Highlights
Citadel:gz/*include headers can now be used in pre-Garden versions ofgz-common,gz-math, andgz-msgs. This will ease migration from ignition to gazebo. -
Garden: Add bullet-featherstone plugin togz-physics. The full integration withgz-simwill be released soon. -
Script and tutorial for generating procedural datasets with Blender
Garden: Clarify the definition of<joint><thread_pitch>SDFormat 1.10 and introduce<joint><screw_thread_pitch>
which uses a more conventional unit. -
Citadel: libsdformat now adds<frame>s for reduced links/joints when parsing URDF files to preserve the pose information of those elements.
Releases
These are the minor and patch releases that came out since the previous post and the release of Garden.
Gazebo Common 5.1.0 to 5.2.2 (Garden)
Changelog
[Backport] Avoid Io.hh header name clash (#471)
Fix arm builds and tests
Add CSV data parsing
Skip CSV header when reading DataFrame.
Adds an API to retrieve keys.
All common4 changes up to 4.6.1 release
All common3 changes up to 3.15.1 release
Don’t install auto-generated profiler.hh
Fixed MeshManager Singleton
Don’t install CMakeLists.txt
ign → gz Migrate Ignition Headers : gz-common
Suppress a bunch of unnecessary test output
Fix metallic roughness file path for gltf assets
Include cstring for memcpy
Remove redundant namespace references
Contributors
Alejandro Hernández Cordero
Arjo Chakravarty
CristĂłbal Arroyo
Jochen Sprickerhof
Louise Poubel
Luca Della Vedova
methylDragon
Michael Carroll
Michel Hidalgo
Nate Koenig
Steve Peters
Gazebo Common 3.15.0 and 3.15.1 (Citadel)
Changelog
Fix build on case-insensitive filesystems
Contributors
Michael Carroll
Nate Koenig
Steve Peters
methylDragon
Gazebo Common 4.6.0 and 4.6.1 (Fortress)
Changelog
Contributors
Jochen Sprickerhof
Louise Poubel
Michael Carroll
Nate Koenig
Steve Peters
methylDragon
Gazebo Math 6.13.0 (Citadel and Fortress)
Changelog
Support migration and migrate headers
Contributors
methylDragon
Gazebo Msgs 8.7.0 (Fortress)
Changelog
ign → gz Redirect Gz Headers
Add parameter component message definitions
Remove redunant namespace references
Contributors
Ivan Santiago Paunovic
methylDragon
Steve Peters
Gazebo Msgs 5.11.0 (Citadel)
Changelog
Ignition to Gazebo renaming.
Remove mistaken VERSION.
Increase utility coverage.
Contributors
Jenn Nguyen
Louise Poubel
methylDragon
Nate Koenig
Gazebo Physics 6.1.1
Changelog
Suppress MSVC warning that is not applicable
Fix construction of nested models
Removed GetCollision API it’s redundant
Fix bullet cmake, probably bad merge
Contributors
Grey
Michael Carroll
Nate Koenig
Gazebo Rendering 7.1.0
Changelog
Initialize wide angle camera pixel format
Fix use of singletons
All changes merged forward from ign-rendering6
Contributors
Addisu Z. Taddese
ahcorde
CristĂłbal Arroyo
Ian Chen
methylDragon
Sanjuksha
Gazebo Rendering 3.6.1 (Citadel)
Changelog
Improved coverage: MeshDescriptor, Mesh, MoveToHelper, OrbitViewController, PixelFormat and ShadersParams
Suppress Windows warnings
Improved RenderEngine and Mesh coverage
Increase TransformControl test converage (#668)
Increased Marker coverage
Added shaderType converage
Improved grid coverage
Improved coverage Arrow and Axis visuals and fixed some warnings
Backport from 6 to 3. Disable C4275 warnings on Windows from OgreUTFString (#621)
Disabling flaky depth and thermal camera tests on mac (#405)
Change IGN_DESIGNATION to GZ_DESIGNATION (#677)
Add coverage ignore file
Ignition → Gazebo
fix checking unofficial ogre version when ogre 1.x is not installed
Updated CODEOWNERS
Silence CMake policy CMP0072
Contributors
AzulRadio
CristĂłbal Arroyo
Ian Chen
Jenn Nguyen
Jorge Perez
Louise Poubel
methylDragon
Michael Carroll
William Lew
Gazebo Sim 6.13.0
Changelog
Fix two tests on Windows
All ign-gazebo3 changes up to 3.14.0 release
Some minor changes to hydrodynamic flags test
Fix thruster integration test
Fix scene_broadcaster_system test
Enable use of ign gazebo -s on Windows (take two)
Removed unused speedlimit file
Fortress: Removed warnings
Enable/Disable individual hydrodynamic components.
Adding thrust coefficient calculation
Restore Add System GUI plugin
Return absolute path when finding a resource
Adds sky cubemap URI to the sky.proto’s header
Update triggered_publisher.sdf
Add ResourceSpawner example file
Enable inherited model topic name.
Fix loading render engine plugins in GUI
Add a service to trigger functionality
Fix installation instructions on Ubuntu 22.04
Fix reference link in ackermann steering
Contributors
Andrej Orsula
Arjo Chakravarty
Benjamin Perseghetti
Ian Chen
Jose Luis Rivero
Kenji Brameld
Liam Han
Marco A. Gutierrez
Michael Carroll
Nate Koenig
Silvio Traversaro
Steve Peters
SDFormat 13.1.0 and 13.2.0 (Garden)
Changelog
sdf/1.10/joint.sdf: add
screw_thread_pitch -
sdf/1.10: support //world/joint specification
Model: add sdf::Errors output to API methods
Added Root::WorldByName
Python: add OpticalFrameID APIs to pyCamera
Fix
GZ_PYTHON_INSTALL_PATHvalue -
Rename python bindings import library for Windows
Add test helper python package for encapsulating versioned python packages
Add a configuration option to resolve URIs
World: sdfwarns to sdf::Errors when warnings policy set to sdf::EnforcementPolicy::ERR
PrintConfig: add sdf::Errors output to API methods
Element: add sdf::Errors output to API methods
python: Import gz.math at startup to fix #1129
parser_urdf: add //frame for reduced links/joints
Param::Set: fix truncation of floating-point values
Reduce the number of include dirs for sdformat
urdf: fix test and clean up internals
sdf/camera.sdf: fields for projection matrix
Add camera optical_frame_id element
Contributors
Addisu Z. Taddese
Brian
Jose Luis Rivero
Marco A. Gutiérrez
Marq Rasmussen
Michael Carroll
Nate Koenig
Silvio Traversaro
Steve Peters
Will Stott
SDFormat 12.6.0 (Fortress)
Changelog
Reduce the number of include dirs for sdformat.
Add camera
optical_frame_idelement -
urdf: fix sensor/light pose for links lumped by fixed joints
Removed USD component from SDFormat and move to gz-usd
Fix URDF fixed joint reduction of SDF joints
Test model name as
placement_frame -
Test using
__model__,worldin@attached_to,@relative_to -
Remove unused sdf.hh.in template
Readme: Ignition → Gazebo
Document major and minor SDFormat version numbers
Add skybox URI
Bash completion for flags
Fix bug with resolving poses for joint sensors.
sdf::Joint: Mutable versions of SensorByName and SensorByIndex
Add Link::ResolveInertial API
Contributors
Addisu Z. Taddese
Brian
Jenn Nguyen
Mabel Zhang
Marco A. Gutiérrez
Marq Rasmussen
Michael Carroll
Nate Koenig
Stefan Profanter
Steve Peters
SDFormat 9.9.0 (Citadel)
Changelog
Ensure relocatable config files
Test using
__model__,worldin @attached_to, @relative_to -
Contributors
Brian
Jenn Nguyen
Mabel Zhang
Stefan Profanter
Steve Peters
