Hi ROS!
So I recently stumbled across a bug with rosidl_generator_py that has a super easy fix, however I know it’ll be awhile before it gets implemented.
I’ve went ahead and tried to add the fix directly into a CMakelist.txt file for the problem-package, however I cant seem to get it to run after the rosidl files are generated. So instead I just warn the user to re-build the entire thing and then the cmake add_custom_command can find the generated file just fine and replace the bad bits with the good bits.
Question for the ROS community is does anyone know of a better way to do this? Either waiting until the rosidl_generator_py package is done doing its thing or re-running the CMake build from within the same CMake file ![]()
Any advice or input is greatly appreciated. Interested to hear your thoughts!
