How much RTK fix do your outdoor robots keep under tree canopy? Field data and a test design
For those of you running outdoor robots (lawn mowers, orchard or vineyard platforms, campus AMRs), how much RTK fix do you actually keep under tree canopy?
We recently went through a field test that logged several RTK receivers side by side under roadside trees, and I thought the numbers, and their limits, might be useful here.
What was logged (all at about 10 Hz, viewed in RTKPLOT):
  • Half sky + rain, 21.9 km baseline, about 61 min
  • Under trees + rain, 16.4 km baseline, about 39 min
  • Under trees + network RTK, 1.99 km baseline, about 61 min
What the status bars showed:
  • In both long-baseline sessions, three of four record groups (Septentrio mosaic-X5 / mosaic-H based receivers) held 100% fixed (Q=1) for the whole session.
  • One record group dropped to 83.3% (half sky) and 88.5% (under trees) fixed, with the rest float or DGPS. The ground track shows jumps of tens of centimetres when that happens.
  • On the 1.99 km network RTK session, both record groups held 100%.
What it can’t tell you: there was no ground truth and no raw observation data, the sessions changed canopy, baseline, correction source and weather all at once, and there was one unit per position. So it’s a status comparison, not an accuracy ranking. A fixed flag doesn’t prove the position was right.
If you’re evaluating receivers for a robot that works under trees, this is the test design we’d recommend:
  1. Same site, baseline and correction source; cross open-sky/under-canopy with dry/wet, three or more repeats each
  2. A known control point or a long static baseline as truth
  3. Log raw observations so every receiver can be reprocessed with the same RTKLIB settings
  4. At least two units per model; log heading at the same time on dual-antenna setups
  5. Report RMS and 95th percentile, time to first fix and availability, not only fix ratio, after decimating to 1 Hz
On the ROS side, the septentrio_gnss_driver publishes the solution status, so you can log fix state alongside your localization output and see exactly where under the canopy your EKF starts leaning on odometry.
The full write-up with all 36 figures and per-screenshot readings is here: RTK fix ratio under tree canopy and rain
I’d be interested to hear what others see in practice: do you gate your localization on fix status, or blend float solutions with a larger covariance?
Disclosure: I work with Eview GNSS, which makes receivers based on Septentrio modules. Test data was supplied by the test team and is used with permission.
I’m eager to see others’ experiences.
For your writeup, I think a must add is the type of antennas you used. Are they calibrated? Are they 2/3/4-band? Are they multifeed? Do they have a choke ring? These are all parameters that pull both the price and performance up quite a lot. Also, to some extent, cables and connectors matter, too.
In our experiments with Mosaic-H (either eval kit or Ardusimple), the height of the antennas above ground seems to make quite a lot of difference (at least without choke ring). Our robots carry antennas as low as 50 cm above ground, and that seems to be about the limit. I remember one test when just moving the antnenna 2 cm lower got C/N0 10 points down for most signals. It seems that car rooftops are especially good in this regard :slight_smile: My working theory is that as you’re getting closer to the ground, multipath effects are both stronger and closer to the direct signal, which makes correlating the signal much harder. But I’m no radio guy =)
In general, with Mosaic-H and helical antennas, we got float most of the time under trees, or single/DGPS.
Thanks @peci1, that’s a very useful point, and you’re right that it’s missing. The source material doesn’t say which antennas were used. From the site photos they look like roof-mounted puck-style survey antennas on a car (so roughly 1.6–1.8 m above ground, with the car roof acting as a ground plane), but the model, band count, calibration and cabling weren’t recorded. That’s another reason the numbers should be read as a status comparison rather than a performance ranking.
Your height observation matches what we’d expect: at 50 cm the antenna sees much more ground-reflected multipath at low elevation, and without a choke ring or a good ground plane that eats directly into C/N0. A 10 dB-Hz drop from a 2 cm change is striking. Do you know whether that was mainly on the low-elevation satellites, or across the board?
I’ll add these to the retest checklist:
  • Antenna make and model, number of bands, single- vs multi-feed, phase-centre calibration (and whether the ANTEX values were applied)
  • Ground plane or choke ring, and the height above ground
  • Cable type and length, and the connectors
  • Low-mount (robot-height, ~0.5 m) versus roof-mount runs at the same site, so the height effect can be separated from the canopy effect
If anyone has logged C/N0 versus antenna height under canopy, I’d be very interested in seeing it.
I think low elevation satellites were not present at all when we were doing this particular test. We did it in a closed courtyard with 4-storey buildings all around, so I guess the lowest actually visible elevation was roughly 25°.
Our robots’ bodies do not form any kind of ground plane. We usually put the antennas on poles. Helical antennas shouldn’t need any ground plane, so we use either none or a 10 cm copper disc. For classical puck-like antennas, we try to provide a ground plane as large as we can, but we rarely get to 1 wavelength radius (we’re usually happy to fit at least 10 cm diameter).
Thanks @williammoore and @peci1, both points go into the retest plan.
To be clear on the original data: those runs were roof-mounted on a car, so the car roof acted as a large ground plane. The 50 cm / 10 dB-Hz observation was @peci1’s robot experience, not part of our test.
For the retest we’ll log:
  • raw observations (so phase-centre / ANTEX questions can be checked afterwards), plus the antenna model and mounting height;
  • C/N0 binned by elevation band (for example 0–15°, 15–30°, 30–60°, 60–90°), to see whether canopy and near-ground multipath hit the low satellites hardest. As @peci1 notes, under dense canopy the lowest band may simply be empty;
  • plate-on vs plate-off pairs at the same height (a 10 cm disc and a larger plate), to separate the ground-plane effect from height.
@peci1, have you seen a clear difference between helical and puck antennas under canopy specifically, or mainly in open sky?
Thanks for sharing the session setup, the “status comparison, not an accuracy ranking” caveat is the right framing. A few things I would add to the retest, mostly from the outdoor-sensing side:
  1. Log raw observations (RINEX or the receiver’s native format) plus per-satellite C/N0 and elevation/azimuth, not only the Q flag. Under canopy the interesting number is usually the C/N0 drop versus elevation. Foliage attenuation hits low-elevation satellites hardest and also causes multipath, so a fixed flag can still sit on a poor position. Binning C/N0 by 10-degree elevation bands, as you plan, will show it clearly.
  2. To get ground truth cheaply, add two or three surveyed marks along the route (a total station or a good open-sky static occupation) and drive over them at walking speed. A fixed flag plus a few-centimetre error at known marks says far more than the flag alone.
  3. Antenna height and ground plane matter, as pec11 noted. On a car roof you get a large ground plane, but on a low robot the antenna sits close to wet grass or the chassis. If the platform allows, test the same antenna at two heights and with and without a ground plate, and note the radome and cable type, since a wet radome adds a little extra loss in rain.
  4. Rain and canopy water are confounders. Compare dry and wet passes on the same stretch, otherwise rain, baseline and canopy all change at once, as you pointed out.
  5. For the robot itself, ask what the stack does when RTK drops to float. A wheel-odometry plus IMU filter that holds the pose for a few seconds is often the difference between a mower or orchard platform recovering gracefully and a path jump of tens of centimetres. Logging how long float periods last would be useful for choosing the dead-reckoning budget.
Would you be able to share the elevation-binned C/N0 plots once the retest is done? I think that would be the most reusable result for people picking antennas for tree-lined routes.
