Hello,
I am following the tutorial (Source Installation on Ubuntu — Gazebo garden documentation) to install Gazebo Garden from source on Ubuntu 22.04. I am using a Parallels VM on my Mac M1 (ARM64).
When I ran “colcon build --merge-install”, the below error appeared for the gz-rendering7 library. It appears to have something to do with Ogre. Do you guys have any suggestions for how I can fix this?
As an FYI, I was able to run Gazebo Garden (not installed from source) on a different Ubuntu 22.04 VM. On that machine, I had to resort to ogre1 with the tag “–render-engine ogre” but otherwise had no difficulties. Perhaps this might have something to do with the below problem.
/usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerra.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre9HlmsTerraE' which may bind externally can not be used when making a shared object; recompile with -fPIC ../../lib/libterra.a(OgreHlmsTerra.cpp.o): in function Ogre::HlmsTerra::~HlmsTerra()‘:
/home/parallels/workspace/src/gz-rendering/ogre2/src/terrain/Terra/src/Hlms/OgreHlmsTerra.cpp:94:(.text+0x4): dangerous relocation: unsupported relocation
/usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerra.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre9HlmsTerraE' which may bind externally can not be used when making a shared object; recompile with -fPIC /home/parallels/workspace/src/gz-rendering/ogre2/src/terrain/Terra/src/Hlms/OgreHlmsTerra.cpp:94:(.text+0x10): dangerous relocation: unsupported relocation /usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerra.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre9HlmsTerraE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
../../lib/libterra.a(OgreHlmsTerra.cpp.o): in function Ogre::HlmsTerra::~HlmsTerra()': /home/parallels/workspace/src/gz-rendering/ogre2/src/terrain/Terra/src/Hlms/OgreHlmsTerra.cpp:94:(.text+0x294): dangerous relocation: unsupported relocation /usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerra.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre9HlmsTerraE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
/home/parallels/workspace/src/gz-rendering/ogre2/src/terrain/Terra/src/Hlms/OgreHlmsTerra.cpp:94:(.text+0x2a0): dangerous relocation: unsupported relocation
/usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerra.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre9HlmsTerraE' which may bind externally can not be used when making a shared object; recompile with -fPIC ../../lib/libterra.a(OgreHlmsTerra.cpp.o): in function non-virtual thunk to Ogre::HlmsTerra::~HlmsTerra()‘:
/usr/include/OGRE-2.3/OgreMemoryStdAlloc.h:136:(.text+0x2e4): dangerous relocation: unsupported relocation
/usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerra.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre9HlmsTerraE' which may bind externally can not be used when making a shared object; recompile with -fPIC /usr/include/OGRE-2.3/OgreMemoryStdAlloc.h:136:(.text+0x2e8): dangerous relocation: unsupported relocation /usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerra.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre9HlmsTerraE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
../../lib/libterra.a(OgreHlmsTerra.cpp.o): in function non-virtual thunk to Ogre::HlmsTerra::~HlmsTerra()': /usr/include/OGRE-2.3/OgreMemoryStdAlloc.h:136:(.text+0x338): dangerous relocation: unsupported relocation /usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerra.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre9HlmsTerraE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
/usr/include/OGRE-2.3/OgreMemoryStdAlloc.h:136:(.text+0x33c): dangerous relocation: unsupported relocation
/usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerra.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZN4Ogre12HlmsListener15hlmsTypeChangedEbPNS_13CommandBufferEPKNS_13HlmsDatablockEm' which may bind externally can not be used when making a shared object; recompile with -fPIC ../../lib/libterra.a(OgreHlmsTerra.cpp.o): in function Ogre::HlmsTerra::fillBuffersFor(Ogre::HlmsCache const*, Ogre::QueuedRenderable const&, bool, unsigned int, Ogre::CommandBuffer*, bool)‘:
/home/parallels/workspace/src/gz-rendering/ogre2/src/terrain/Terra/src/Hlms/OgreHlmsTerra.cpp:631:(.text+0xcc0): dangerous relocation: unsupported relocation
/usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerra.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre9HlmsTerraE' which may bind externally can not be used when making a shared object; recompile with -fPIC ../../lib/libterra.a(OgreHlmsTerra.cpp.o): in function Ogre::HlmsTerra::HlmsTerra(Ogre::Archive*, std::vector<Ogre::Archive*, Ogre::STLAllocator<Ogre::Archive*, Ogre::CategorisedAllocPolicy<(Ogre::MemoryCategory)0> > >)‘:
/home/parallels/workspace/src/gz-rendering/ogre2/src/terrain/Terra/src/Hlms/OgreHlmsTerra.cpp:78:(.text+0x1d94): dangerous relocation: unsupported relocation
/usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerra.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre9HlmsTerraE' which may bind externally can not be used when making a shared object; recompile with -fPIC /home/parallels/workspace/src/gz-rendering/ogre2/src/terrain/Terra/src/Hlms/OgreHlmsTerra.cpp:78:(.text+0x1da4): dangerous relocation: unsupported relocation /usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerraDatablock.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre29HlmsTerraBaseTextureDatablockE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
../../lib/libterra.a(OgreHlmsTerraDatablock.cpp.o): in function Ogre::HlmsTerraBaseTextureDatablock::HlmsTerraBaseTextureDatablock(Ogre::IdString, Ogre::Hlms*, Ogre::HlmsMacroblock const*, Ogre::HlmsBlendblock const*, std::vector<std::pair<Ogre::IdString, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, Ogre::STLAllocator<std::pair<Ogre::IdString, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, Ogre::CategorisedAllocPolicy<(Ogre::MemoryCategory)0> > > const&)': /usr/include/OGRE-2.3/Hlms/Common/OgreHlmsTextureBaseClass.inl:26:(.text+0x898): dangerous relocation: unsupported relocation /usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerraDatablock.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre29HlmsTerraBaseTextureDatablockE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
/usr/include/OGRE-2.3/Hlms/Common/OgreHlmsTextureBaseClass.inl:26:(.text+0x8a4): dangerous relocation: unsupported relocation
/usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerraDatablock.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre29HlmsTerraBaseTextureDatablockE' which may bind externally can not be used when making a shared object; recompile with -fPIC /usr/include/OGRE-2.3/Hlms/Common/OgreHlmsTextureBaseClass.inl:26:(.text+0x8a8): dangerous relocation: unsupported relocation /usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerraDatablock.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre29HlmsTerraBaseTextureDatablockE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
../../lib/libterra.a(OgreHlmsTerraDatablock.cpp.o): in function Ogre::HlmsTerraBaseTextureDatablock::~HlmsTerraBaseTextureDatablock()': /usr/include/OGRE-2.3/Hlms/Common/OgreHlmsTextureBaseClass.inl:36:(.text+0x938): dangerous relocation: unsupported relocation /usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerraDatablock.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre29HlmsTerraBaseTextureDatablockE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
/usr/include/OGRE-2.3/Hlms/Common/OgreHlmsTextureBaseClass.inl:36:(.text+0x954): dangerous relocation: unsupported relocation
/usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerraDatablock.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre29HlmsTerraBaseTextureDatablockE' which may bind externally can not be used when making a shared object; recompile with -fPIC /usr/include/OGRE-2.3/Hlms/Common/OgreHlmsTextureBaseClass.inl:36:(.text+0x970): dangerous relocation: unsupported relocation /usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerraDatablock.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre18HlmsTerraDatablockE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
../../lib/libterra.a(OgreHlmsTerraDatablock.cpp.o): in function Ogre::HlmsTerraDatablock::~HlmsTerraDatablock()': /home/parallels/workspace/src/gz-rendering/ogre2/src/terrain/Terra/src/Hlms/OgreHlmsTerraDatablock.cpp:88:(.text+0xa24): dangerous relocation: unsupported relocation /usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerraDatablock.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre18HlmsTerraDatablockE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
/home/parallels/workspace/src/gz-rendering/ogre2/src/terrain/Terra/src/Hlms/OgreHlmsTerraDatablock.cpp:88:(.text+0xa38): dangerous relocation: unsupported relocation
/usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerraDatablock.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre18HlmsTerraDatablockE' which may bind externally can not be used when making a shared object; recompile with -fPIC /home/parallels/workspace/src/gz-rendering/ogre2/src/terrain/Terra/src/Hlms/OgreHlmsTerraDatablock.cpp:88:(.text+0xa3c): dangerous relocation: unsupported relocation /usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerraDatablock.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre18HlmsTerraDatablockE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
../../lib/libterra.a(OgreHlmsTerraDatablock.cpp.o): in function Ogre::HlmsTerraDatablock::~HlmsTerraDatablock()': /home/parallels/workspace/src/gz-rendering/ogre2/src/terrain/Terra/src/Hlms/OgreHlmsTerraDatablock.cpp:88:(.text+0xa84): dangerous relocation: unsupported relocation /usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerraDatablock.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre18HlmsTerraDatablockE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
/home/parallels/workspace/src/gz-rendering/ogre2/src/terrain/Terra/src/Hlms/OgreHlmsTerraDatablock.cpp:88:(.text+0xa98): dangerous relocation: unsupported relocation
/usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerraDatablock.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre18HlmsTerraDatablockE' which may bind externally can not be used when making a shared object; recompile with -fPIC /home/parallels/workspace/src/gz-rendering/ogre2/src/terrain/Terra/src/Hlms/OgreHlmsTerraDatablock.cpp:88:(.text+0xa9c): dangerous relocation: unsupported relocation /usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerraDatablock.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre18HlmsTerraDatablockE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
../../lib/libterra.a(OgreHlmsTerraDatablock.cpp.o): in function non-virtual thunk to Ogre::HlmsTerraDatablock::~HlmsTerraDatablock()': /usr/include/OGRE-2.3/OgreMemoryStdAlloc.h:80:(.text+0xae8): dangerous relocation: unsupported relocation /usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerraDatablock.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre18HlmsTerraDatablockE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
/usr/include/OGRE-2.3/OgreMemoryStdAlloc.h:80:(.text+0xb00): dangerous relocation: unsupported relocation
/usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerraDatablock.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre18HlmsTerraDatablockE' which may bind externally can not be used when making a shared object; recompile with -fPIC /usr/include/OGRE-2.3/OgreMemoryStdAlloc.h:80:(.text+0xb04): dangerous relocation: unsupported relocation /usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerraDatablock.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre18HlmsTerraDatablockE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
../../lib/libterra.a(OgreHlmsTerraDatablock.cpp.o): in function non-virtual thunk to Ogre::HlmsTerraDatablock::~HlmsTerraDatablock()': /usr/include/OGRE-2.3/OgreMemoryStdAlloc.h:80:(.text+0xb54): dangerous relocation: unsupported relocation /usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerraDatablock.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre18HlmsTerraDatablockE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
/usr/include/OGRE-2.3/OgreMemoryStdAlloc.h:80:(.text+0xb6c): dangerous relocation: unsupported relocation
/usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerraDatablock.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre18HlmsTerraDatablockE' which may bind externally can not be used when making a shared object; recompile with -fPIC /usr/include/OGRE-2.3/OgreMemoryStdAlloc.h:80:(.text+0xb70): dangerous relocation: unsupported relocation /usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerraDatablock.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre18HlmsTerraDatablockE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
../../lib/libterra.a(OgreHlmsTerraDatablock.cpp.o): in function Ogre::HlmsTerraDatablock::HlmsTerraDatablock(Ogre::IdString, Ogre::HlmsTerra*, Ogre::HlmsMacroblock const*, Ogre::HlmsBlendblock const*, std::vector<std::pair<Ogre::IdString, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, Ogre::STLAllocator<std::pair<Ogre::IdString, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, Ogre::CategorisedAllocPolicy<(Ogre::MemoryCategory)0> > > const&)': /home/parallels/workspace/src/gz-rendering/ogre2/src/terrain/Terra/src/Hlms/OgreHlmsTerraDatablock.cpp:72:(.text+0x1860): dangerous relocation: unsupported relocation /usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerraDatablock.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre18HlmsTerraDatablockE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
/home/parallels/workspace/src/gz-rendering/ogre2/src/terrain/Terra/src/Hlms/OgreHlmsTerraDatablock.cpp:72:(.text+0x188c): dangerous relocation: unsupported relocation
/usr/bin/ld: ../../lib/libterra.a(OgreHlmsTerraDatablock.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre18HlmsTerraDatablockE' which may bind externally can not be used when making a shared object; recompile with -fPIC /home/parallels/workspace/src/gz-rendering/ogre2/src/terrain/Terra/src/Hlms/OgreHlmsTerraDatablock.cpp:72:(.text+0x1890): dangerous relocation: unsupported relocation /usr/bin/ld: ../../lib/libterra.a(OgreHlmsPbsTerraShadows.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre19HlmsPbsTerraShadowsE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
../../lib/libterra.a(OgreHlmsPbsTerraShadows.cpp.o): in function Ogre::HlmsPbsTerraShadows::HlmsPbsTerraShadows()': /home/parallels/workspace/src/gz-rendering/ogre2/src/terrain/Terra/src/Hlms/PbsListener/OgreHlmsPbsTerraShadows.cpp:47:(.text+0x3d0): dangerous relocation: unsupported relocation /usr/bin/ld: ../../lib/libterra.a(OgreHlmsPbsTerraShadows.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre19HlmsPbsTerraShadowsE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
../../lib/libterra.a(OgreHlmsPbsTerraShadows.cpp.o): in function Ogre::HlmsPbsTerraShadows::~HlmsPbsTerraShadows()': /home/parallels/workspace/src/gz-rendering/ogre2/src/terrain/Terra/src/Hlms/PbsListener/OgreHlmsPbsTerraShadows.cpp:54:(.text+0x3e8): dangerous relocation: unsupported relocation /usr/bin/ld: ../../lib/libterra.a(Terra.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre5TerraE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
../../lib/libterra.a(Terra.cpp.o): in function Ogre::Terra::~Terra()': /home/parallels/workspace/src/gz-rendering/ogre2/src/terrain/Terra/src/Terra.cpp:107:(.text+0xf4): dangerous relocation: unsupported relocation /usr/bin/ld: ../../lib/libterra.a(Terra.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre5TerraE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
../../lib/libterra.a(Terra.cpp.o): in function Ogre::Terra::Terra(unsigned int, Ogre::ObjectMemoryManager*, Ogre::SceneManager*, unsigned char, Ogre::CompositorManager2*, Ogre::Camera*, bool)': /home/parallels/workspace/src/gz-rendering/ogre2/src/terrain/Terra/src/Terra.cpp:96:(.text+0x538): dangerous relocation: unsupported relocation /usr/bin/ld: ../../lib/libterra.a(TerraWorkspaceListener.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre22TerraWorkspaceListenerE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
../../lib/libterra.a(TerraWorkspaceListener.cpp.o): in function Ogre::TerraWorkspaceListener::TerraWorkspaceListener(Ogre::HlmsTerra*)': /home/parallels/workspace/src/gz-rendering/ogre2/src/terrain/Terra/src/TerraWorkspaceListener.cpp:44:(.text+0x1e0): dangerous relocation: unsupported relocation /usr/bin/ld: ../../lib/libterra.a(TerrainCell.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre11TerrainCellE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
../../lib/libterra.a(TerrainCell.cpp.o): in function Ogre::TerrainCell::~TerrainCell()': /home/parallels/workspace/src/gz-rendering/ogre2/src/terrain/Terra/src/TerrainCell.cpp:50:(.text+0x14): dangerous relocation: unsupported relocation /usr/bin/ld: ../../lib/libterra.a(TerrainCell.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre11TerrainCellE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
../../lib/libterra.a(TerrainCell.cpp.o): in function Ogre::TerrainCell::~TerrainCell()': /home/parallels/workspace/src/gz-rendering/ogre2/src/terrain/Terra/src/TerrainCell.cpp:50:(.text+0x84): dangerous relocation: unsupported relocation /usr/bin/ld: ../../lib/libterra.a(TerrainCell.cpp.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol _ZTVN4Ogre11TerrainCellE’ which may bind externally can not be used when making a shared object; recompile with -fPIC
../../lib/libterra.a(TerrainCell.cpp.o): in function `Ogre::TerrainCell::TerrainCell(Ogre::Terra)’:
/home/parallels/workspace/src/gz-rendering/ogre2/src/terrain/Terra/src/TerrainCell.cpp:46:(.text+0x110): dangerous relocation: unsupported relocation
collect2: error: ld returned 1 exit status
gmake[2]: *** [ogre2/src/CMakeFiles/gz-rendering7-ogre2.dir/build.make:907: lib/libgz-rendering7-ogre2.so.7.4.0] Error 1
gmake[1]: *** [CMakeFiles/Makefile2:3321: ogre2/src/CMakeFiles/gz-rendering7-ogre2.dir/all] Error 2
gmake: *** [Makefile:166: all] Error 2
Failed <<< gz-rendering7 [3.28s, exited with code 2]`
Thank you!
-Aaron
