Cargo ros-new and cargo ros-add plugin
Overview
To streamline ROS 2 development in [Rust](https://www.rust-lang.org/), I have developed two [Cargo]( Introduction - The Cargo Book ) plugins that simplify package creation and dependency management: [cargo-ros-new]( crates.io: Rust Package Registry ) and [cargo-ros-add]( crates.io: Rust Package Registry ). The primary goal of these tools is simplify the management of the dual-manifest system (Cargo.toml and package.xml), reducing boilerplate and ensuring consistency.
ros_new
This plugin extends the standard cargo new command to bootstrap a new Rust package that is also a valid ROS 2 package. It automates the initial setup process, creating all the necessary files with the correct configurations.
Features:
  • Standard Package Scaffolding: Leverages cargo new to create a standard Rust package, inheriting all its native features and directory structure.
  • Automated package.xml Generation: Simultaneously generates a ROS 2-compliant package.xml manifest, automatically populating it with:
    • Package name and version, synchronized from Cargo.toml.
    • Maintainer information (name and email).
    • License identifier, consistent with Cargo.toml.
    • Package description.
    • The required XML format specification (<package format="3">).
    • The ament_cargo build type declaration (<build_type>ament_cargo</build_type>), making the package compatible with Colcon.
  • Full cargo new Argument Passthrough: Supports all standard cargo new options, allowing for complete control over the initial setup, including:
    • --bin / --lib
    • --edition <YEAR>
    • --vcs <VCS>
    • --name <NAME>
ros_add
This plugin enhances cargo add by synchronizing Rust dependencies with your ROS 2 package manifest. When you add a dependency, it ensures both configuration files are updated correctly.
Features:
  • Synchronized Dependency Management: Updates both the Rust manifest (Cargo.toml) and the ROS 2 manifest (package.xml) with a single command, ensuring they never go out of sync.
  • Intelligent XML Updates: Atomically adds the corresponding <depend> tag to package.xml while preserving the original document’s formatting, indentation, and comments.
  • Idempotent Operations: The plugin is idempotent, meaning it will safely skip adding a dependency tag if it already exists in package.xml, preventing duplicates.
  • Robust Error Handling: Provides clear and actionable error messages for common failure scenarios, such as a missing package.xml file or malformed configuration.
No matter which tool you’re using, you should enjoy using it. If people don’t enjoy using a tool, they tend to use it less. Hopefully, these two plugins will improve your experience of developing ROS 2 Rust packages.
