Highlights
Fortress/Garden: Additional convenience classes: Actor, Joint, Light, and Sensor. These classes provide a more object-oriented interface to the Entity Component Manager and would be familiar to Gazebo-classic users. We’ve also created tutorials on migrating the Actor, Joint, Light, and Sensor classes from gazebo classic -
Garden: Gazebo now uses a more aggressive low-pass filter which makes the RTF display more stable and reflect the RTF of a longer window of time. gz-sim#1942
Fortress/Garden: Adds a simple camera FPS plugin to show the GUI camera’s framerate. gz-gui#523
Garden: The Reset button has been added to world_control. Note that you need to update yourgui.configto match the new width of the world_control widget. Alternatively, you can remove~/.gz/sim/7/gui.configand a new one will be created for you. SDFormat files that have<gui>tags will also need to be updated with the new width. gz-sim#476
Garden: Support for airspeed sensor has been added in gz-sim#1847 -
Garden: Support for bayer images to has been added to Ogre and Ogre2 in gz-rendering#838
Garden: Actuators message input for JointController, JointPositionController, Ackermann Steering. This adds the ability to control multiple joints with a single message. gz-sim#1953 -
Garden: Performance improvements to rendering sensors gz-sim#1938 -
Garden: Support for fluid added mass is complete gz-sim#1592 -
Citadel: The Resource Spawner load time has been significantly improved by fetching the model list asynchronously gz-sim#1962 -
Citadel/Fortress/Garden: Passstd::functionby value toNode::Subscribegz-transport#382. This allows users to pass lambdas directly toNode::Subscribelike so:transport::Node node; node.Subscribe([](const Foo& msg) { // do something with msg return; }); -
Garden: Fixed a bug in how fixed joints are handled when URDF files are converted to SDFormat sdformat#1238.libsdformatnow also gives more specific warnings during conversion when it encounters links with no inertia or zero mass. A tutorial on the parameters that affect URDF->SDFormat conversion is now also available.
Releases
Gazebo Cmake 3.1.0, 3.2.0 and 3.2.1 (Garden)
Changelog
GzSetCompilerFlags: Fix detection of clang-cl
Add support for adding cmake extras to packages
Build examples using native CMake
Add optional binary relocatability in downstream libraries
Changes up to 2.17.0
Contributors
Benjamin Perseghetti
Ian Chen
Jorge Perez
Jose Luis Rivero
Michael Carroll
Silvio Traversaro
Steve Peters
Gazebo Cmake 2.17.0 (Citadel and Fortress)
Changelog
Use CONFIG in gz_add_benchmark to avoid Windows collisions
Fix FindAVDEVICE.cmake in case without pkg-config installed with ffmpeg >= 5.1
Contributors
Jorge Perez
Jose Luis Rivero
Silvio Traversaro
Steve Peters
Gazebo Common 5.4.0 (Garden)
Changelog
Add support for bayer images to be saved in a directory
Update common5 for bazel builds
Fixed metalness/roughness in ASSIMP loader
Fix Capsule mesh generation
Changes up to 4.7.0
Contributors
Addisu Z. Taddese
Alejandro Hernández Cordero
Ben Wolsieffer
Ian Chen
Konstantinos Chatzilygeroudis
Michael Carroll
Nate Koenig
Steve Peters
Tejal Ashwini Barnwal
Gazebo Common 4.7.0 (Fortress)
Changelog
Fix for ffmpeg v6
Fixed MeshManager Singleton
Contributors
Addisu Z. Taddese
Ben Wolsieffer
Michael Carroll
Steve Peters
Gazebo Fuel-Tools 8.0.2 (Garden)
Changelog
Fix model downloads for ignitionrobotics.org URIs.
Fix build when
JSON_USE_EXCEPTION == 0 -
Changes up to 7.2.2
Contributors
Addisu Z. Taddese
Cristóbal Arroyo
Ian Chen
Nate Koenig
Steve Peters
Gazebo Fuel-Tools 7.2.1 and 7.2.2 (Fortress)
Changelog
- Changes up-to 4.9.0
Contributors
Addisu Z. Taddese
Cristóbal Arroyo
Nate Koenig
Steve Peters
Gazebo Fuel-Tools 4.8.1, 4.8.2, 4.8.3. and 4.9.0 (Citadel)
Changelog
Add bash completion
Reflect pagination of RESTful requests in iterator API
Support link referral download
Allow Curl redirect on get.
Contributors
Addisu Z. Taddese
Nate Koenig
Steve Peters
Gazebo Gui 7.1.0 and 7.2.0 (Garden)
Changelog
Add support for bayer images to get displayed in gazebo gui
Apply low-pass filter to RTF display
Added Reset button to world_control
Tries to fix a scenario when a user sends a malformed point cloud
Fix attribute update when
<dialog>isn’t present -
Changes up to 6.8.0
Contributors
Addisu Z. Taddese
Arjo Chakravarty
AzulRadio
Ian Chen
Jenn Nguyen
Louise Poubel
methylDragon
Michael Carroll
Nate Koenig
Steve Peters
Gazebo Gui 6.8.0 (Fortress)
Changelog
Add degree as an optional unit for rotation in GzPose.
Update cmd/CMakeLists to conform with all other gz libraries.
Add pointer check in Application::RemovePlugin.
Add Camera FPS plugin.
Fix data race issues in CameraTracking plugin.
Contributors
Addisu Z. Taddese
AzulRadio
Ian Chen
Jenn Nguyen
Louise Poubel
methylDragon
Nate Koenig
Steve Peters
Gazebo Math 6.14.0 (Citadel and Fortress)
Changelog
Disable pybind11 on windows by default
Add option to skip pybind11 and SWIG
Custom PID error rate
Contributors
Addisu Z. Taddese
Michael Carroll
Nate Koenig
Steve Peters
Gazebo Msgs 9.3.0 and 9.4.0 (Garden)
Changelog
Support for bazel in garden
Add entity wrench map
Added airspeed sensor
Fix cross-compilation workflow
Contributors
Arjo Chakravarty
Carlos Agüero
Ian Chen
Michael Carroll
Rhys Mainwaring
Silvio Traversaro
Gazebo Physics 6.3.0, 6.3.1, 6.3.2, and 6.4.0 (Garden)
Changelog
dartsim: Add support for joints in worlds
Bullet featherstone: Add JointTransmittedWrench for F-T sensor
Support multiple collisions per link in bullet-featherstone
Fix bullet related segfaults on macOS
dartsim: Refactor entity addition logic in the EntityStorage class
Fix a crash due to an invalid pointer
Fix joint index used in bookkeeping
Resolve joints in nested models
Apply gravity external to dartsim for added mass
Install the common test executables to libexec
[bullet]: Fix how changed link poses are computed
Changes up to 5.3.1
Contributors
Addisu Z. Taddese
Aditya Pande
Louise Poubel
methylDragon
Michael Carroll
Nate Koenig
Rhys Mainwaring
Steve Peters
Gazebo Physics 5.3.1 (Fortress)
Changelog
- Fix memory corruption due to faulty refcount tracking
Contributors
Addisu Z. Taddese
Steve Peters
Gazebo Rendering 7.3.0, 7.3.1, and 7.4.0 (Garden)
Changelog
Add Projector
Add support for bayer images to Ogre and Ogre2
Fix requiring OpenGL on macOS
Lower severity level for ogre2 visibility mask msgs and unavailable render passes
Fix deleting ogre2 when created (and deleted) in a thread
Add message to see troubleshooting page when render engine fails to create dummy window
Limit max camera position vector length
Cleanup GpuRays properly
Ensure composite BaseVisuals are destroyed correctly.
Mesh cleanup on destruction
Fix gpu lidar memory leak [ogre2]
Fix selecting semi-transparent visuals
Fix Ogre2DepthCamera on macOS (Fortress)
Add Heightmap integration test
Restore GLX context after OGRE plugin loading finishes.
Do not overwrite reserved visibility flags in ogre2
Fix Metal shader compiler error in GpuRays (Lidar)
Fix memory corruption in Ogre2GpuRays
Enable ray heightmap ray query
Fix RenderTarget::destroy not getting called in both ogre1 & ogre2
Implement consistent Auto Aspect Ratio
Fix bounding box for glbs
Use proper sRGB conversion in DepthCamera
Enable Heightmap Test for ogre2 & fix crash when using GpuRays camera
Fix non-deterministic rendering due to background texture loading
Fix lidar heightmap detection
Changes up to 6.6.0
Contributors
Ian Chen
Martin Pecka
Matias N. Goldberg
methylDragon
Michael Carroll
Nate Koenig
Rhys Mainwaring
Silvio Traversaro
Steve Peters
Gazebo Rendering 6.6.0 (Fortress)
Changelog
Backport Composite BaseVisual destroy fix to 6
Fix transparency over heightmap
Fix duplicate PreRrender calls
Changes up to 3.7.1
Contributors
Ian Chen
methylDragon
Michael Carroll
Nate Koenig
Gazebo Rendering 3.7.1 (Citadel)
Changelog
- Remove fini to resolve segfault at shutdown.
Contributors
Nate Koenig
Gazebo Sensors 7.1.0 and 7.2.0 (Garden)
Changelog
Cleanup resources in CameraSensor destructor
Added trigger to BoundingBoxCamera
Clean up rendering resources
Added Camera Info topic support for cameras
Set custom projection matrix based on intrinsics params from SDF
Renamed
ignition_frame_idtogz_frame_idand fix warning -
Update Camera Intrinsics in camera_info topic
Changes up to 6.7.0
Contributors
Addisu Z. Taddese
Aditya Pande
Alex
Brian
Ian Chen
Louise Poubel
Marq Rasmussen
methylDragon
Michael Carroll
Michel Hidalgo
Nate Koenig
quentingllmt
Steve Peters
Valentina Vasco
Gazebo Sensors 6.7.0 (Fortress)
Changelog
Add optional optical frame id to camera sensors.
Add support for 16 bit image format.
Fix navsat frame id.
CameraInfo is now published when there’s a CameraSensor subscriber.
Add HasInfoConnections() method to expose infoPub.HasConnections() to
child of CameraSensor class.
Contributors
Alex
Brian
Ian Chen
Jenn Nguyen
Jorge Perez
Louise Poubel
Marq Rasmussen
methylDragon
Nate Koenig
Steve Peters
Gazebo Sim 7.3.0, 7.4.0, and 7.5.0 (Garden)
Changelog
Add missing cmake exports from core library
Update sdf plugins to use actuator_number.
Unload render engine when the sensors system exits
Use GzSpinBox instead of IgnSpinBox in ViewAngle plugin.
Add tutorial on migrating the Actor, Joint, and Light classes from gazebo classic
Optimize render updates and use of thread mutexes in Sensors system
Fix use of actors that only has trajectory animation
Remove filtering from realtime factor (RTF) calculation
Fix docker/README.md
Use a queue to track component registration from mulitiple sources
Initialize services in ViewAngle constructor
Add comment on center of buoyancy force
Add convenience classes: Actor, Joint, Light, and Sensor
Resolve inconsistent visibility on ign-gazebo6
Fix formatting of error messages with large mesh file names
Update all velocity and acceleration components of non-link entities
Allow to change camera user hfov in camera_view plugin
Added magnetometer value based on location
Allow specifying initial simulation time with a CLI argument
Add Joint class
Added reset simulation tutorial
Add SensorTopic component to rendering sensors
Inherit material cast shadows property
Remove actors from screen when they are supposed to
JointPosController: support nested joints
Fluid added mass
Add P gain value for Ackermann steering.
Add orientation to Odom with covariance.
Contributors
Addisu Z. Taddese
Anas Aamoum
Arjo Chakravarty
AzulRadio
Carlos Agüero
Cristóbal Arroyo
El Jawad Alaa
Ian Chen
Jenn Nguyen
Joan Aguilar Mayans
Louise Poubel
Mabel Zhang
Matthew LeMay
methylDragon
Michael Carroll
Nate Koenig
Onur Berk Töre
Rhys Mainwaring
Steve Peters
Gazebo Sim 3.15.0 (Citadel)
Changelog
Speed up Resource Spawner load time by fetching model list asynchronously
Fix loading wold with record topic
Remove duplicate Fuel server used by ResourceSpawner
Re-add namespace for GUI render event
Fix QML warnings regarding binding loops
Update documentation on
UpdateInfo::realTime -
Remove plotIcon in Physics.qml for Component Inspector
Added collection name to About Dialog
Contributors
Addisu Z. Taddese
Arjo Chakravarty
AzulRadio
Ian Chen
Jenn Nguyen
methylDragon
Nate Koenig
Steve Peters
Gazebo Transport 12.2.0 (Garden)
Changelog
Support clang and std::filesystem
Pass std::function by value to Node::Subscribe
Prevent invoking callbacks after a node unsubscribes to a topic
Fix CLI configuration install path to ignition
Changes up to 11.4.0
Contributors
Carlos Agüero
Ian Chen
Michael Carroll
Nate Koenig
Steve Peters
Gazebo Transport 11.4.0 (Fortress)
Changelog
- Added Node::RequestRaw
Contributors
Michael Carroll
Nate Koenig
SDFormat 13.3.0, 13.4.0, 13.4.1, and 13.5.0 (Garden)
Changelog
Added projector Python wrapper
Added new error codes in Python
Add missing element
visualizein 1.9/light.sdf -
Add Projector DOM
Update libsdformat APIs to use sdf::Errors parameters instead of printing errors to the console.
- Several PRs tracked by: Explicitly delimit EOM for logging · Issue #820 · gazebosim/sdformat · GitHub
Fix Element::Set method return value
Add missing values in Surface ToElement method
URDF->SDF handle links with no inertia or small mass
Allowing relative paths in URDF
Fix camera_info_topic default value
Add support for merge-includes in worlds
Backport the python3 embedSdf script variant
Add missing sdf files from xsd generation
Add airspeed sensor
Warn child joint that resolves to world
ParamPassing: sdfwarns to sdf::Errors when warnings policy set to sdf::EnforcementPolicy::ERR
Camera: added HasLensProjection
Change default
camera_info_topicvalue to__default__ -
Check JointAxis expressed-in values during Load
Added camera info topic to Camera
Fix static URDF models with fixed joints
Changes up to 12.7.1
Contributors
Aaron Chong
Addisu Z. Taddese
Ben Wolsieffer
Ian Chen
Liam Han
Marco A. Gutierrez
methylDragon
Michael Carroll
Nate Koenig
Robert Plante
Steve Peters
Vít Ondruch
SDFormat 12.7.0 and 12.7.1 (Fortress)
Changelog
- Fix camera info topic default value
Contributors
Ben Wolsieffer
Ian Chen
methylDragon
Nate Koenig
Steve Peters
Vít Ondruch
