As an input I have a topic name. I want to get the message type of this topic.
I know how to find the string type name using node->get_topic_names_and_types();. The resulting string type name is smth like rcl_interfaces/msg/ParameterEvent (just for example)
Is there any ways in C++ how to get the instance of rcl_interfaces::msg::ParameterEvent or it bumps into C++ being static typed language?
In Python I found the following way of doing that:
import argparse
from ros2cli.node.strategy import NodeStrategy
import rosidl_runtime_py.utilities
with NodeStrategy(argparse.Namespace()) as node:
for (
topic,
topic_type,
) in node.daemon_node.get_topic_names_and_types():
if topic == requested_topic:
requested_type_str = topic_type[0]
topic_type = rosidl_runtime_py.utilities.get_message(requested_type_str)
print(topic_type) # would print something like <class 'my_custom_package.msg._my_custom_message.MyCustomMessage'>)
If you want to have a normal message layout, lazy copy, the ability to also create and publish messages, action, and service support, the tool you want is:
There are also multiple examples on how to use it to get you started.
Here’s a short example for subscription
using namespace ros_babel_fish; // Except Node all of the following classes are in that namespace
Node node;
BabelFish::SharedPtr fish = BabelFish::make_shared();
// Subscribe topic /pose
BabelFishSubscription::SharedPtr sub = fish->create_subscription( node, topic, 1, &callback );
void callback( const ros_babel_fish::CompoundMessage::SharedPtr &msg )
std::cout << "Message received!" << std::endl;
std::cout << "Datatype:" << msg->datatype() << std::endl; // geometry_msgs::msg::Pose
std::cout << "Name:" << msg->name() << std::endl; // geometry_msgs/msg/Pose
std::cout << "Message Content:" << std::endl;
const CompoundMessage &compound = *msg;
std::cout << "Position: " << compound["position"]["x"].value<double>() << ", " << compound["position"]["y"].value<double>() << ", "
<< compound["position"]["z"].value<double>() << std::endl;
// Alternatively, you can use the new get<T> convenience method
std::cout << "Orientation: " << compound["orientation"].get<double>("w") << ", " << compound["orientation"].get<double>("x") << ", "
<< compound["orientation"].get<double>("y") << ", " << compound["orientation"].get<double>("z") << std::endl;
