Command: The robot is commanded to rotate to an angle of -1.57079633 radians (≈ -90°) at position [2.91248069, -0.87074165] (cmd_id 179), preparing it to dock.
Interruption: Before the rotation completes, a new go_to_place request (pgv_dock_m3) is received, specifying a single waypoint with a slightly different position [2.90602542, -0.86592286] and an incorrect angle of -1.73497393 radians (≈ -99.4°, cmd_id 180).
Result: The robot navigates to this new waypoint, overriding the correct rotation. It then attempts to dock at [2.91248069, -1.67395578, -1.57079633] (cmd_id 181) with an unaligned initial angle, potentially causing docking failure.
This suggests that the new go_to_place command does not preserve the robot’s ongoing rotation state, leading to misalignment.
[fleet_adapter-1] [INFO] [1744083666.468903268] [Robots100loading_fleet_adapter]: All mutex groups were already locked for [Robots100loading/nanos10002]
[fleet_adapter-1] [INFO] [1744083666.469979447] [Robots100loading_command_handle]: Received new follow path request for robot [nanos10002] with 6 waypoints which are:
[fleet_adapter-1] [INFO] [1744083666.470730243] [Robots100loading_command_handle]: Waypoint: wp_7 at [ 5.13437317 -1.621381 1.57079633] on map L1
[fleet_adapter-1] [INFO] [1744083666.471417627] [Robots100loading_command_handle]: Waypoint: wp_3 at [ 5.13437317 -0.87074165 1.57079633] on map L1
[fleet_adapter-1] [INFO] [1744083666.472153379] [Robots100loading_command_handle]: Waypoint: wp_3 at [ 5.13437317 -0.87074165 3.14159265] on map L1
[fleet_adapter-1] [INFO] [1744083666.472816431] [Robots100loading_command_handle]: Waypoint: at [ 3.86909548 -0.87074165 3.14159265] on map L1
[fleet_adapter-1] [INFO] [1744083666.473528103] [Robots100loading_command_handle]: Waypoint: at [ 2.91248069 -0.87074165 3.14159265] on map L1
[fleet_adapter-1] [INFO] [1744083666.474228717] [Robots100loading_command_handle]: Waypoint: at [ 2.91248069 -0.87074165 -1.57079633] on map L1
[fleet_adapter-1] [INFO] [1744083666.474857221] [Robots100loading_command_handle]: Commanding [nanos10002] to navigate to wp_7 at [ 5.13437317 -1.621381 1.57079633] on map [L1]: cmd_id 174
[fleet_adapter-1] [INFO] [1744083670.093262726] [Robots100loading_command_handle]: Commanding [nanos10002] to navigate to wp_3 at [ 5.13437317 -0.87074165 1.57079633] on map [L1]: cmd_id 175
[fleet_adapter-1] [INFO] [1744083675.730674145] [Robots100loading_command_handle]: Commanding [nanos10002] to navigate to wp_3 at [ 5.13437317 -0.87074165 3.14159265] on map [L1]: cmd_id 176
[fleet_adapter-1] [INFO] [1744083679.252714801] [Robots100loading_command_handle]: Commanding [nanos10002] to navigate to at [ 3.86909548 -0.87074165 3.14159265] on map [L1]: cmd_id 177
[fleet_adapter-1] [INFO] [1744083683.881142164] [Robots100loading_command_handle]: Commanding [nanos10002] to navigate to at [ 2.91248069 -0.87074165 3.14159265] on map [L1]: cmd_id 178
[fleet_adapter-1] [INFO] [1744083688.219801130] [Robots100loading_command_handle]: Commanding [nanos10002] to navigate to at [ 2.91248069 -0.87074165 -1.57079633] on map [L1]: cmd_id 179 ----- correct angle
[fleet_adapter-1] [INFO] [1744083690.965974420] [Robots100loading_fleet_adapter]: Executing final go_to_place [pgv_dock_m3] for robot [Robots100loading/nanos10002]
[fleet_adapter-1] [INFO] [1744083690.967562216] [Robots100loading_command_handle]: Received new follow path request for robot [nanos10002] with 1 waypoints which are:
[fleet_adapter-1] [INFO] [1744083690.968520536] [Robots100loading_command_handle]: Waypoint: at [ 2.90602542 -0.86592286 -1.73497393] on map L1
[fleet_adapter-1] [INFO] [1744083692.075082287] [Robots100loading_command_handle]: Commanding [nanos10002] to navigate to at [ 2.90602542 -0.86592286 -1.73497393] on map [L1]: cmd_id 180 ------ wrong angle
[fleet_adapter-1] [INFO] [1744083692.843438326] [Robots100loading_command_handle]: Commanding [nanos10002] to dock to pgv_dock_m3 at [ 2.91248069 -1.67395578 -1.57079633] on map [L1]: cmd_id 181
